#Define the measure
ds = ufl.Measure(“ds”, subdomain_data=facet_tags, subdomain_id=5 ) #Calculate the integral
integral = dolfinx.fem.form(u_test * ufl.ds)
print(fem.assemble_scalar(integral))
Also, you need dS instead of ds because dS integrates in the interior (actually I am not 100% sure for this). Moreover, (and this is a mistake I did a lot) you need to use the custom made ds instead of ufl.ds
from dolfinx import fem, mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, 100, 100, mesh.CellType.triangle)
mesh=domain
V = dolfinx.fem.FunctionSpace(domain, ("Lagrange", 1))
u_test = dolfinx.fem.Function(V)
u_test.interpolate(lambda x: 1 + x[0]**2 + 2*x[1]**2)
def facet_eq(x):
return np.isclose(x[0], 0.5)
facets = dolfinx.mesh.locate_entities(mesh, mesh.topology.dim-1, facet_eq)
facet_tags = dolfinx.mesh.meshtags(mesh, mesh.topology.dim-1, facets, np.full_like(facets, 5))
#Define the measure
ds = ufl.Measure("dS", subdomain_data=facet_tags, subdomain_id=5 )
integral = dolfinx.fem.form(u_test * ds)
dS is the integral measure over interior facets, these are facets that are connected to two cells. ds is for exterior facets, those only connected to one cell.
