I am working on nonlinear mechanics, where there is pressure acting on a boundary. This yields a term looking like
with the standard notation (J=\text{det}(\mathbf d), \mathbf F = \mathbf I + \nabla \mathbf d). This term is not symmetric (at least I concluded so after some lengthy computations), and I have also verified this by doing some computations in another FEM library. Thing is, UFL yields a symmetric jacobian no matter what, so I was wondering if this has something to do with how UFL computes things. Here is an MWE:
mesh = UnitCubeMesh(10, 10, 10)
left = CompiledSubDomain("near(x[0], side) && on_boundary", side=0.0)
right = CompiledSubDomain("near(x[0], side) && on_boundary", side=1.0)
c_bc = Constant(("0.0", "0.0", "0.0"))
r_bc = Expression(("scale*0.0",
"scale*(y0 + (x[1] - y0)*cos(theta) - (x[2] - z0)*sin(theta) - x[1])",
"scale*(z0 + (x[1] - y0)*sin(theta) + (x[2] - z0)*cos(theta) - x[2])"),
scale=0.5, y0=0.5, z0=0.5, theta=pi/3, degree=4)
bcl = DirichletBC(V, c_bc, left)
bcr = DirichletBC(V, r_bc, right)
bcs = [bcl, bcr]
# Define functions
du = TrialFunction(V) # Incremental displacement
v = TestFunction(V) # Test function
u = Function(V) # Displacement from previous iteration
# Kinematics
I = Identity(3) # Identity tensor
C = F.T*F
E = 0.5 * (C - I)
J = det(F)
# Elasticity parameters
E_elast, nu = 10.0, 0.3
mu, lmbda = Constant(E_elast/(2*(1 + nu))), Constant(E_elast*nu/((1 + nu)*(1 - 2*nu)))
P = mu * F + (-mu + lmbda * ln(J)) * inv(F.T)
Res = inner(P, grad(v)) * dx - dot(Constant(1e0) * J * inv(F.T) * FacetNormal(mesh), v) * ds
Jac = derivative(Res, u, du)
solve(Res == 0, u, bcs, J=Jac)
# Test symmetry
Jnpy = assemble(Jac).array()
ten = np.abs(Jnpy-Jnpy.T) < 1e1 * np.finfo(float).eps
print("First Piola Symmetric: ", np.all(ten))
Which of course in the end gives ‘True’. Any ideas on why this is happening?
Thanks in advance,
Nicolas
