Tag surfaces inside the domain
Dear all,
I am solving a flow in a rectangular domain and I need to compute the mass flux on the mid transverse plane (plane S of the following figure).
Therefore, I need to define a differential of surface such as:
dSurf = Measure("ds", domain=mesh, subdomain_data=ft, subdomain_id=surface_marker)
My problem is that I do not know how to tag that surface, since it is not part of the boundaries set. Therefore, if I use the usual approach, that is:
surface_marker = 2
surface = []
if rank == 0:
    for boundary in boundaries:
        if np.allclose(center_of_mass, [0, 0, 0]):
            surface.append(boundary[1])
the mass flux is always zero because there is not any real boundary at [0,0,0].
Does anybody know how to tag surfaces in dolfinx that are not part of the boundaries set?
Thanks in advance.
I know this is an old question, but did you try :
fdim = spy.mesh.topology.dim - 1
	facets = dfx.mesh.locate_entities(spy.mesh, fdim, locator)
	facet_indices.append(facets)
facet_tag = dfx.mesh.meshtags(spy.mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.Measure("ds", domain=spy.mesh, subdomain_data=facet_tag)
Seems to work for me. Taken straight from this excellent tutorial - credit’s due where it’s due
