Thank you very much @dokken !!
I have looked at the link you provided. Since i am not dealing with interior facets, I can simply solve over ‘ds’ instead of ‘dS’ and without restricting the normal directions using ‘res’.
Here is the code I used, and this prints the tangent vectors and normal vectors.
In the code, I am printing the facet normals that lie in the bottom (base) of cube. Hence, the normals are supposed to have only ‘z’ component.
from ufl import Jacobian, replace
from ufl.classes import FacetJacobian, ReferenceGrad, ReferenceValue
# generate mesh
mesh = BoxMesh(Point(0, 0, 0), Point(1, 1, 1), 1, 1, 1)
# mark bottom boundary
boundaries = MeshFunction('size_t', mesh, mesh.topology().dim() - 1)
boundaries.set_all(0)
class BottomFace(SubDomain):
return on_boundary and near(x[2], 0.0)
bottom_face = BottomFace()
bottom_face.mark(boundaries, 1) # Mark with '1' for bottom face
# Calculate facet normals, tangent vectors
J = FacetJacobian(mesh)
G1 = J[:,0] # \partial{x_i}/\partial{Xf_1}
G2 = J[:,1] # \partial{x_i}/\partial{Xf_2}
N = cross(G1,G2) # normal vector
N = N/sqrt(dot(N,N)) # normalize N
# n = FacetNormal(mesh)
# simple problem to project them and visualize
param = N # (normal) this is the parameter we want to compute
V = VectorFunctionSpace(mesh, 'DG', 1)
dv = TestFunction(V)
v = TrialFunction(V)
a_V = inner(dv, v)*ds + Constant(0)*inner(dv,v)*dx
L_v = inner(dv, param)*ds
param_out = Function(V)
a_V = assemble(a_V, keep_diagonal=True)
L_v = assemble(L_v)
a_V.ident_zeros()
solve(a_V, param_out.vector(), L_v)
# Print out the values of normal vector at each facet midpoint
# (fenicsproject.disclosure.group)
W = FunctionSpace(mesh, 'CG', 1)
for f in facets(mesh):
if boundaries[f] == 1:
print("Facet index:", f.index())
vertex_coords = []
vertex_indices = []
for vertex in vertices(f):
vertex_coords.append(list(vertex.point().array()))
vertex_indices.append(vertex.index())
facet_dofs = W.dofmap().entity_dofs(mesh, mesh.topology().dim()-1, [f.index()])
vertex_dofs = W.dofmap().entity_dofs(mesh, 0, vertex_indices)
print("Vertex Coords and DOFs:", vertex_coords, facet_dofs, vertex_dofs)
# print parameter values at facet midpoint
mp = f.midpoint()
param_value = N_out(mp)
print("N at midpoint:", param_value)
N_file = File("param.pvd")
N_file << param_out
But the results are weird.
Facet index: 0
Vertex Coords and DOFs: [[0.0, 0.0, 0.0], [1.0, 0.0, 0.0], [1.0, 1.0, 0.0]] [] [1, 5, 6]
N at midpoint: [0.16666667 0. 0.83333333]
Facet index: 3
Vertex Coords and DOFs: [[0.0, 0.0, 0.0], [0.0, 1.0, 0.0], [1.0, 1.0, 0.0]] [] [1, 7, 6]
N at midpoint: [ 0. -0.16666667 -0.83333333]
I think this is coming from the simple problem i am solving for projecting. Is this correct?
Anyways, I am going to use these normals in my weak formulation. I just wanted to check whether the normal and tangent vectors I am calculating are correct.
