Hello everyone,
I tried to solve the problem of electric field distribution in a two-dimensional axisymmetric coordinate system (r-z), but I found that the output value of electric field strength is always “inf”.
Here is an MWE. The problem is a calculation domain with r=2mm and z=5mm, where the potential at the position of z=5mm is 10V and the potential at the position of z=0mm is 0.
import numpy
from dolfinx import mesh, fem
from ufl import (dot, dx, grad)
domain = mesh.create_rectangle(MPI.COMM_WORLD, ([0,0],[2e-3,5e-3]), [20,50], mesh.CellType.triangle)
# Defining FunctionSpace
## Voltage
V = fem.FunctionSpace(domain, ("Lagrange", 1))
## Electric intensity
element_E = ufl.VectorElement("Lagrange", domain.ufl_cell(), 1)
E = fem.FunctionSpace(domain, element_E)
# Create boundary condition
## anode_marker
def anode_marker(x):
return numpy.isclose(x[1], 5e-3)
## cathode_marker
def cathode_marker(x):
return numpy.isclose(x[1], 0)
anode_boundary_entity = mesh.locate_entities_boundary(domain, 1, anode_marker)
cathode_boundary_entity = mesh.locate_entities_boundary(domain, 1, cathode_marker)
anode_boundary_dof = fem.locate_dofs_topological(V, 1, anode_boundary_entity)
bc1_voltage = fem.dirichletbc(PETSc.ScalarType(10), anode_boundary_dof, V)
cathode_boundary_dof = fem.locate_dofs_topological(V, 1, cathode_boundary_entity)
bc2_voltage = fem.dirichletbc(PETSc.ScalarType(0), cathode_boundary_dof, V)
# Define trailfunction and testfunction
## Voltage
u_voltage = ufl.TrialFunction(V)
v_voltage = ufl.TestFunction(V)
## electric intensity
u_E = ufl.TrialFunction(E)
v_E = ufl.TestFunction(E)
# Compute voltage
a = dot(grad(u_voltage), grad(v_voltage)) * x[0] * dx
f = fem.Constant(domain, PETSc.ScalarType(0))
L = f * v_voltage * x[0] * dx
problem = LinearProblem(a, L, bcs=[bc1_voltage, bc2_voltage], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
u_voltage = problem.solve()
# Compute electric intensity
a = dot(u_E, v_E) * x[0] * dx
L = -dot(grad(u_voltage), v_E) * x[0] * dx
problem = LinearProblem(a, L, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
u_E = problem.solve()
print(u_voltage.x.array)
print(u_E.x.array)
The result of running the code is as follows:
[ 0. 0. 0.2 ... 9.8 10. 10. ]
[inf inf inf ... inf inf inf]
It is obvious that the electric field strength generated by a uniform electric field with a potential difference of 10V and a distance of 5mm should be 2000V/m.
I have made some modifications that seem to avoid outputting “inf”.
If the number of grids is reduced, for example:
domain = mesh.create_rectangle(MPI.COMM_WORLD, ([0,0],[2e-3,5e-3]), [2,5], mesh.CellType.triangle)
[ 0. 0. 2. 2. 0. 4. 2. 4. 6. 4. 6. 8. 6. 8. 10. 8. 10. 10.]
[ 2.09704918e-13 -2.00000000e+03 -3.21492470e-13 -2.00000000e+03
4.56580570e-13 -2.00000000e+03 1.38844405e-13 -2.00000000e+03
-4.75498750e-13 -2.00000000e+03 3.45393962e-13 -2.00000000e+03
-7.44081027e-13 -2.00000000e+03 -2.87688412e-13 -2.00000000e+03
-4.77103187e-13 -2.00000000e+03 4.57738155e-13 -2.00000000e+03
-1.01184923e-12 -2.00000000e+03 -1.90857790e-12 -2.00000000e+03
-9.67609523e-13 -2.00000000e+03 -1.53526676e-12 -2.00000000e+03
-6.75744090e-13 -2.00000000e+03 -2.50548673e-12 -2.00000000e+03
1.44144609e-13 -2.00000000e+03 1.10859876e-12 -2.00000000e+03]
If I replace the coordinate system with a two-dimensional Cartesian coordinate system (x-y) — actually the only difference in the code is that x[0] is missing from the variational equation.
[-2.04011867e-13 -2.00000000e+03 8.99103355e-14 ... -2.00000000e+03
-1.17962349e-11 -2.00000000e+03]
These two appear to be correct,but what’s going on with the e-13 magnitude?
Therefore, there must be a problem in this, can you give me some instructions?
