I would like to define time-dependent BC on a scalar FEM space. Here is a MWE:
from basix.ufl import element
from dolfinx.fem import (Function, dirichletbc, functionspace, locate_dofs_topological, locate_dofs_geometrical,)
from dolfinx.mesh import *
# mesh, spaces, functions
msh = create_unit_square(MPI.COMM_WORLD, 10,10)
P1 = element("Lagrange", "triangle", 1)
XV = functionspace(msh, P1)
# BC
def Gamma(x):
return np.isclose(x[0], 0.)
class time_dep_func:
def __init__(self):
self.t = 0.0
def eval(self, x):
return np.sin(self.t)
BC_obj = time_dep_func()
BC_obj.t = 0.
bc_fun = Function(XV)
bc_fun.interpolate(BC_obj.eval)
dofs = locate_dofs_geometrical(XV, Gamma)
bcu = dirichletbc(bc_fun, dofs, XV)
I get an error message like this:
File "/home/renoldner/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/fem/function.py", line 397, in interpolate
_interpolate(u, cells)
File "/home/renoldner/miniconda3/envs/fenicsx/lib/python3.11/functools.py", line 909, in wrapper
File "/home/renoldner/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/fem/function.py", line 373, in _interpolate
self._cpp_object.interpolate(u, cells, nmm_interpolation_data)
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
1. (self: dolfinx.cpp.fem.Function_float64, f: numpy.ndarray[numpy.float64], cells: numpy.ndarray[numpy.int32]) -> None
2. (self: dolfinx.cpp.fem.Function_float64, u: dolfinx.cpp.fem.Function_float64, cells: numpy.ndarray[numpy.int32], nmm_interpolation_data: Tuple[List[int], List[int], List[float], List[int]]) -> None
3. (self: dolfinx.cpp.fem.Function_float64, expr: dolfinx::fem::Expression<double, double>, cells: numpy.ndarray[numpy.int32]) -> None
Invoked with: <dolfinx.cpp.fem.Function_float64 object at 0x7f6542b703f0>, <bound method time_dep_func.eval of <__main__.time_dep_func object at 0x7f6546dd34d0>>, array([ 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12,
13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25,
26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38,
39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51,
52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64,
65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77,
78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90,
91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103,
104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116,
117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129,
130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142,
143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155,
156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168,
169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181,
182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194,
195, 196, 197, 198, 199], dtype=int32), ((), (), (), ())
File "/home/ [...] / test.py", line 34, in <module>
File "/home/renoldner/miniconda3/envs/fenicsx/lib/python3.11/site-packages/dolfinx/fem/function.py", line 402, in interpolate
self._cpp_object.interpolate(np.asarray(u(x), dtype=self.dtype), cells)
IndexError: invalid axis: 0 (ndim = 0)
I can not explain this, as in THIS DISCOURSE POST, the method seems to work (however, there, a Vector-valued FEM space is used).
Using
dofs = locate_dofs_topological(XV, 1, Gamma)
does not fix the error.
