Time dependent ODE's
I want to solve a problem of time dependent PDEs (reaction equations) with no spatial distribution. Is this any way to do it with Fenics?
Thanks
If your "PDE"s only vary with time you’d probably be better served by one of the many ODE integration libraries. Scipy wraps many of these nicely, e.g. odeint.
I want to solve them with PDE’s simultaneously, not alone.
I would strongly suggest that you state your PDEs, as it is quite hard to give advice without having a minimal example of a strong form of such a problem.
I have a system of 5 PDEs and 25 ODEs so lets say we have a more simple problem such as:
U.dt + U.dx^2 = f & f.dt = f^2 + f/3
(I didnt know how to write this in latex form So .dt and .dx are the derivatives with respect to time and space respectively)
$ \frac{a}{b} + c = d $
yields
\frac{a}{b} + c = d
which may help clarify your equations.
So lets start again
\frac{du}{dt} + \frac{du}{dx} = f & \frac{df}{dt} = f^2 + \frac{f}{3}
U and f are the uknowns
