**Description:**
I am trying to solve an inverse problem using FEniCS, where I need to estimate parameters \(A\) and \(C\) in a modified Burgers' equation. The forward model involves solving a nonlinear PDE, but the Newton solver fails to converge during the optimization process. I have tried adjusting solver parameters and reducing the time step, but the issue persists.
**Code:**
```python
from scipy.optimize import least_squares
# Parameters
nu = 0.01 / np.pi
T = 1.0
num_steps = 100
dt = T / num_steps
# Create mesh and function space
nx = 255
mesh = IntervalMesh(nx, -1, 1)
# Define boundary conditions
u_D = Constant(0.0)
def boundary(x, on_boundary):
return on_boundary
# Define initial condition
u_n = interpolate(Expression('-sin(pi*x[0])', degree=2), V)
# Define test function and current solution
# Time loop
def model(p):
A, C = p
u_n.assign(interpolate(Expression('-sin(pi*x[0])', degree=2), V))
model_output = []
for n in range(num_steps):
t = n * dt
F = A * ((u - u_n) / dt) * v * dx + u * u.dx(0) * v * dx + C * inner(grad(u), grad(v)) * dx
solver_parameters = {
"nonlinear_solver": "newton",
"newton_solver": {
"maximum_iterations": 100,
"relaxation_parameter": 0.7,
"relative_tolerance": 1e-8,
"absolute_tolerance": 1e-10,
solve(F == 0, u, bc, solver_parameters=solver_parameters)
model_output.append(u.vector().get_local())
u_n.assign(u)
return np.array(model_output)
RuntimeError:
*** https://fenicsproject.discourse.group/
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** Git changeset: 1c52e837eb54cc34627f90bde254be4aa8a2ae17
