First, you need to use physical markers on your lines and surfaces
See for instance this tutorial: https://jsdokken.com/converted_files/tutorial_pygmsh.html
In particular have a look at part 3.
What you should also do is inspect the objects that you are trying to access.
I.e. print msh.cells[“line”] etc.
