Hello there,
I am translating some Fenics code from GitHub - MoGeist/diffusion_PPDE to fenicsx. In this code I try to solve the parametrized diffusion equation n times. This equation looks as follows in general: -\nabla (a(x,y) \nabla u) = f in [0,1]^2 and 0 on the boundary. Here a(x,y)= a_0 + sum_{j=1}^p y_j sin(x_j). In this case, x,y \in R^p and y_j are uniformly drawn from [0,1]. Thus a(x,y) is a sum of trigonometric functions, which is generated in the following way:
def trigonometric_basis(n, p, mu=1, sigma=1):
'''Generate list of expressions and array of coefficients in polynomial basis (T1)
n: number of samples
p: number of basis fcts.
mu: shift
sigma: decay rate
num_terms = p
print(n,p)
coeff = np.random.uniform(0, 1., (n, num_terms))
expr_list = []
template_a = "+(1+{}*{}*(1+{}))"
template_sin = "sin({}*3.14159*x[0])*sin({}*3.14159*x[1])"
for i in range(n):
temp = str(mu)
for j in range(1,num_terms+1):
sin = template_sin.format(floor((j+2)/2), ceil((j+2)/2))
a = template_a.format(j**(sigma), str(coeff[i,j-1]), sin)
temp += a
expr_list.append(temp)
print(coeff)
return expr_list, coeff
In fenics, this was now solvable with:
def solver(expr):
'''Solver for parametric diffusion equation'''
a = Expression(expr, degree=params['inter_deg'])
F = dot(a*grad(u), grad(v))*dx - f*v*dx
solve(F == 0, u, bc)
return np.array(u.vector().get_local())
Since a(x,y) is generated with a for loop, I am not sure how to translate this into the form mentioned on Equivalent for expression in dolfinx since here the functions are typed by hand. A minimal example of how this would look like is as follows:
import dolfinx as dnx
import multiprocessing as mp
from math import floor, ceil
default_parameters = {
'num_samples': 1,
'basis_fct': 'mixed_trigonometric',
'mu': 1, # shift hyper-parameter
'mode': 'x', # only required for cookies
'sigma': 1, # only required for trigonometric polynomials
'num_basis': 2, # actual number of basis functions may vary
'finite_element': 'P', # see http://femtable.org/
'inter_deg': 1, # degree of interpolation
'mesh_size': 10, # number of edges in the mesh (number of nodes: edges + 1)
'right_hand_side': '20+10*x[0]-5*x[1]',
'folder_name': 'some_dataset', # folder where data is saved
'part': 1,
'part_max': 1
# create mesh and function space
msh = dnx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
f = 20+10*x[0]-5*x[1]
V = dnx.fem.functionspace(msh, ('P', 1))
facets = dnx.mesh.locate_entities_boundary( msh,
dim=1,
marker=lambda x: np.isclose(x[0], 0.0)
| np.isclose(x[0], 1.0)
| np.isclose(x[1], 0.0)
| np.isclose(x[1], 1.0),
dofs = dnx.fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = dnx.fem.dirichletbc(value=ScalarType(0), dofs=dofs, V=V)
bcs = [bc]
'''Generate list of expressions and array of coefficients in polynomial basis (T1)'''
num_terms = p
expr_list = []
template_sin = "sin({}*pi*x[0])*sin({}*pi*x[1])"
for i in range(n):
temp = str(mu)
for j in range(1, num_terms+1):
a = template_a.format(j**(sigma), str(coeff[i, j-1]), sin)
temp += a
expr_list, coeff = trigonometric_basis(5,2,1)
for expr in expr_list:
uh = dnx.fem.Function(V)
a(expr) = ...
a_bilinear = a(expr)*ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
problem = LinearProblem(a_bilinear, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
Could someone please show me how to write this? I am new in fenicsx and I can’t find any similar problems. It might be an easy question but I have no idea how to do this, any help would be greatly appreciated!
Best,
Daan
