Hi everyone,
I’m trying to create a UFL Expression object (in FEniCS 2019.1.0) to represent the following function
\phi(x,y) =\begin{cases}
\frac{1}{h^2}\biggl(1 - \frac{|x-x_0|}{h}\biggr)\biggl(1 - \frac{|y-y_0|}{h} \biggr), \quad \max(|x-x_0|,|y-y_0|) \le h
0, \quad \mathrm{else},
\end{cases}
using the code below:
mesh = UnitSquareMesh(20, 20)
h=1/20
x0 = 0.5
y0 = 0.5
g = Expression('(abs(x[0] -x0)< h ) & abs(x[1]-y0) < h'\
+' ? 1/pow(h,2)*(1 - abs(x[0]-x0)/h)*(1-abs(x[1]-y)/h): 0',degree=2,x0 =x0,y0=y0,h=h )
g = interpolate(g, V)
plot(g, title='g')
However, when I run this I keep getting the error message
Any suggestions?
