AttributeError when using dolfinx.fem.petsc.LinearProblem
Hi! I am new to FEniCSx and before jumping into my more complex real problem, I was using a toy model when I run into an error using one of the solvers. I am using the version fenics-dolfinx 0.9.0 and fenics-ufl 2024.2.0 and I installed them using conda-forge on my macOS Ventura13.1 (chip M1). My code is the following:
import pygmsh
import dolfinx.fem.petsc
from ufl import TestFunction, TrialFunction, interpolate, dx, grad, inner
# %% Create mesh
# Generate the spherical surface mesh with pygmsh
with pygmsh.geo.Geometry() as geom:
    radius = 1.0  # Radius of the sphere
    # Add a sphere with a smaller mesh size for higher point density
    sphere = geom.add_ball([0, 0, 0], radius, mesh_size=0.05)  # Smaller mesh_size -> more points
    mesh = geom.generate_mesh(dim=2)  # Generate 2D surface mesh
# Filter out mixed cells and retain only triangles
triangle_cells = mesh.cells_dict["triangle"]
mesh = meshio.Mesh(
    points=mesh.points,
# Save the filtered mesh in XDMF format
meshio.write("SphericalSurfaceMesh.xdmf", mesh)
# %% Load the mesh and integrate the system
# Load the filtered mesh into FEniCSx
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "SphericalSurfaceMesh.xdmf", "r") as infile:
    fenics_mesh = infile.read_mesh(name="Grid")
cell_radius = 75
Du = dolfinx.fem.Constant(fenics_mesh, 0.08/(cell_radius**2))
coordinates = fenics_mesh.geometry.x  # Nodal coordinates
x, y, z = coordinates[:, 0], coordinates[:, 1], coordinates[:, 2]
# Define the function space for the scalar field u
V = dolfinx.fem.functionspace(fenics_mesh, ("CG", 1))
v_test_u = TestFunction(V)
# Define the bilinear and linear forms
a_u = Du*inner(grad(u), grad(v_test_u))*dx
A_u = dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(a_u))
# Update RHS using the current values of u, v, w
f_u = 1.
L_u = dolfinx.fem.assemble_vector(dolfinx.fem.form(inner(f_u, v_test_u)*dx))
problem_u = dolfinx.fem.petsc.LinearProblem(A_u, L_u, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
# Solve
uh = problem_u.solve()
The error I run to is the following:
File ~/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/spyder_kernels/customize/utils.py:209, in exec_encapsulate_locals(code_ast, globals, locals, exec_fun, filename)
    207     if filename is None:
    208         filename = "<stdin>"
--> 209     exec_fun(compile(code_ast, filename, "exec"), globals, None)
    210 finally:
    211     if use_locals_hack:
    212         # Cleanup code
File ~/Desktop/FEMSphere_v3.py:56
     53 f_u = 1.
     54 L_u = dolfinx.fem.assemble_vector(dolfinx.fem.form(inner(f_u, v_test_u)*dx))
---> 56 problem_u = dolfinx.fem.petsc.LinearProblem(A_u, L_u, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
     58 # Solve
     59 uh = problem_u.solve()
File ~/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/petsc.py:788, in LinearProblem.__init__(self, a, L, bcs, u, petsc_options, form_compiler_options, jit_options)
    754 """Initialize solver for a linear variational problem.
    755
    756 Args:
    780        "mumps"})
    781 """
    782 self._a = _create_form(
    783     a,
    784     dtype=PETSc.ScalarType,
    785     form_compiler_options=form_compiler_options,
    786     jit_options=jit_options,
    787 )
--> 788 self._A = create_matrix(self._a)
    789 self._L = _create_form(
    790     L,
    791     dtype=PETSc.ScalarType,
    792     form_compiler_options=form_compiler_options,
    793     jit_options=jit_options,
    794 )
    795 self._b = create_vector(self._L)
File ~/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/petsc.py:176, in create_matrix(a, mat_type)
    160 """Create a PETSc matrix that is compatible with a bilinear form.
    161
    162 Note:
    173     A PETSc matrix with a layout that is compatible with ``a``.
    174 """
    175 if mat_type is None:
--> 176     return _cpp.fem.petsc.create_matrix(a._cpp_object)
    177 else:
    178     return _cpp.fem.petsc.create_matrix(a._cpp_object, mat_type)
AttributeError: 'petsc4py.PETSc.Mat' object has no attribute '_cpp_object'
I’ve tried to use some other objects such as CSR Matrices, but seems that the only objects that the solver can use is ‘petsc4py.PETSc.Mat’. I did not see this question posted anywhere, so I thought on asking myself.
LinearProblem does not accept pre-assembled matrices/vectors.
You should just send in
and
