Hello
I am solving a hyperelasticity problem. For the sake of speed, I want to use the TSFC compiler. I am getting an error after including ds when I want to apply a load on the right boundary. Here is the code:
parameters["form_compiler"]["representation"] = "tsfc"
# Define boundary
class Left(SubDomain):
return abs(x[0] - 0.0) < DOLFIN_EPS and on_boundary
class Right(SubDomain):
return abs(x[0] - 1.0) < DOLFIN_EPS and on_boundary
mesh = UnitCubeMesh.create(1,1,1,CellType.Type.hexahedron)
V = VectorFunctionSpace(mesh, 'CG', degree=1)
left = Left()
right = Right()
du = TrialFunction(V)
boundaries = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
subdomains = MeshFunction('size_t', mesh, mesh.topology().dim())
boundaries.set_all(0)
left.mark(boundaries, 1)
right.mark(boundaries, 2)
dx = Measure('dx', domain=mesh, subdomain_data=subdomains, metadata={'quadrature_degree': 2})
ds = Measure('ds', domain=mesh, subdomain_data=boundaries, metadata={'quadrature_degree': 2})
d = u.geometric_dimension()
I = Identity(d)
F = I + grad(u)
C = F.T*F
Ic = tr(C)
J = det(F)
mu = 20
K = 1E6
force = Constant((0.1, 0.0, 0.0))
psi = (mu* (Ic - 3.) ) * dx + 0.5 * K * pow(ln(J),2) * dx - dot(force, u)*ds(2)
F1 = derivative(psi, u, v)
# Compute Jacobian of F
Jac = derivative(F1, u, du)
bc_left = DirichletBC(V, Constant((0,0,0)), boundaries , 1)
problem = NonlinearVariationalProblem(F1, u, bc_left, Jac)
solver.solve()
The above code fails with “AssertionError”. If I comment out the second line (parameters["form_compiler"]["representation"] = "tsfc") it works. It also works if I keep the “tsfc” and replace ds(2) with for example dx but I want to use the “tsfc” and keeping "ds(2) simultaneously.
Does anybody know where the problem is?
