Two subdomains with different equations
I want to solve two diffusion equations time dependently. c1 is solved for both subdomains, and c2 is solved for one subdomain. My problem is how to define initial condition for c2 just for its subdomain, and solve c2 for that subdomain?
this is the code I tried to do it:
mesh = UnitSquareMesh(32, 32)
subdomains = MeshFunction("size_t", mesh, mesh.topology().dim())
subdomain_1 = CompiledSubDomain("x[0] < 0.5")
subdomain_2 = CompiledSubDomain("x[0] >= 0.5")
subdomains.set_all(0)
subdomain_1.mark(subdomains, 1)
subdomain_2.mark(subdomains, 2)
c1_initial = Expression("1", degree=1)
c2_initial = Expression("0", degree=1)
c1 = interpolate(c1_initial, V)
c2 = interpolate(c2_initial, V)
D1 = Constant(1.0)
D2 = Constant(0.5)
c1_trial = TrialFunction(V)
c1_test = TestFunction(V)
c2_trial = TrialFunction(V)
c2_test = TestFunction(V)
c1_diffusion = D1 * dot(grad(c1_trial), grad(c1_test)) * dx
c1_rhs = Constant(0) * c1_test * dx + c2_trial * c1_test * dx(2)
c1_problem = LinearVariationalProblem(c1_diffusion, c1_rhs, c1)
c2_diffusion = D2 * dot(grad(c2_trial), grad(c2_test)) * dx(2)
c2_rhs = Constant(0) * c2_test * dx(2)
c2_problem = LinearVariationalProblem(c2_diffusion, c2_rhs, c2)
t = 0.0
dt = 0.01
num_steps = 100
c1_solver = LinearVariationalSolver(c1_problem)
c2_solver = LinearVariationalSolver(c2_problem)
for step in range(num_steps):
    c1_solver.bcs = [DirichletBC(V, c1_initial, subdomains, 1)]
    c1_solver.solve()
    c2_solver.bcs = [DirichletBC(V, c2_initial, subdomains, 2)]
    c2_solver.solve()
This is the error:
Blockquote
raise ArityMismatch(“Adding expressions with non-matching form arguments {0} vs {1}.”.format(_afmt(a), _afmt(b)))
ArityMismatch: Adding expressions with non-matching form arguments (‘v_0’, ‘v_1’) vs (‘v_0’,).
See: https://dl.acm.org/doi/abs/10.1145/3471138
or
GitHub - multiphenics/multiphenics: multiphenics - easy prototyping of multiphysics problems in FEniCS
or
GitHub - MiroK/fenics_ii
Thanks dokken.
As I understand it needs MeshView which is not available in FEniCS.
Apart from installing MeshView on Docker, is MeshView available on FEniCSx or not?
Only the following
uses meshview, which is available in the docker image:
The two other resources does not rely on meshview
You are here asking about FEniCSx, while your code is in legacy FEniCS.
is the reimplementation of multiphenics in FEniCSx.
Meshviews/submeshes are under development in DOLFINx
