I want to implement a time-dependent problem where different time step sizes are used in subdomains. I use FEniCSx 0.4.1 but an update to the latest version would be no problem.
To illustrate what I want to achieve, consider the given picture:
I have a domain consisting of two subdomains. I know that due to material parameters the solution in subdomain 1 changes more within a certain period of time than in subdomain 2 (which can be considered constant within that time period). Therefore, I want to only calculate the solution in subdomain 1 for N time steps, update subdomain 2 after N time steps, and repeat. To implement this approach, I need a way to somehow fixate the solution in subdomain 2 or apply a known solution.
While searching for similar problems, I encountered this: Integrating on subdomain. But all answers there and for similar questions are given for legacy FEniCS and I struggle to apply them to FEniCSx.
As a simple model problem, I modified the heat equation form the tutorial. Now 2 different materials are used and only subdomain 1 should be calculated. The entire code is given at the end.
I came up with the following idea (assuming the subdomains are marked as 1 and 2):
a = u * v * dx(1) + dt*ufl.dot(ufl.grad(u), ufl.grad(v)) * dx(1)
L = (u_n + dt * f) * v * dx(1)
a += u_known * dx(2)
L += u_known * dx(2)
Where I try to use a known solution in subdomain 2. Obviously the last two lines are wrong. My questions are: How can I apply a known solution in subdomain 2? Is there a different approach that I should use? Is what I’m trying to do even possible in FEniCSx?
Thank you in advance!
from dolfinx import fem, mesh, io, plot
# Define temporal parameters
t = 0 # Start time
T = 2.0 # Final time
num_steps = 61
# Define mesh
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])], [nx, ny], mesh.CellType.triangle)
Q = fem.FunctionSpace(domain, ("DG", 0))
def Omega_1(x):
return x[1] >= 0.0
def Omega_2(x):
return x[1] <= 0.0
kappa = fem.Function(Q)
cells_1 = mesh.locate_entities(domain, domain.topology.dim, Omega_1)
cells_2 = mesh.locate_entities(domain, domain.topology.dim, Omega_2)
kappa.x.array[cells_1] = np.full_like(cells_1, 1, dtype=ScalarType)
kappa.x.array[cells_2] = np.full_like(cells_2, 0.01, dtype=ScalarType)
# Create initial condition
def initial_condition(x, a=5):
return np.exp(-a*(x[0]**2+x[1]**2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
# Create boundary condition
boundary_facets = mesh.locate_entities_boundary(
domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V)
xdmf = io.XDMFFile(domain.comm, "output.xdmf", "w")
xdmf.write_mesh(domain)
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
xdmf.write_function(uh, t)
f = fem.Constant(domain, PETSc.ScalarType(0))
# The following two lines of code need to be changed in a way that
# only subdomain 1 is calculated and subdomain 2 remains unchanged.
a = u * v * ufl.dx + dt*kappa*ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = (u_n + dt * f) * v * ufl.dx
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = fem.petsc.assemble_matrix(bilinear_form, bcs=[bc])
b = fem.petsc.create_vector(linear_form)
solver.setOperators(A)
for i in range(num_steps):
with b.localForm() as loc_b:
loc_b.set(0)
fem.petsc.assemble_vector(b, linear_form)
fem.petsc.apply_lifting(b, [bilinear_form], [[bc]])
fem.petsc.set_bc(b, [bc])
# Solve linear problem
solver.solve(b, uh.vector)
uh.x.scatter_forward()
u_n.x.array[:] = uh.x.array
# Write solution to file
xdmf.close()
