Ufl.conditional doesn't return precise results when using ('CG', 1)
Hello everyone,
I am working on a non-local plasticity example. For the obtained solution of the plasticity I need to define a irreversability constraint, where the previous solution is supposed to be the lower threshhold (here an simple function called x0_func). This also called ad-hoc condition. That means at time n+1, we have:
alpha_n+1 > alpha_n
In order to realize that I am using ufl.conditional. When I define the function in the space of (‘DG’, 0), I get really good results. However, this is not the case when the functions are defined in (‘CG’, 1).
The code and the outputs are as follows:
from dolfinx import mesh
from dolfinx.fem import (Function, FunctionSpace)
import ufl as ufl
L = 100.0
H = 100.0
dL = 30
dH = 30
domain = mesh.create_box(MPI.COMM_WORLD,[[0,0,0], [L, L, H]], [dL, dL, dH], mesh.CellType.tetrahedron)
# For plasticity problem
V_pl = FunctionSpace(domain, ('CG', 1))
#V_pl = FunctionSpace(domain, ('DG', 0)) #precise
pl = Function(V_pl)
with pl.vector.localForm() as pl_loc:
    pl_loc.set(-1.0)
x0_func = Function(V_pl)
x0_ufl = x[0]
x0 = lambda x: eval(str(x0_ufl))
x0_func.interpolate(x0)
print("min of x0_func:", min(x0_func.vector.array), flush=True)
with XDMFFile(MPI.COMM_WORLD,  "test.xdmf", "w") as xdmf:#, encoding=XDMFFile.Encoding.HDF5) #FIXME
    xdmf.write_mesh(domain)
    xdmf.write_function(x0_func)
def project(v, target_func, bcs=[]):
    # Ensure we have a mesh and attach to measure
    V = target_func.function_space
    dx = ufl.dx(V.mesh)
    # Define variational problem for projection
    w = ufl.TestFunction(V)
    Pv = ufl.TrialFunction(V)
    a = dolfinx.fem.form(ufl.inner(Pv, w) * dx)
    L = dolfinx.fem.form(ufl.inner(v, w) * dx)
    # Assemble linear system
    A = dolfinx.fem.petsc.assemble_matrix(a, bcs)
    b = dolfinx.fem.petsc.assemble_vector(L)
    dolfinx.fem.petsc.apply_lifting(b, [a], [bcs])
    dolfinx.fem.petsc.set_bc(b, bcs)
    # Solve linear system
    solver = PETSc.KSP().create(A.getComm())
    solver.setOperators(A)
    solver.solve(b, target_func.vector)
def Pl_max(pl_, pln_):
    return ufl.conditional(ufl.gt(pl_, pln_), pl_, pln_)
project(Pl_max(pl, x0_func), pl)
print("min of plasticity:", min(pl.vector.array), flush=True)
Output for V_pl = FunctionSpace(domain, (‘CG’, 1))
min of x0_func: -5.244705219161143e-17
min of plasticity: -2.950809850125471e-05
Output for V_pl = FunctionSpace(domain, (‘DG’, 0))
min of x0_func: 0.8333333333333334
min of plasticity: 0.8333333333334109
Thank you
I’m not really sure what you are expecting here.
You have set the minimum bound og pl to -1, thus your condition states that x0_func is always greater than than pl, and thus the resulting plasticity will always be equal to x0_func.
Let’s consider why you get different results for x0.
Any degree of freedom in a DG 0 space is placed in the cell center, while the dofs in CG-1 is placed at the vertices. We can then look at what point x0 is at its smallest:
import ufl as ufl
def compute_x0(V_pl):
    domain = V_pl.mesh
    x0_ufl = x[0]
    def x0(x): return eval(str(x0_ufl))
    return x0_func
L = 100.0
H = 100.0
dL = 30
dH = 30
domain = mesh.create_box(MPI.COMM_WORLD, [[0, 0, 0], [L, L, H]], [
V_CG = FunctionSpace(domain, ('CG', 1))
x0 = compute_x0(V_CG)
coord_CG = V_CG.tabulate_dof_coordinates()
pos = np.argmin(x0.x.array)
print(coord_CG[pos], x0.x.array[pos])
with XDMFFile(domain.comm, "CG.xdmf", "w") as xdmf:
    xdmf.write_function(x0)
V_DG = FunctionSpace(domain, ('DG', 0))  # precise
x0_dg = compute_x0(V_DG)
coord_DG = V_DG.tabulate_dof_coordinates()
pos = np.argmin(x0_dg.x.array)
print(coord_DG[pos], x0_dg.x.array[pos])
with XDMFFile(domain.comm, "DG.xdmf", "w") as xdmf:
    xdmf.write_function(x0_dg)
which gives you
[0.00000000e+00 1.85037171e-16 1.85037171e-16] 0.0
[0.83333333 2.5        1.66666667] 0.8333333333333334
i.e. the CG 1 function is smallest at [0,0,0]
while DG 0 is smallest at [0.83,2.5,1.6667]
If you look at all the dof coordinates, you can check that the smallest x-value for each spaces is:
print(min(coord_CG[:,0]))
print(min(coord_DG[:,0]))
giving
0.0
0.8333333333333334
Thank you very much for this explanation. That would have been my next question
By setting pl to -1, I wanted to force the plasticity to be equal to x0_func so that I could test the accuracy of the ad-hoc condition by comparing pl and x0_func.
I found that the lowest values of pl and x0_func were much closer in DG-0 than in CG-1. I wondered why this was. I’m sorry if I didn’t make myself clear.
What happens in my full simulation is that I get a negative plasticity of up to -4e-3. This should not be possible because of the ad-hoc condition and the initial values (pl_n set to 0). However, when I describe the functions in DG-0, I get a minimum plasticity value of 0, as expected.
Thanks a lot!
Without having an actual example of this behavior at hand, I cannot really give you any pointers.
You need to think about what project and interpolate does, and how they are affected by using a ufl.conditional. If you do a projection with a ufl-conditional, the condition is evalutated at a quadrature point when assembled into the RHS. This is different from what happens in an interpolation, where you would only evaluate the condition at a dof coordinate/interpolation point.
Thank you! I just tested your suggestion on my full simulation and it works like a charm.
For future readers, the now working example:
from dolfinx.fem import (Expression, Function, FunctionSpace)
import ufl as ufl
L = 100.0
H = 100.0
dL = 30
dH = 30
pl = Function(V_pl)
    pl_loc.set(-1.0)
x0_ufl = x[0]
expr = Expression(Pl_max(pl, x0_func), V_pl.element.interpolation_points)
pl.interpolate(expr)
min of plasticity: -5.244705219161143e-17
min of plasticity: 0.8333333333333334
Have a nice day!
