Dear all, for my code d and e are constant. I want to store the value of d and e as pvd file. but while running it shows, “RuntimeError: Unable to cast Python instance to C++ type (compile in debug mode for details)”. How can i get rid out of it?
from fenics_adjoint import *
rho = Constant(500.0)
C= Constant(20.0)
dt=1
num_steps=10
mesh = RectangleMesh(Point(0,0),Point(1,1), 10, 10)
x=SpatialCoordinate(mesh)
M = FunctionSpace(mesh,"CG",1)
u = Function(V, name="State")
Q_heat = 20000.0
Q = Constant(0.0)
g = Expression('Q_heat', degree=1, Q_heat=Constant(Q_heat))
#Define boudary conditions
u_0 = Constant(0.0)
u0=interpolate(u_0, V)
#Define Left Boundary
def left_boundary( x, on_boundary):
return on_boundary and (abs(x[0])< DOLFIN_EPS)
bc= DirichletBC(V, Constant(0.0), left_boundary)
# Define right bounday
class right(SubDomain):
return on_boundary and ((abs(x[0] - 1.) < DOLFIN_EPS))
vertical = right()
tdim = mesh.topology().dim()
boundaries = MeshFunction('size_t', mesh, tdim-1)
boundaries.set_all(0)
vertical.mark(boundaries, 1)
dsB = Measure("ds", subdomain_id=1, subdomain_data=boundaries)
d_target=Constant(20.0)
e_target=Constant(100.0)
def forward(d, e):
u0 = Function(V, name="State")
#Define Thermal conductivity
def k():
return d + e*x[1]
a= rho*C*u*v*dx+ dt*inner(grad(v),k()*grad(u))*dx
L= dt*g*v*dsB+rho*C*inner(u0,v)*dx+dt*Q*v*dx
t = 0
for n in range (num_steps):
#Compute solution
solve(a==L, u, bc)
plot(u)
#update solution
u0.assign(u)
return u,d,e
[u_target, d_target_1, e_target_1] = forward(d_target, e_target)
File("forward/target_d_modified.pvd") << d_target_1
File("forward/target_e_up.pvd") << e_target_1
