I’m running fenics 2019.1.0 with singularity 3.6.0. I’ve successfully run the physics simulation and am just trying to get the data on the boundary. The script I have to do this works fine with the coarser meshes, but when I attempt it with the finer mesh, I get the following error:
Process 14: *** Warning: Mesh is empty, unable to create entities of dimension 0.
Process 14: Number mesh entities for distributed mesh (for specified vertex ids).
File "extract_surfaces.py", line 38, in <module>
Vb = VectorFunctionSpace(surface,'P',1)
File "/usr/local/lib/python3.6/dist-packages/dolfin/function/functionspace.py", line 222, in VectorF
unctionSpace
return FunctionSpace(mesh, element, constrained_domain=constrained_domain)
File "/usr/local/lib/python3.6/dist-packages/dolfin/function/functionspace.py", line 31, in __init__
self._init_from_ufl(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/dolfin/function/functionspace.py", line 50, in _init_from_ufl
dolfin_dofmap = cpp.fem.DofMap(ufc_dofmap, mesh)
RuntimeError:
*** Error: Unable to number mesh entities.
*** Reason: Global vertex indices exist at input. Cannot be renumbered.
*** Where: This error was encountered inside MeshPartitioning.cpp.
*** Process: 14
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
This is the script that I have:
# Environment setup
import os
# FEniCS imports
import numpy
# Define communicator and rank for this process, in case we are running with MPI
mpi_comm = MPI.comm_world
mpi_rank = mpi_comm.Get_rank()
PROGRESS = 16
TRACE = 13
DBG = 10
set_log_level(PROGRESS)
mesh = Mesh(mpi_comm)
with XDMFFile(mpi_comm, "mesh.xdmf") as infile:
infile.read(mesh)
# Read boundaries
surface = BoundaryMesh(mesh,"exterior")
# Try reading checkpoint
V = VectorFunctionSpace(mesh,'P',1)
ub = Function(Vb)
xdmf_vol = XDMFFile(mpi_comm, "displacement.xdmf")
xdmf_sur = XDMFFile(mpi_comm, "displacement_surf.xdmf")
for i in range(0,5):
xdmf_vol.read_checkpoint(u, "u", i)
ub = interpolate(u,Vb)
ub.rename("ub", "displacement")
#xdmf_sur.write(ub,i)
if i < 1:
xdmf_sur.write_checkpoint(ub,"ub",i,XDMFFile.Encoding.HDF5,False)
xdmf_sur.write_checkpoint(ub,"ub",i,XDMFFile.Encoding.HDF5,True)
Seeing as the script works for the coarser meshes, I’m not sure what to do. Would there be any workarounds for this? Thanks!
