Unable to import extruded geometry mesh
I am considering a 3D geometry which is created by extruding a 2D one. The mesh by design should be a 2D one but extruded to 3D (prism element). However, it seems to be running into problem with conversion to dolfinx mesh. Below is an MWE that reproduces my problem. I would appreciate if someone could clarify my mistake. I use the conda build of dolfinx 0.9
import gmsh, mpi4py
from dolfinx.io import gmshio
gmsh.finalize()
gmsh.option.setNumber("General.Terminal", 0) # disable output messages
occ = gmsh.model.occ
gdim = 2
rect1 = occ.addRectangle(0, 0, 0, 1, 1)
extruded = occ.extrude(
    [(gdim, rect1)],
    0, 0, 1,  # extrusion vector
    numElements=[1],  # only one element in extrusion direction
    recombine=True
occ.synchronize()
# add_sub physical tags
all_doms = occ.getEntities(gdim+1)
for j, dom in enumerate(all_doms):
    gmsh.model.addPhysicalGroup(dom[0], [dom[1]], j + 1)  # create the main group/node
# number all boundaries
all_edges = gmsh.model.getEntities(gdim)
for j, edge in enumerate(all_edges):
    gmsh.model.addPhysicalGroup(edge[0], [edge[1]], edge[1])  # create the main group/node
gmsh.model.mesh.generate(gdim+1)
mpi_rank = 0
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, mpi_rank, gdim+1)
The gmshio does currently not support prism elements, as there is no clear API in DOLFINx for reading facet tags.
Here is a modified version of the gmshio that can read the mesh and cell tags:
import gmsh, mpi4py
try:
except ImportError:
    from dolfinx.io import gmsh as gmshio
from dolfinx import default_real_type
import numpy.typing as npt
import basix.ufl
# Map from Gmsh cell type identifier (integer) to DOLFINx cell type and
# degree https://gmsh.info//doc/texinfo/gmsh.html#MSH-file-format
_gmsh_to_cells = {
    1: ("interval", 1),
    2: ("triangle", 1),
    3: ("quadrilateral", 1),
    4: ("tetrahedron", 1),
    5: ("hexahedron", 1),
    6: ("prism", 1),
    8: ("interval", 2),
    9: ("triangle", 2),
    10: ("quadrilateral", 2),
    11: ("tetrahedron", 2),
    12: ("hexahedron", 2),
    15: ("point", 0),
    21: ("triangle", 3),
    26: ("interval", 3),
    29: ("tetrahedron", 3),
    36: ("quadrilateral", 3),
    92: ("hexahedron", 3),
def ufl_mesh(gmsh_cell: int, gdim: int, dtype: npt.DTypeLike) -> ufl.Mesh:
    """Create a UFL mesh from a Gmsh cell identifier and geometric
    dimension.
    See https://gmsh.info//doc/texinfo/gmsh.html#MSH-file-format.
    Args:
        gmsh_cell: Gmsh cell identifier.
        gdim: Geometric dimension of the mesh.
    Returns:
        UFL Mesh using Lagrange elements (equispaced) of the
        corresponding DOLFINx cell.
    try:
        shape, degree = _gmsh_to_cells[gmsh_cell]
    except KeyError as e:
        print(f"Unknown cell type {gmsh_cell}.")
        raise e
    cell = ufl.Cell(shape)
    element = basix.ufl.element(
        basix.ElementFamily.P,
        cell.cellname(),
        degree,
        basix.LagrangeVariant.equispaced,
        shape=(gdim,),
        dtype=dtype,  # type: ignore[arg-type]
    return ufl.Mesh(element)
def model_to_mesh(
    model,
    comm,
    rank: int,
    gdim: int = 3,
    partitioner = None,
    dtype=default_real_type,
) -> tuple[dolfinx.mesh.Mesh, dolfinx.mesh.MeshTags]:
    """Create a Mesh from a Gmsh model.
    Creates a :class:`dolfinx.mesh.Mesh` from the physical entities of
    the highest topological dimension in the Gmsh model. In parallel,
    the gmsh model is processed on one MPI rank, and the
    :class:`dolfinx.mesh.Mesh` is distributed across ranks.
    Args:
        model: Gmsh model.
        comm: MPI communicator to use for mesh creation.
        rank: MPI rank that the Gmsh model is initialized on.
        gdim: Geometrical dimension of the mesh.
        partitioner: Function that computes the parallel
            distribution of cells across MPI ranks.
    Returns:
        MeshData with mesh and tags of corresponding entities by
        codimension. Codimension 0 is the cell tags, codimension 1 is the
        facet tags, codimension 2 is the ridge tags and codimension 3 is
        the peak tags as well as a lookup table from the physical groups by
        name to integer.
    Note:
        For performance, this function should only be called once for
        large problems. For reuse, it is recommended to save the mesh
        and corresponding tags using :class:`dolfinx.io.XDMFFile` after
        creation for efficient access.
    valid_mesh = None
    if comm.rank == rank:
        assert model is not None, "Gmsh model is None on rank responsible for mesh creation."
        # Get mesh geometry and mesh topology for each element
        x = gmshio.extract_geometry(model)
        try:
            topologies, physical_groups = gmshio.extract_topology_and_markers(model)
            valid_mesh = len(physical_groups) > 0
        except ValueError as e:
            topologies = gmshio.extract_topology_and_markers(model)
        # Extract Gmsh entity (cell) id, topological dimension and number
        # of nodes which is used to create an appropriate coordinate
        # element, and seperate higher topological entities from lower
        # topological entities (e.g. facets, ridges and peaks).
        num_unique_entities = len(topologies.keys())
        element_ids = np.zeros(num_unique_entities, dtype=np.int32)
        entity_tdim = np.zeros(num_unique_entities, dtype=np.int32)
        num_nodes_per_element = np.zeros(num_unique_entities, dtype=np.int32)
        for i, element in enumerate(topologies.keys()):
            _, dim, _, num_nodes, _, _ = model.mesh.getElementProperties(element)
            element_ids[i] = element
            entity_tdim[i] = dim
            num_nodes_per_element[i] = num_nodes
        # Broadcast information to all other ranks
        entity_tdim, element_ids, num_nodes_per_element = comm.bcast(
            (entity_tdim, element_ids, num_nodes_per_element), root=rank
        entity_tdim, element_ids, num_nodes_per_element = comm.bcast((None, None, None), root=rank)
    valid_mesh = comm.bcast(valid_mesh, root=rank)
    if not valid_mesh:
        raise RuntimeError("No 'physical groups' in gmsh mesh. Cannot continue.")
    # Sort elements by descending dimension
    perm_sort = np.argsort(entity_tdim)[::-1]
    if len(perm_sort) > 1:
        assert entity_tdim[perm_sort[0]] != entity_tdim[perm_sort[1]]
    # Extract position of the highest topological entity and its
    # topological dimension
    cell_position = perm_sort[0]
    tdim = int(entity_tdim[cell_position])
    # Check that all cells are tagged once
    error_msg = ""
        _elementTypes, _elementTags, _nodeTags = model.mesh.getElements(dim=tdim, tag=-1)
        _elementType_dim = _elementTypes[0]
        if _elementType_dim not in topologies.keys():
            error_msg = "All cells are expected to be tagged once; none found"
        num_cells_tagged = len(topologies[_elementType_dim]["entity_tags"])
        if (num_cells := len(_elementTags[0])) != num_cells_tagged:
            error_msg = (
                "All cells are expected to be tagged once;"
                + f"found: {num_cells_tagged}, expected: {num_cells}"
        num_cells_tagged_once = len(np.unique(topologies[_elementType_dim]["entity_tags"]))
        if num_cells_tagged != num_cells_tagged_once:
            error_msg = "All cells are expected to be tagged once, found duplicates"
    error_msg = comm.bcast(error_msg, root=rank)
    if error_msg != "":
        raise RuntimeError(error_msg)
    # Extract entity -> node connectivity for all cells and sub-entities
    # marked in the GMSH model
    meshtags: dict[int, tuple[npt.NDArray[np.int64], npt.NDArray[np.int32]]] = {}
    for position in perm_sort:
        codim = tdim - entity_tdim[position]
            gmsh_entity_id = element_ids[position]
            marked_entities = np.asarray(topologies[gmsh_entity_id]["topology"], dtype=np.int64)
            entity_values = np.asarray(topologies[gmsh_entity_id]["cell_data"], dtype=np.int32)
            meshtags[codim] = (marked_entities, entity_values)
            # Any other process than input rank does not have any entities
            marked_entities = np.empty((0, num_nodes_per_element[position]), dtype=np.int32)
            entity_values = np.empty((0,), dtype=np.int32)
    # Create a UFL Mesh object for the GMSH element with the highest
    ufl_domain = ufl_mesh(element_ids[cell_position], gdim, dtype=dtype)
    # Get cell->node connectivity and  permute to FEniCS ordering
    num_nodes = num_nodes_per_element[cell_position]
    gmsh_cell_perm = gmshio.cell_perm_array(dolfinx.cpp.mesh.to_type(str(ufl_domain.ufl_cell())), num_nodes)
    cell_connectivity = meshtags[0][0][:, gmsh_cell_perm].copy()
    # Create a distributed mesh, where mesh nodes are only destributed from
    # the input rank
    if comm.rank != rank:
        x = np.empty([0, gdim], dtype=dtype)  # No nodes on other than root rank
    mesh = dolfinx.mesh.create_mesh(
        comm, cell_connectivity, ufl_domain, x[:, :gdim].astype(dtype, copy=False), partitioner
    assert tdim == mesh.topology.dim, (
        f"{mesh.topology.dim=} does not match Gmsh model dimension {tdim}"
    # Create MeshTags for all sub entities
    topology = mesh.topology
    codim_to_name = {0: "cell", 1: "facet", 2: "ridge", 3: "peak"}
    dolfinx_meshtags: dict[str, dolfinx.mesh.MeshTags | None] = {}
    for codim in [0]:
        key = f"{codim_to_name[codim]}_tags"
        if (
            codim == 1 and topology.cell_type == dolfinx.mesh.CellType.prism
        ) or topology.cell_type == dolfinx.mesh.CellType.pyramid:
            raise RuntimeError(f"Unsupported facet tag for type {topology.cell_type}")
        meshtag_data = meshtags.get(codim, None)
        if meshtag_data is None:
            dolfinx_meshtags[key] = None
            continue
        # Distribute entity data [[e0_v0, e0_v1, ...], [e1_v0, e1_v1, ...],
        # ...] which is made in global input indices to local indices on
        # the owning process
        (marked_entities, entity_values) = meshtag_data
        local_entities, local_values = dolfinx.io.distribute_entity_data(
            mesh, tdim - codim, marked_entities, entity_values
        # Create MeshTags object from the local entities
        mesh.topology.create_connectivity(tdim - codim, tdim)
        adj = dolfinx.graph.adjacencylist(local_entities)
        et = dolfinx.mesh.meshtags_from_entities(
            mesh, tdim - codim, adj, local_values.astype(np.int32, copy=False)
        et.name = key
        return mesh, et
gdim = 2
    [(gdim, rect1)],
    recombine=True
occ.synchronize()
mpi_rank = 0
mesh, ct = model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, mpi_rank, gdim+1)
with dolfinx.io.XDMFFile(mpi4py.MPI.COMM_WORLD, "mwe.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_meshtags(ct, mesh.geometry)
Thanks a lot Jorgen for detailed feedback!
I ran your code locally (conda 0.9.0) and got the following error:
Cell In[7], line 271
    268 gmsh.model.mesh.generate(gdim+1)
    270 mpi_rank = 0
--> 271 mesh, ct = model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, mpi_rank, gdim+1)
    274 # with dolfinx.io.XDMFFile(mpi4py.MPI.COMM_WORLD, "mwe.xdmf", "w") as xdmf:
    275 #     xdmf.write_mesh(mesh)
    276 #     xdmf.write_meshtags(ct, mesh.geometry)
Cell In[7], line 139
    137 valid_mesh = comm.bcast(valid_mesh, root=rank)
    138 if not valid_mesh:
--> 139     raise RuntimeError("No 'physical groups' in gmsh mesh. Cannot continue.")
    141 # Sort elements by descending dimension
    142 perm_sort = np.argsort(entity_tdim)[::-1]
RuntimeError: No 'physical groups' in gmsh mesh. Cannot continue.
Any thoughts on what could be amiss?
Sorry, was a bit too quick with backporting this to stable, here is a working version:
import gmsh, mpi4py
try:
except ImportError:
import basix.ufl
_gmsh_to_cells = {
    1: ("interval", 1),
    2: ("triangle", 1),
    6: ("prism", 1),
    8: ("interval", 2),
    9: ("triangle", 2),
    15: ("point", 0),
    dimension.
    Args:
    Returns:
    try:
        raise e
        cell.cellname(),
        degree,
        shape=(gdim,),
def model_to_mesh(
    model,
    comm,
    rank: int,
    gdim: int = 3,
    partitioner = None,
    Args:
        model: Gmsh model.
    Returns:
        name to integer.
    Note:
    valid_mesh = None
        try:
            valid_mesh = True
    if not valid_mesh:
    # the input rank
        comm, cells=cell_connectivity, e=ufl_domain, x=x[:, :gdim].astype(dtype, copy=False),
        partitioner=partitioner
    for codim in [0]:
        if (
            continue
        et.name = key
        return mesh, et
gdim = 2
    [(gdim, rect1)],
    recombine=True
occ.synchronize()
mpi_rank = 0
Thanks a lot for the fix. Is it planned to be included in the next stable release?
Probably not next stable release. I will have to talk to @Chris_Richardson about how we want to read in facet markers on such meshes.
