I have created a mesh with gmsh and I am having trouble importing it into my script.
Dolfin has trouble reading the facets xdmf file and shows the following error message:
*** Error: Unable to find entity in map.
*** Reason: Error reading MeshValueCollection.
*** Where: This error was encountered inside HDF5File.cpp.
this is my .geo file:
// Gmsh project created on Tue Jan 18 10:52:11 2022
SetFactory("OpenCASCADE");
Point(1) = {0, 0, 0, 1.0};
Point(3) = {0.007421, 0.001296, 0, 1.0};
Point(5) = {0.007421, 0.002798, 0, 1.0};
Point(6) = {0.007421, 0.003812, 0, 1.0};
Point(7) = {0.007421, 0.002748, 0, 1.0};
Point(8) = {0.006405, 0.001273, 0, 1.0};
Point(9) = {0.006405, 0.002727, 0, 1.0};
Point(10) = {0.006405, 0.002783, 0, 1.0};
Point(11) = {0.006405, 0.003791, 0, 1.0};
Point(12) = {0.005553, 0.001266, 0, 1.0};
Point(13) = {0.005553, 0.002718, 0, 1.0};
Point(14) = {0.005553, 0.002769, 0, 1.0};
Point(15) = {0.005553, 0.003788, 0, 1.0};
Point(16) = {0.004349, 0.001228, 0, 1.0};
Point(17) = {0.004349, 0.002597, 0, 1.0};
Point(18) = {0.004349, 0.002660, 0, 1.0};
Point(19) = {0.004349, 0.003704, 0, 1.0};
Point(20) = {0.004120, 0.000980, 0, 1.0};
Point(21) = {0.004120, 0.002534, 0, 1.0};
Point(22) = {0.004120, 0.002596, 0, 1.0};
Point(23) = {0.004120, 0.003669, 0, 1.0};
Point(24) = {0.003964, 0.00-0.000688, 0, 1.0};
Point(25) = {0.003964, 0.002482, 0, 1.0};
Point(26) = {0.003964, 0.002542, 0, 1.0};
Point(27) = {0.003964, 0.003631, 0, 1.0};
Point(28) = {0.003535, -0.000730, 0, 1.0};
Point(29) = {0.003535, 0.002272, 0, 1.0};
Point(30) = {0.003535, 0.002336, 0, 1.0};
Point(31) = {0.003535, 0.003501, 0, 1.0};
Point(32) = {0.003227, -0.000693, 0, 1.0};
Point(33) = {0.003227, 0.002033, 0, 1.0};
Point(34) = {0.003227, 0.002101, 0, 1.0};
Point(35) = {0.003227, 0.003370, 0, 1.0};
Point(36) = {0.002993, 0.001490, 0, 1.0};
Point(37) = {0.002993, 0.003231, 0, 1.0};
Point(38) = {0.002993, -0.000661, 0, 1.0};
Point(39) = {0.002790, 0.003081, 0, 1.0};
Point(40) = {0.002670, -0.000627, 0, 1.0};
Point(41) = {0.002670, 0.000256, 0, 1.0};
Point(42) = {0.002395, 0, 0, 1.0};
Point(43) = {0, -0.000660, 0, 1.0};
Line(1) = {1, 42};
Point(44) = {0, 0, 0, 1.0};
Point(45) = {0, 0, -0, 1.0};
Point(46) = {0, 0, -0, 1.0};
Point(47) = {0, 0, -0, 1.0};
Point(48) = {0, 0, -0, 1.0};
Point(49) = {0, 0, -0, 1.0};
Point(50) = {0, 0, -0, 1.0};
Point(51) = {0, 0, -0, 1.0};
Point(52) = {0, 0, -0, 1.0};
Point(53) = {0, 0, -0, 1.0};
Point(54) = {0, 0, -0, 1.0};
Point(55) = {0, 0, -0, 1.0};
Point(56) = {0, 0, -0, 1.0};
Point(57) = {0, 0, -0, 1.0};
Point(58) = {0, 0, -0, 1.0};
Point(59) = {0, 0, -0, 1.0};
Point(60) = {0, 0, -0, 1.0};
Line(2) = {41, 39};
Spline(3) = {39, 37, 35, 31};
Spline(4) = {31, 27, 23, 19};
Spline(5) = {19, 15, 11, 6};
Line(6) = {6, 5};
Spline(7) = {5, 10, 14};
Spline(8) = {14, 18, 22};
Spline(9) = {22, 26, 30, 34, 36};
Spline(10) = {36, 33, 29, 25};
Spline(11) = {25, 21, 17, 13};
Spline(12) = {13, 9, 7};
Line(13) = {3, 7};
Spline(14) = {3, 8, 12};
Line(15) = {12, 16};
Line(16) = {16, 20};
Line(17) = {20, 24};
Line(18) = {24, 28};
Line(19) = {28, 32};
Line(20) = {32, 38};
Line(21) = {38, 40};
Line(22) = {40, 43};
Point(61) = {0, 0, -0, 1.0};
Point(62) = {0, 0, -0, 1.0};
Point(63) = {0, 0, -0, 1.0};
Point(64) = {0, 0, -0, 1.0};
Point(65) = {0, 0, -0, 1.0};
Point(66) = {0.002598, 0.000107, 0, 1.0};
Spline(23) = {41, 66, 42};
Point(67) = {0, -0.000284, 0, 1.0};
Point(68) = {0.000698, -0.000284, 0, 1.0};
Point(69) = {0.001298, -0.000322, 0, 1.0};
Point(70) = {0.001522, -0.000314, 0, 1.0};
Point(71) = {0.003118, -0.000029, 0, 1.0};
Point(72) = {0.003166, 0.000059, 0, 1.0};
Point(73) = {0.003118, 0.000710, 0, 1.0};
Line(25) = {67, 68};
Spline(26) = {68, 69, 70};
Spline(30) = {36, 73, 72, 71};
Line(31) = {71, 70};
Symmetry {1, 0, 0, 0} {
Duplicata { Curve{1}; Curve{23}; Curve{2}; Curve{3}; Curve{4}; Curve{5}; Curve{6}; Curve{7}; Curve{8}; Curve{9}; Curve{30}; Curve{31}; Curve{26}; Curve{25}; Curve{22}; Curve{21}; Curve{20}; Curve{19}; Curve{18}; Curve{17}; Curve{16}; Curve{15}; Curve{14}; Curve{13}; Curve{12}; Curve{11}; Curve{10}; }
Duplicata { Point{66}; Point{37}; Point{35}; Point{27}; Point{23}; Point{11}; Point{33}; Point{29}; Point{25}; Point{21}; Point{9}; Point{8}; }
Duplicata { Point{34}; Point{30}; Point{26}; }
Duplicata { Point{14}; }
Duplicata { Point{10}; }
Duplicata { Point{15}; }
Duplicata { Point{70}; }
Duplicata { Point{69}; }
Duplicata { Point{71}; }
Duplicata { Point{72}; }
Duplicata { Point{73}; }
Duplicata { Point{26}; }
Duplicata { Point{22}; }
Duplicata { Point{18}; }
Duplicata { Point{17}; }
Curve Loop(1) = {1,23,2,3,4,5,6,7,8,9,30,31,26,25,45,44,43,42,41,40,39,38,37,36,35,34,33,32};
Plane Surface (1) = {1};
Curve Loop(2) = {25,26,31,30,10,11,12,13,14,15,16,17,18,19,20,21,22,46,47,48,49,50,51,52,53,54,55,56,57,58,42,43,44,45};
Plane Surface(2) = {2};
Physical Curve(1) = {35, 37, 36, 34, 32, 33, 1, 23, 2, 3, 5, 4};
Physical Curve(2) = {38};
Physical Curve(3) = {6};
Physical Curve(4) = {8, 10, 9, 7, 11, 12};
Physical Curve(5) = {13};
Physical Curve(6) = {14, 15, 16, 17, 18, 19, 20, 21, 22, 46, 47, 48, 49, 50, 51, 52, 53, 54};
Physical Curve(7) = {55};
Physical Curve(8) = {56, 57, 58, 41, 40, 39};
Physical Curve(11) = {42, 43, 44, 45, 25, 26, 31, 30};
Physical Surface(9) = {1};
Physical Surface(10) = {2};
I am using the following code to import the mesh:
mesh = Mesh()
infile.read(mesh)
infile.read(mvc, "Boundary")
I’m thankful for any suggestions for what might be wrong with my mesh
Edit 1
Code for mesh conversion:
# import mesh file from gmesh
msh = meshio.read('mesh.msh')
# make
line_cells = []
for cell in msh.cells:
if cell.type == "triangle":
triangle_cells = cell.data
elif cell.type == "line":
if len(line_cells) == 0:
line_cells = cell.data
line_cells = np.vstack([line_cells, cell.data])
line_data = []
if key == "line":
if len(line_data) == 0:
line_data = msh.cell_data_dict["gmsh:physical"][key]
line_data = np.vstack([line_data, msh.cell_data_dict["gmsh:physical"][key]])
elif key == "triangle":
triangle_mesh = meshio.Mesh(points=msh.points[:, :2], cells={"triangle": triangle_cells})
line_mesh =meshio.Mesh(points=msh.points[:, :2],
cells=[("line", line_cells)],
cell_data={"Boundary":[line_data]})
meshio.xdmf.write("mf.xdmf", line_mesh)
