Unable to plot squared norm of solution over domain
While trying to solve the time-dependent Schrodinger equation with a initial condition and dirichlet boundary conditions over a rectangular shaped domain, we’re trying to plot the values of |u|^2 on the domain. This is done with a VectorFunctionSpace were u[0] corresponds to the real part of the equation and u[1] corresponds to the imaginary part, as seen in the residual F below. We want to plot the u[0]^2+u[1]^2 in a contour plot.
T = 2.0            # final time
num_steps = 200     # number of time steps
mesh = RectangleMesh(Point(-5, -5), Point(5, 5), 50, 50)
V = VectorFunctionSpace(mesh, 'Lagrange', 1, dim=2)
# Define initial value
u_0 = Expression(  ( 'exp(-2*(pow(x[0], 2)))+ exp(-2*pow(x[1], 2))', '0'), degree=1)
u_n = interpolate(u_0, V)
def boundary(x, on_boundary):
    return on_boundary
bc = DirichletBC(V,(0, 0), boundary)
f = Expression(('1/4*pow(x[0], 2) + 9*pow(x[1], 2)', '0'), degree=2)
QQ = FunctionSpace(mesh, "R", 0, 2)
#Residual
F = u[0]*v[0]*dx - dt/2*dot(grad(u[1]),grad(v[0]))*dx - dt/2*f[0]*u[1]*v[0]*dx - u_n[0]*v[0]*dx - dt/2*dot(grad(u_n[1]),grad(v[0]))*dx - dt/2*f[0]*u_n[1]*v[0]*dx + u[1]*v[1]*dx + dt/2*dot(grad(u[0]),grad(v[1]))*dx + dt/2*f[0]*u[0]*v[1]*dx - u[1]*v[1]*dx + dt/2*dot(grad(u[0]), grad(v[1]))*dx + dt/2*f[0]*u[0]*v[1]*dx
J = derivative(F, u)
t=0
for n in range(num_steps):
    # Update current time
    # Compute solution
    solve(F == 0, u, bc, J=J)
    #print(norm_u)
    unormsq = project(inner(u,u),QQ)
    # Update previous solution
    u_n.assign(u)
plot(unormsq)
plt.savefig('testunorm2.png')
the right contour plot is what we expect to get (given from our supervisor) and the left plot is what we get.
Before we’re even able to conclude if the solution is correct we’re not able to plot the solution with a contour plot on the mesh. How would we go about plotting this data?
Maybe this is what you need:
u0, u1 = u.split()
plot(u0**2+u1**2)
