Hi, I am trying to do a simulation of diffusion over time, but my field values are not being updated. What seems to be the issue here?
import matplotlib
matplotlib.use('Agg')
from matplotlib import ticker
# Units are seconds, OD, uM, mm
T = 50*60*60 # final time
num_steps = 1000 # number of time steps
D=Constant(50.2e-3)
Dn=Constant(50.2e-5)
Da=Constant(50.2e-4)
chi_0=Constant(315e-6)
am=Constant(1e-3)
folder='outputs_test/'
# Read mesh from file
mesh = generate_mesh(Circle(Point(0.0, 0.0), 10), 128)
# Define function space for velocity
W = VectorFunctionSpace(mesh, 'P', 2)
# Define function space for system of concentrations
P1 = FiniteElement('P', triangle, 1)
element = MixedElement([P1, P1, P1])
# Define test functions
rho_test, n_test, a_test = TestFunctions(V)
# Define functions for velocity and concentrations
w = Function(W)
u_n = Function(V)
# Split system functions to access components
rho_trial, n_trial, a_trial = split(u)
rho_iter, n_iter, a_iter = split(u_n)
rho_iter = Expression('(tanh((4-x[0]*x[0]-x[1]*x[1]))+1)*.029/2', degree=3, R=1)
n_iter = Constant('40.0')
a_iter = Constant('0.1')
# Define source terms
f_1 = Constant(0)
f_2 = Constant(0)
f_3 = Constant(0)
k = Constant(dt)
w=project(chi_0/am*grad(a_trial))
F = (((rho_trial - rho_iter) / k)*rho_test*dx
#+ dot(w, grad(rho_trial))*rho_test*dx # Advection
+ D*dot(grad(rho_trial), grad(rho_test))*dx #Diffusion
+ ((n_trial - n_iter) / k)*n_test*dx
+ Dn*dot(grad(a_trial), grad(n_test))*dx #Diffusion
+ ((a_trial - a_iter) / k)*a_test*dx
+ Da*dot(grad(n_trial), grad(a_test))*dx #Diffusion
- f_1*rho_test*dx - f_2*n_test*dx - f_3*a_test*dx)
# Time-stepping
t = 0
for n in range(num_steps):
dpi=200
# Update current time
# Solve variational problem for time step
solve(F == 0, u)
_rho_trial, _n_trial, _a_trial = u.split()
# Update previous solution
u_n.assign(u)
