Dear Community,
I’m encountering an issue while trying to set initial conditions for a vector within a specific subdomain of the mesh. I’m working on a project where I need to define different initial conditions for different subdomains, but I’m having trouble achieving this. I have used a Mixed Element to define a vector and a scalar. The method, which I have used to set initial condition for the scalar worked well, but it doesn’t work for the setting of vector.
Here’s the part of my code:
from dolfinx.mesh import *
from dolfinx.mesh import CellType, locate_entities
from dolfinx.fem import (Function, functionspace)
from basix.ufl import element
##### Mesh Part #####
domain = create_unit_square(MPI.COMM_WORLD, 5, 5, CellType.triangle)
# Mixed element
P2 = element("Lagrange", domain.basix_cell(), 1, shape = (2,)) # Mixed element for tensor , shape = (2,)
P1 = element("Lagrange", domain.basix_cell(), 1)
# Functionspace for mixed element
TH = ufl.MixedElement([P2, P1])
ME = functionspace(domain, TH)
v_u, v_pi = ufl.TestFunctions(ME)
Variable = Function(ME)
u, pi = ufl.split(Variable)
##### Subdomains #####
Omega = {}
Omega[0] = lambda x : np.logical_and(x[0] >= 0.5, x[0] <= 1.0)
Omega[1] = lambda x : np.logical_and(x[0] >= 0.0, x[0] <= 0.5)
Subdomain1 = locate_entities(domain, domain.topology.dim, Omega[0])
##### Initial Conditions #####
V2 = functionspace(domain, P2)
Value = {}
Value[0] = Function(V2)
initial_u = PETSc.ScalarType((0, 0))
Value[0].x.array[Subdomain1]= np.full_like(Subdomain1, initial_u, dtype=default_scalar_type)
Variable.sub(0).interpolate(Value[0])
Variable.x.scatter_forward()
Here’s the Error I got:
ValueError: could not broadcast input array from shape (2,) into shape (20,)
I’ve searched through the entire Dolfinx tutorial and tried lots of methods but I couldn’t find a solution to my problem. I would greatly appreciate any suggestions on how to approach this problem.
Thank you in advance for your help!
