Hello Fenics community,
I am trying to implement an RD system where I also have to update the mesh coordinates. When I try to assign the initial conditions for the mesh coordinate function.
V01, _ = ME2.sub(0).collapse()
V02, _ = ME2.sub(1).collapse()
def x_expr(x):
"""Expression for the exact velocity solution to Kovasznay flow"""
return np.vstack((x[0],x[1]))
x_exp = Expression(x, V01.element.interpolation_points())
H_exp = Expression(div(sign*n), V02.element.interpolation_points())
normal_expr = Expression(n_oriented, V01.element.interpolation_points())
normal_vec = Function(V01)
#X0.sub(0).interpolate(x_exp)
X0.sub(1).interpolate(H_exp)
X0.sub(0).interpolate(x_expr)
X0.x.scatter_forward()
I obtain strange values if I plot as a vector (It should look like outward vectors).
I have already implemented it in different ways, but I cannot find the error.
Here is my MWE
import os
import math
from dolfinx import default_real_type, log, mesh
from dolfinx.fem import Function, functionspace, Expression
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
from dolfinx.io import XDMFFile, gmshio
from dolfinx.mesh import CellType, GhostMode
from ufl import dx, grad, inner, div,dot
# Save all logging to file
log.set_output_file("log.txt")
# Next, various model parameters are defined:
dt = 5.0e-02 # time step
try:
import gmsh # type: ignore
except ImportError:
import sys
print("This demo requires gmsh to be installed")
sys.exit(0)
def gmsh_circle(model: gmsh.model, name: str) -> gmsh.model:
"""Create a Gmsh model of a circle.
model.add(name)
model.setCurrent(name)
gmsh.option.setNumber("Mesh.CharacteristicLengthFactor", 0.3)
circle = model.occ.addCircle(0, 0, 0, 1, tag=1)
# Synchronize OpenCascade representation with gmsh model
model.occ.synchronize()
# Add physical marker for cells. It is important to call this
# function after OpenCascade synchronization
model.add_physical_group(dim=1, tags=[circle])
# Generate the mesh
model.mesh.generate(dim=1)
model.mesh.setOrder(2)
return model
def create_mesh(comm: MPI.Comm, model: gmsh.model, name: str, filename: str, mode: str):
"""Create a DOLFINx from a Gmsh model and output to file.
msh, ct, ft = gmshio.model_to_mesh(model, comm, rank=0,gdim=2)
msh.name = name
ct.name = f"{msh.name}_cells"
ft.name = f"{msh.name}_facets"
with XDMFFile(msh.comm, filename, mode) as file:
msh.topology.create_connectivity(0, 1)
file.write_mesh(msh)
file.write_meshtags(ct, msh.geometry, geometry_xpath=f"/Xdmf/Domain/Grid[@Name='{msh.name}']/Geometry")
file.write_meshtags(ft, msh.geometry, geometry_xpath=f"/Xdmf/Domain/Grid[@Name='{msh.name}']/Geometry")
gmsh.option.setNumber("General.Terminal", 0)
# Create model
model = gmsh.model()
model = gmsh_circle(model, "circle")
model.setCurrent("circle")
create_mesh(MPI.COMM_SELF, model, "circle", f"out_gmsh/mesh_rankCircle_{MPI.COMM_WORLD.rank}.xdmf", "w")
with XDMFFile(MPI.COMM_WORLD, "out_gmsh/mesh_rankCircle_0.xdmf", "r") as xdmf:
mesh = xdmf.read_mesh(name="circle")
gmsh.finalize
P1 = element("Lagrange", mesh.basix_cell(), 2, gdim=2)
ME = functionspace(mesh, mixed_element([P1, P1], gdim=2))
n = ufl.CellNormal(mesh)
r = x/ufl.sqrt(ufl.dot(x, x))
sign = ufl.sign(ufl.dot(n, r))
n_oriented = sign*n
signx = ufl.sign(ufl.dot(n, r))
xc = signx*n
V1 = element("Lagrange", mesh.basix_cell(), 2, shape=(mesh.geometry.dim,), gdim=2)
V2 = element("Lagrange", mesh.basix_cell(), 2, gdim=2)
ME2 = functionspace(mesh, mixed_element([V1, V2],gdim=2))
# Trial and test functions of the space `ME` are now defined:
q, v = ufl.TestFunctions(ME)
Xi, phi = ufl.TestFunctions(ME2)
# ```{index} split functions
u = Function(ME) # current solution
u0 = Function(ME) # solution from previous converged step
# X = Function(ME2) # current solution
X0 = Function(ME2) # solution from previous converged step
X0.name = "X0"
(Xh, H) = ufl.TrialFunctions(ME2) # current solution
#(Xh0, H0) = ufl.TrialFunctions(ME2) # solution from previous converged step
# Split mixed functions
u1, u2 = ufl.split(u)
u10, u20 = ufl.split(u0)
# # Split mixed functions
# Xh, H = ufl.split(X)
Xh0 = X0.sub(0)
H0 = X0.sub(1)
au = 0.9
bu = 1.1
av = 0.8
bv = 0.95
# Interpolate initial condition
u.sub(0).interpolate(lambda x: (bu-au)*np.random.rand(x.shape[1]) +au)
u.sub(1).interpolate(lambda x: (bv-av)*np.random.rand(x.shape[1]) +av)
u.x.scatter_forward()
def x_expr(x):
print (f"X array {X0.sub(0).x.array[:]}")
u_vec = ufl.as_vector([u1, u2])
kp = ufl.as_vector([1.5 , 0])
# Weak statement of the equations
k = dt
d = 10
gamma = 29
a = 0.1
b = 0.9
tol = 1e-4
d1 = 1.0
d2 = d
ks = 25
kb = 2
F = ((u1 - u10) / k)*q*dx + d1*inner(grad(u1), grad(q))*dx\
-(gamma*(u1*u1*u2-u1+a))*q*dx \
+ ((u2 - u20) / k)*v*dx + d2*inner(grad(u2), grad(v))*dx\
-(gamma*(-u1*u1*u2+b))*v*dx
ax = dot((Xh / k),n_oriented)*phi*dx + kb*inner(grad(H),grad(phi))*dx - 1/2 *kb* H0**2 * H *phi*dx + ks*H*phi*dx\
+ dot(H*n_oriented,Xi)*dx - inner(grad(Xh),grad(Xi))*dx
Lx = dot(kp,u_vec)*phi*dx + dot((Xh0 / k),n_oriented)*phi*dx
# Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, u)
solver.rtol = np.sqrt(np.finfo(default_real_type).eps) * 1e-2
# We can customize the linear solver
ksp = solver.krylov_solver
opts = PETSc.Options() # type: ignore
ksp.setFromOptions()
# X_h = Function(ME2)
# X_h.name = "X_h"
problemX = LinearProblem(ax, Lx)
# Step in time
t = 0.0
# Output file
name = "mesh_at_t"+str(t)
mesh.name = name
# Get the sub-space for c and the corresponding dofs
normal_vec.interpolate(normal_expr)
V0, dofs = ME.sub(0).collapse()
W02, dofs2 = ME2.sub(0).collapse()
u1 = u.sub(0)
u2 = u.sub(1)
Xh0 = X0.sub(0)
H0 = X0.sub(1)
X_coord = X0.x.array[dofs2].reshape(len(mesh.geometry.x[:,1]),2)
file1 = XDMFFile(MPI.COMM_WORLD, "SchnakenbergProof/outputu1.xdmf", "w")
file3 = XDMFFile(MPI.COMM_WORLD, "SchnakenbergProof/normal.xdmf", "w")
file4 = XDMFFile(MPI.COMM_WORLD, "SchnakenbergProof/H.xdmf", "w")
file1.write_mesh(mesh)
file3.write_mesh(mesh)
file4.write_mesh(mesh)
file1.write_function(u1, t, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
file3.write_function(normal_vec, t, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
file4.write_function(X0.sub(0), t, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
norm_stop = 0.1e-6
fileL2 = open('L2.dat', 'w')
np.savetxt("coordinates.dat", mesh.geometry.x, delimiter='\t', header='x\ty', comments='')
z = 0
inc = 0
impresion = 1
u0.x.array[:] = u.x.array
#print (f"MESH array {mesh.geometry.x[:,]}")
X_h = problemX.solve()
r = solver.solve(u)
inc += 1
print(f"Step {int(t/dt)}: num iterations: {r[0]}")
l2_norm = np.linalg.norm(u.x.array[dofs]-u0.x.array[dofs])/dt
#print (f"L2_norm = {l2_norm}")
fileL2.write(f"{t}\t{l2_norm}\n")
X0.x.array[:] = X_h.x.array
num=inc/impresion-1
DeltaX = mesh.geometry.x[:,[0,1]]-X_coord
#print (f"Delta X array {DeltaX}")
mesh.geometry.x[:,0] = X_coord[:,0]
mesh.geometry.x[:,1] = X_coord[:,1]
# Save solution to file (VTK)
mesh.name = name
z += 1
file1.close()
file3.close()
file4.close()
fileL2.close()
print(l2_norm)
#print(H.x.array)
Does anybody know what could be the error?
Thank you.
