Hello, everyone. I have a question, during my study I have a problem like this
Assembling the weak form of operator 'Op1'...
Collecting data for assembler construction...
Data collection finished.
Precalculating singular integrals...
Precalculation of singular integrals took 12.1156 s
Assembly of the weak form of operator 'Op1' took 39.6848 s
Assembling the weak form of operator 'Op2'...
Assembly of the weak form of operator 'Op2' took 0.0617588 s
Calculating the (pseudo)inverse of operator 'Op2'...
Calculation of the (pseudo)inverse of operator 'Op2' took 0.0851854 s
Solving linear system of size 39585 x 39585 (PETSc Krylov solver).
File "newtry.py", line 52, in <module>
for i in range (300): llg.step(state, 2e-11)
File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 151, in step
File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 148, in step
File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 134, in calculate_v
File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 132, in calculate_v
File "/usr/lib/python2.7/dist-packages/dolfin/fem/solving.py", line 279, in solve
return cpp.la_solve(*args)
File "/usr/lib/python2.7/dist-packages/dolfin/cpp/la.py", line 4279, in la_solve
return _la.la_solve(*args)
RuntimeError:
*** fenics@fenicsproject.org
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_NANORINF, residual norm ||r|| = -nan).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: unknown
*** DOLFIN version: 1.5.0
*** Git changeset: unknown
[Mesh file (created by Salome), XML and XDMF files and PYTHON code which you can check and try] (https://drive.google.com/drive/folders/1ZhAbf1Npsx0ljIlncKzJ_U6ChZUyrPwN?usp=drive_link)
Could you explain me why it cannot solve linear system and how I can fix it? Thanks in advance.
