I was running a linear elastic problem. The python script are shown as follows:
from ufl import nabla_div
import sys
path = 'sample0_300_8973410.stl'
#Scaled variables
E = 2.5e11
nv = 0.27
lambda_ = E * nv / ((1 + nv) * (1 - 2 * nv))
mu = 0.5 * E / (1 + nv)
comm = MPI.COMM_WORLD
if comm.rank == 0:
gmsh.merge(path)
s = gmsh.model.getEntities(2)
l = gmsh.model.geo.addSurfaceLoop([e[1] for e in s])
V0 = gmsh.model.geo.addVolume([l])
gmsh.model.addPhysicalGroup(3, [V0], 1)
gmsh.model.geo.synchronize()
gmsh.model.mesh.generate(3)
#obtain the model dimension
dimensionBox = gmsh.model.getBoundingBox(-1, -1)
gmsh.write("sample0_100.msh")
gmsh.finalize()
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={
"name_to_read": [cell_data]})
return out_mesh
mesh_from_file = meshio.read("sample0_100.msh")
tetra_mesh = create_mesh(mesh_from_file, "tetra", prune_z=False)
meshio.write("tetra_mesh.xdmf", tetra_mesh)
print(mesh_from_file)
dimensionBox = None
comm.Barrier()
dimensionBox = comm.bcast(dimensionBox, root=0)
xmin = dimensionBox[0]
ymin = dimensionBox[1]
zmin = dimensionBox[2]
xmax = dimensionBox[3]
ymax = dimensionBox[4]
zmax = dimensionBox[5]
mesh = Mesh()
with XDMFFile("tetra_mesh.xdmf") as infile:
infile.read(mesh)
# Define boundary condition
tol = 1.5
def boundary_Left(x, on_boundary):
return on_boundary and near(x[0], xmin, tol)
def boundary_Right(x, on_boundary):
return on_boundary and near(x[0], xmax, tol)
def boundary_Front(x, on_boundary):
return on_boundary and near(x[1], ymin, tol)
def boundary_Back(x, on_boundary):
return on_boundary and near(x[1], ymax, tol)
def boundary_Top(x, on_boundary):
return on_boundary and near(x[2], zmax, tol)
def boundary_Bottom(x, on_boundary):
return on_boundary and near(x[2], zmin, tol)
applied_strain = 1.0e-4
applied_disp = applied_strain * (xmax - xmin)
bc_l = DirichletBC(V.sub(0), Constant(0), boundary_Left)
bc_r = DirichletBC(V.sub(0), Constant(applied_disp), boundary_Right)
bc_f = DirichletBC(V.sub(1), Constant(0), boundary_Front)
bc_ba = DirichletBC(V.sub(1), Constant(0), boundary_Back)
bc_bo = DirichletBC(V.sub(2), Constant(0), boundary_Bottom)
bc_t = DirichletBC(V.sub(2), Constant(0), boundary_Top)
bcs = [bc_l, bc_r, bc_f, bc_ba, bc_bo, bc_t]
# Define strain and stress
#return sym(nabla_grad(u))
def sigma(u):
return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
d = u.geometric_dimension() # space dimension
f = Constant((0, 0, 0))
L = dot(f, v)*dx
# Compute solution
solve(a == L, u, bcs, solver_parameters = {'linear_solver':'mumps'})
When I run the job, I got the error message:
Error: Unable to solve linear system using PETSc Krylov solver.
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_PC_FAILED, residual norm ||r|| = 0.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
Does anyone have idea about what was wrong in my model? Thanks.
