Hi, I went through this amazing tutorial on Hertzian contact in 3D spatial space and decided to implement it in 2D but the results of Contact Pressure plot and Displacement plot are quite unexpected when I try to indent on point (0.5, 1) .
Plots -
Expectations - I want the contact pressure to be more in the area of contact like this -
I want displacement plot like this -
How can I achieve both by tweaking the boundary conditions ? I would love to hear on the same.
Minimum Working Example -
domain = Rectangle(Point(0., 0.), Point(1., 1.))
mesh = generate_mesh(domain, 10)
class Top(SubDomain):
return near(x[1], 1.) and on_boundary
def bottom(x, on_boundary):
return near(x[1], 0.) and on_boundary
facets = MeshFunction("size_t", mesh, 2)
facets.set_all(0)
bc_top = Top()
bc_top.mark(facets, 1)
ds = Measure('ds', subdomain_data=facets)
R = 0.5
d = 0.02
obstacle = Expression("-d+(pow(x[0] - 0.5,2) + 1)/2/R", d=d, R=R, degree=2)
V = VectorFunctionSpace(mesh, "CG", 1)
V2 = FunctionSpace(mesh, "CG", 1)
V0 = FunctionSpace(mesh, "DG", 0)
u = Function(V, name="Displacement")
du = TrialFunction(V)
u_ = TestFunction(V)
gap = Function(V2, name="Gap")
p = Function(V0, name="Contact pressure")
bc =[DirichletBC(V, Constant((0., 0.)), bottom), DirichletBC(V.sub(1), obstacle, bc_top)]
E = Constant(10.)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(v):
return sym(grad(v))
def sigma(v):
return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v)
def ppos(x):
return (x+abs(x))/2.
pen = Constant(1e4)
form = inner(sigma(u), eps(u_))*dx + pen*dot(u_[1], ppos(u[1]-obstacle))*ds(1)
J = derivative(form, u, du)
problem = NonlinearVariationalProblem(form, u, bc, J=J)
solver.parameters["newton_solver"]["linear_solver"] = "cg"
solver.parameters["newton_solver"]["preconditioner"] = "ilu"
solver.solve()
p.assign(-project(sigma(u)[1, 1], V0))
gap.assign(project(obstacle-u[1], V2))
a = sqrt(R*d)
F = 4/3.*float(E)/(1-float(nu)**2)*a*d
p0 = 3*F/(2*pi*a**2)
print("Maximum pressure FE: {0:8.5f} Hertz: {1:8.5f}".format(max(np.abs(p.vector().get_local())), p0))
print("Applied force FE: {0:8.5f} Hertz: {1:8.5f}".format(4*assemble(p*ds(1)), F))
file_results = XDMFFile("2d_contact_penalty_results.xdmf")
file_results.write(u, 0.)
file_results.write(gap, 0.)
file_results.write(p, 0.)
Thank You.
