Hi all. I’m trying to solve a problem of a hyperelastic material, which is subjected to a displacement load. I want to visualize the calculated displacement and show the deformation of the material by paraview. But I don’t know how to update the node coordinates to show the deformation of the material. The corresponding codes and pictures are attached below. Does anyone have experience dealing with similar issues?Thanks in advance.
from ufl import indices
Optimization options for the form compiler
parameters[“form_compiler”][“cpp_optimize”] = True
parameters[“form_compiler”][“representation”] = “uflacs”
parameters[“form_compiler”][“quadrature_degree”]=4
#mesh=RectangleMesh(Point(0,0),Point(1,1),1,1,“left/right”)
mesh=UnitSquareMesh(20,20)
mesh = UnitSquareMesh.create(2,2, CellType.Type.quadrilateral)
#plot(mesh)
V = VectorFunctionSpace(mesh, “Lagrange”, 1)
Mark boundary subdomians
bot = CompiledSubDomain(“near(x[1], side) && on_boundary”, side = 0.0)
top = CompiledSubDomain(“near(x[1], side) && on_boundary”, side = 1.0)
applied_disp = Expression(“disp”, disp=0.0, degree=2)
bcl = DirichletBC(V, Constant((0,0)), bot)
bcr = DirichletBC(V.sub(1), applied_disp, top)
bcs = [bcl, bcr]
Define functions
du = TrialFunction(V) # Incremental displacement
v = TestFunction(V) # Test function
u = Function(V) # Displacement from previous iteration
u_old = Function(V)
B = Constant((0.0, -0.5, 0.0)) # Body force per unit volume
T = Constant((0.1, 0.0, 0.0)) # Traction force on the boundary
def safeSqrt(x):
return sqrt(x+DOLFIN_EPS)
Kinematics
d = len(u)
I = Identity(d) # Identity tensor
C = variable(F.T*F) # Right Cauchy-Green tensor
q1=(F[0,1]-F[1,0])**2
q2=(F[0,0]+F[1,1])**2
q3=(F[0,1]+F[1,0])2
q4=(F[0,0]-F[1,1])2
eig1=(safeSqrt(q1+q2)-safeSqrt(q3+q4))/2
eig2=(safeSqrt(q1+q2)+safeSqrt(q3+q4))/2
eig12=eig12
eig22=eig22
def psign(u):
return conditional(lt(u,1),1,u)
def nsign(u):
return conditional(le(1,u),1,u)
Invariants of deformation tensors
Ic = tr(C)
J = det(F)
Elasticity parameters
E, nu = 10.0, 0.3
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E/(3*(1-2*nu)))
eps=1E-8
psi=(mu/2*(eig12+eig22-2-2ln(eig1)-2ln(eig2))+0.5lmbda(ln(J))**2)*dx
psi1=(mu/2*(psign(eig12)+psign(eig22)-2-2ln(psign(eig1))-2ln(psign(eig2)))+0.5lmbda(ln(psign(J)))**2)dx
psi2=(mu/2(nsign(eig12)+nsign(eig22)-2-2ln(nsign(eig1))-2ln(nsign(eig2)))+0.5lmbda(ln(nsign(J)))**2)*dx
F=derivative(psi1,u,v)+derivative(psi2,u,v)
J = derivative(F, u, du)
t=0
ur=1.0
deltaT=0.1
tol=1e-3
maxiteration=25
AM_tolerance=1E-3
conc_f=File(“./hyperelastic2/u.pvd”)
fname=open(‘F_D_curve1.txt’,‘w’)
problem=NonlinearVariationalProblem(F,u,bcs,J=J)
solver=NonlinearVariationalSolver(problem)
#staggered scheme
while t<=1.0:
t+=deltaT
if t>=0.4:
deltaT=0.05
applied_disp.disp=t*ur
iter=0
err=1
while err>AM_tolerance and iter<maxiteration:
iter +=1
solver.solve()
u_err=u.vector()-u_old.vector()
err=u_err.norm('linf')
u_old.assign(u)
if err < tol:
print('Iterations:', iter, ',Total time', t)
conc_f << u
