Updating tensors for each element by deformation gradient
In a dynamic transversely isotropic material problem, I have defined a rotation matrix for each element. I suppose the rotation matrices need to be updated after each time step. But I have problems in doing so. I have defined the matrices like below:
el_r = ufl.TensorElement("DG", mesh.ufl_cell(), 0, shape=(3, 3))
Q_r = fe.fem.FunctionSpace(mesh, el_r)
bs_r = Q_r.dofmap.bs
rotation_matrix = fe.fem.Function(Q_r)
def get_rotation_matrix(x):
    values = np.random((bs_r, x.shape[1]), dtype=np.float64)
    return values
rotation_matrix.interpolate(get_rotation_matrix)
Later for solving I use the function below to update the rotation matrix:
F = ufl.variable(I + ufl.grad(u))             # Deformation gradient
def update_rotation(R, F):
    new_rotation = ufl.dot(F,R)
    return new_rotation
But now there are a few problems. Whenever I try to access the matrices with rotation_matrix.x.array[:] I get this error:
AttributeError: ‘Dot’ object has no attribute ‘x’. Did you mean: ‘dx’?
Also, I need to make sure that the new rotation_matrix is orthogonal. So I guess I need to convert the matrices to np.array for that.
I will appreciate any clarification of the procedure here.
Hi Jorosh
The expression ufl.dot(F,R) is a UFL (Unified Form Language) expression and therefore does not possess an attribute .x.array. If you wish to obtain such a vector, it would be necessary to first declare something like,
new_rotation_expression = dolfinx.fem.Expression(new_rotation, Q_r.element.interpolation_points())
then interpolate this expression into a Function from which you can subsequently retrieve the coordinates.
new_rotation_Function = dolfinx.fem.Function(Q_r)
print(new_rotation_Function.x.array)
Hi Paul
Thank you for your attention. I’ve got your point, but there is still a problem with the interpolation. It throws:
RuntimeError: Cannot interpolate Expression with Argument.
I searched in UFL documents and there is an ufl.Argument object which is a basis function! I think the fact that I am using deformation gradient in update_rotation function causes this problem. How can I interpolate such an Expression?
Please provide a minimal reproducible example, as it is currently not clear what you are trying to do.
Hello @dokken
Thank you for you attention,
In this example I’ve set the initial value for for the rotation matrix as identity to keep the code as minimal as possible.
import dolfinx as fe
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem, assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
import os
def main(linear = True, time_dependent = True):
    L = 1
    W = 0.2
    mesh = fe.mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
                         [20, 6, 6], cell_type=fe.mesh.CellType.hexahedron)
    element = ufl.VectorElement("Lagrange", mesh.ufl_cell(), 1)
    V = fe.fem.functionspace(mesh, element)
    dt = fe.default_scalar_type(0.01)
    num_steps = int(1/float(dt))
    maximum_pressure = 15
    minimum_pressure = 0
    pressure = np.append(np.linspace(minimum_pressure, maximum_pressure, num=int(num_steps/2)),\
                         np.linspace(maximum_pressure, minimum_pressure, num=int(num_steps/2)))
    p = fe.fem.Constant(mesh, pressure[0])
    def clamped_boundary(x):
        return np.isclose(x[0], 0)
    fdim = mesh.topology.dim - 1
    clamped_boundary_facets = fe.mesh.locate_entities_boundary(mesh, fdim, clamped_boundary)
    u_D = np.array([0, 0, 0], dtype=fe.default_scalar_type)
    bc = fe.fem.dirichletbc(u_D, fe.fem.locate_dofs_topological(V, fdim, clamped_boundary_facets), V)
    boundaries = [(1, lambda x: np.isclose(x[0], L))]
        facets = fe.mesh.locate_entities(mesh, fdim, locator)
        facet_indices.append(facets)
    facet_tag = fe.mesh.meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
    ##########################Defining the rotation matrix for each cell##################################
        values = np.zeros((bs_r, x.shape[1]), dtype=np.float64)
        values[0] = 1
        values[4] = 1
        values[8] = 1
        return values
    #########################################Formulation##################################################
    u = ufl.TrialFunction(V)
    v  = ufl.TestFunction(V)
    old_u  = fe.fem.Function(V)
    old_velocity  = fe.fem.Function(V)
    old_acceleration  = fe.fem.Function(V)
    d = len(u)
    I = ufl.variable(ufl.Identity(d))             # Identity tensor
    C = ufl.variable(F.T*F)                   # Right Cauchy-Green tensor
    J = ufl.variable(ufl.det(F))
    ####Check out for the metadata
    ds = ufl.Measure("ds", domain=mesh, subdomain_data=facet_tag, metadata=metadata)
    dx = ufl.Measure("dx", domain=mesh, metadata=metadata)
    # Generalized-alpha method parameters
    alpha_m = fe.fem.Constant(mesh, 0.2)
    alpha_f = fe.fem.Constant(mesh, 0.4)
    gamma   = fe.default_scalar_type(0.5+alpha_f-alpha_m)
    beta    = fe.default_scalar_type((gamma+0.5)**2/4.)
    # Update formula for acceleration
    # a = 1/(2*beta)*((u - u0 - v0*dt)/(0.5*dt*dt) - (1-2*beta)*a0)
    def update_a(u, u_old, v_old, a_old, ufl=True):
        if ufl:
            dt_ = dt
            beta_ = beta
            dt_ = float(dt)
            beta_ = float(beta)
        return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
    # Update formula for velocity
    # v = dt * ((1-gamma)*a0 + gamma*a) + v0
    def update_v(a, u_old, v_old, a_old, ufl=True):
        if ufl:
            dt_ = dt
            gamma_ = gamma
            dt_ = float(dt)
            gamma_ = float(gamma)
        return v_old + dt_*((1-gamma_)*a_old + gamma_*a)
        return new_rotation
    def update_fields(u_new, u_old, v_old, a_old, rotation_matrix, F):
        """Update fields at the end of each time step."""
        # Get vectors (references)
        u_vec, u0_vec  = u_new.x.array[:], u_old.x.array[:]
        v0_vec, a0_vec = v_old.x.array[:], a_old.x.array[:]
        # use update functions using vector arguments
        a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl=False)
        v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl=False)
        R_vec = update_rotation(rotation_matrix, F)
        new_rotation_expression = fe.fem.Expression(R_vec, Q_r.element.interpolation_points())
        rotation_matrix.interpolate(new_rotation_expression)
        R_vec = rotation_matrix.x.array[:].reshape(num_cells_local, 3, 3)
        # Update (u_old <- u)
        v_old.x.array[:], a_old.x.array[:] = v_vec, a_vec
        u_old.x.array[:] = u_new.x.array[:]
        rotation_matrix.x.array[:] = R_vecs
    def avg(x_old, x_new, alpha):
        return alpha*x_old + (1-alpha)*x_new
    normal = -ufl.FacetNormal(mesh)
    rho = 1
    E = fe.default_scalar_type(1.0e4)
    nu = fe.default_scalar_type(0.3)
    mu = fe.fem.Constant(mesh, E / (2 * (1 + nu)))
    lmbda = fe.fem.Constant(mesh, E * nu / ((1 + nu) * (1 - 2 * nu)))
    def S(u):
        return 2.0 * mu * ufl.sym(ufl.grad(u)) + lmbda * ufl.tr(ufl.sym(ufl.grad(u))) * I
    acceleration = update_a(u, old_u, old_velocity, old_acceleration, ufl=False)
    velocity = update_v(acceleration, old_u, old_velocity, old_acceleration, ufl=True)
    formulation = rho * ufl.inner(alpha_m*old_acceleration + (1-alpha_m)* acceleration, v) * dx \
      + ufl.inner(ufl.grad(v), S(avg(old_u, u, alpha_f))) * dx \
      - ufl.inner(v, p * normal) * ds(1)
    bilinear_form = fe.fem.form(ufl.lhs(formulation))
    linear_form = fe.fem.form(ufl.rhs(formulation))
    ###############################################Solving################################################
    A = assemble_matrix(bilinear_form, bcs=[bc])
    b = create_vector(linear_form)
    solver.setInitialGuessNonzero(True)
    solver.setOperators(A)
    solver.getPC().setType(PETSc.PC.Type.SOR)
    solver.view()
    displacement = fe.fem.Function(V)
    for i in range(num_steps):
        p.value = pressure[i]
        with b.localForm() as loc_b:
            loc_b.set(0)
        assemble_vector(b, linear_form)
        apply_lifting(b, [bilinear_form], [[bc]])
        set_bc(b, [bc])
        # Solve linear problem
        solver.solve(b, displacement.vector)
        displacement.x.scatter_forward()
        # Update old fields with new quantities
        update_fields(displacement, old_u, old_velocity, old_acceleration, rotation_matrix, F)
if __name__ == "__main__":
    main()
