In a dynamic transversely isotropic material problem, I have defined a rotation matrix for each element. I suppose the rotation matrices need to be updated after each time step. But I have problems in doing so. I’ll show what I mean in the example below:
import dolfinx as fe
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem, assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
import os
def main(linear = True, time_dependent = True):
L = 1
W = 0.2
mesh = fe.mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
[20, 6, 6], cell_type=fe.mesh.CellType.hexahedron)
element = ufl.VectorElement("Lagrange", mesh.ufl_cell(), 1)
V = fe.fem.functionspace(mesh, element)
dt = fe.default_scalar_type(0.01)
num_steps = int(1/float(dt))
maximum_pressure = 15
minimum_pressure = 0
pressure = np.append(np.linspace(minimum_pressure, maximum_pressure, num=int(num_steps/2)),\
np.linspace(maximum_pressure, minimum_pressure, num=int(num_steps/2)))
p = fe.fem.Constant(mesh, pressure[0])
def clamped_boundary(x):
return np.isclose(x[0], 0)
fdim = mesh.topology.dim - 1
clamped_boundary_facets = fe.mesh.locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = np.array([0, 0, 0], dtype=fe.default_scalar_type)
bc = fe.fem.dirichletbc(u_D, fe.fem.locate_dofs_topological(V, fdim, clamped_boundary_facets), V)
boundaries = [(1, lambda x: np.isclose(x[0], L))]
facets = fe.mesh.locate_entities(mesh, fdim, locator)
facet_indices.append(facets)
facet_tag = fe.mesh.meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
##########################Defining the rotation matrix for each cell##################################
el_r = ufl.TensorElement("DG", mesh.ufl_cell(), 0, shape=(3, 3))
Q_r = fe.fem.FunctionSpace(mesh, el_r)
bs_r = Q_r.dofmap.bs
rotation_matrix = fe.fem.Function(Q_r)
def get_rotation_matrix(x):
values = np.zeros((bs_r, x.shape[1]), dtype=np.float64)
values[0] = 1
values[4] = 1
values[8] = 1
return values
rotation_matrix.interpolate(get_rotation_matrix)
#########################################Formulation##################################################
u = ufl.TrialFunction(V)
old_u = fe.fem.Function(V)
old_velocity = fe.fem.Function(V)
old_acceleration = fe.fem.Function(V)
d = len(u)
I = ufl.variable(ufl.Identity(d)) # Identity tensor
F = ufl.variable(I + ufl.grad(u)) # Deformation gradient
C = ufl.variable(F.T*F) # Right Cauchy-Green tensor
J = ufl.variable(ufl.det(F))
####Check out for the metadata
ds = ufl.Measure("ds", domain=mesh, subdomain_data=facet_tag, metadata=metadata)
dx = ufl.Measure("dx", domain=mesh, metadata=metadata)
# Generalized-alpha method parameters
alpha_m = fe.fem.Constant(mesh, 0.2)
alpha_f = fe.fem.Constant(mesh, 0.4)
gamma = fe.default_scalar_type(0.5+alpha_f-alpha_m)
beta = fe.default_scalar_type((gamma+0.5)**2/4.)
# Update formula for acceleration
# a = 1/(2*beta)*((u - u0 - v0*dt)/(0.5*dt*dt) - (1-2*beta)*a0)
def update_a(u, u_old, v_old, a_old, ufl=True):
if ufl:
dt_ = dt
beta_ = beta
dt_ = float(dt)
beta_ = float(beta)
return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
# Update formula for velocity
# v = dt * ((1-gamma)*a0 + gamma*a) + v0
def update_v(a, u_old, v_old, a_old, ufl=True):
if ufl:
dt_ = dt
gamma_ = gamma
dt_ = float(dt)
gamma_ = float(gamma)
return v_old + dt_*((1-gamma_)*a_old + gamma_*a)
def update_rotation(R, F):
new_rotation = ufl.dot(F,R)
return new_rotation
def update_fields(u_new, u_old, v_old, a_old, rotation_matrix, F):
"""Update fields at the end of each time step."""
# Get vectors (references)
u_vec, u0_vec = u_new.x.array[:], u_old.x.array[:]
v0_vec, a0_vec = v_old.x.array[:], a_old.x.array[:]
# use update functions using vector arguments
a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl=False)
v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl=False)
R_vec = update_rotation(rotation_matrix, F)
new_rotation_expression = fe.fem.Expression(R_vec, Q_r.element.interpolation_points())
rotation_matrix.interpolate(new_rotation_expression)
R_vec = rotation_matrix.x.array[:].reshape(num_cells_local, 3, 3)
# Update (u_old <- u)
v_old.x.array[:], a_old.x.array[:] = v_vec, a_vec
u_old.x.array[:] = u_new.x.array[:]
rotation_matrix.x.array[:] = R_vecs
def avg(x_old, x_new, alpha):
return alpha*x_old + (1-alpha)*x_new
normal = -ufl.FacetNormal(mesh)
rho = 1
E = fe.default_scalar_type(1.0e4)
nu = fe.default_scalar_type(0.3)
mu = fe.fem.Constant(mesh, E / (2 * (1 + nu)))
lmbda = fe.fem.Constant(mesh, E * nu / ((1 + nu) * (1 - 2 * nu)))
def S(u):
return 2.0 * mu * ufl.sym(ufl.grad(u)) + lmbda * ufl.tr(ufl.sym(ufl.grad(u))) * I
acceleration = update_a(u, old_u, old_velocity, old_acceleration, ufl=False)
velocity = update_v(acceleration, old_u, old_velocity, old_acceleration, ufl=True)
formulation = rho * ufl.inner(alpha_m*old_acceleration + (1-alpha_m)* acceleration, v) * dx \
+ ufl.inner(ufl.grad(v), S(avg(old_u, u, alpha_f))) * dx \
- ufl.inner(v, p * normal) * ds(1)
bilinear_form = fe.fem.form(ufl.lhs(formulation))
linear_form = fe.fem.form(ufl.rhs(formulation))
###############################################Solving################################################
A = assemble_matrix(bilinear_form, bcs=[bc])
b = create_vector(linear_form)
solver.setInitialGuessNonzero(True)
solver.setOperators(A)
solver.getPC().setType(PETSc.PC.Type.SOR)
solver.view()
displacement = fe.fem.Function(V)
for i in range(num_steps):
p.value = pressure[i]
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, linear_form)
apply_lifting(b, [bilinear_form], [[bc]])
set_bc(b, [bc])
# Solve linear problem
solver.solve(b, displacement.vector)
displacement.x.scatter_forward()
# Update old fields with new quantities
update_fields(displacement, old_u, old_velocity, old_acceleration, rotation_matrix, F)
if __name__ == "__main__":
main()
The rotation matrix (which I’ve set to the identity matrix initially for keeping it simple) get updated in the for loop at the end in the ‘update_fields’ function. But I get the error:
RuntimeError: Cannot interpolate Expression with Argument.
I will appreciate any hint.
