Use abs() function in a complex UFL form
Good evening,
I am trying to solve a coupled set of complex-valued PDE’s. These contain an absolute value of one of the functions to be solved. However, the complex ufl form which contains an abs() causes a compiler error. Note that the full problem uses abs(u)**2 which could be replaced with u*conj(u) (as in MWE) which is similarly illegal. This may be because the form is non-sesquillinear but I am unsure whether that is required with a non-linear solver. I get:
ValueError: not enough values to unpack (expected 2, got 1)
when running:
from ufl import dx, inner, grad, TestFunction, sqrt, conj
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[0, 0], [1, 1]], [10, 10], mesh.CellType.quadrilateral)
V = fem.functionspace(domain, ("Lagrange", 1))  # Scalar function space of degree 1
u = fem.Function(V, dtype=np.complex128)
u.x.array[:] = 0.0  # Initialize with zero
F = inner(grad(u), grad(v)) * dx + inner(u**2, v) * dx  # Generic math for illustration
# Add a complex term: For example, a complex coefficient in the non-linearity
F = F + 1j * inner(u*conj(u), v) * dx  # Possible alternative which also fails
# F = F + 1j * inner(u*u, v) * dx        # Regular non-linear term
# F = F + 1j * inner(abs(u)**2, v) * dx  # take the absolute value of a function
boundary_facets = mesh.locate_entities_boundary(domain, 1, lambda x: np.full(x.shape[1], True))
bc = fem.dirichletbc(1+0j, fem.locate_dofs_topological(V, 1, boundary_facets), V)
# Create the nonlinear problem and solver
problem = fem.petsc.NonlinearProblem(F, u, bcs = [bc])
solver.rtol = 1e-8
n, converged = solver.solve(u)
print("Solved the non-linear problem with complex terms.")
I would expect the abs() function to be usable within the UFL form when using a non-linear solver within the complex kernel. Any tips on why the above forms with u*conj(u) or abs(u)**2 are illegal would be greatly appreciated.
Thank you
I think its a similar issue to this:https://fenicsproject.discourse.group/t/nonlinear-complex-value-problem/13652
Will look into it a bit more to see if I can figure out how to approach it.
I managed to get it working by rewriting the complex variable as psi = a + b*j, expanding the grad, div, and curl operations over the real and complex parts, separating the real and complex parts and implementing the entire thing back in the real space with a non-linear solver. Unsure if this can be done in most cases.
Thanks
