Hey there,
Im trying to implement a time stepping algorithm for coupled differential equation. Whenever I implement F(u,udot,t)=0 everything seems to work fine. But trying to use setRHSFunction does not work. It seems to me that the solver just ignores G because the result does not change when I set G to zero. Am I making any obvious mistakes? Code example, below, thanks in advance!
from dolfinx import mesh, log
from dolfinx.fem import (functionspace, Constant, Function, locate_dofs_topological, dirichletbc, DirichletBC,
Expression, assemble_scalar, assemble_vector, apply_lifting, set_bc, form)
import dolfinx.fem.petsc as petsc
from basix.ufl import element
from ufl import derivative, dx, div, grad, inner, SpatialCoordinate, TrialFunction, TestFunction
class PETScTSSolver:
# F(t, u, u') = G(t, u)
def __init__(self, ts_problem, u, bcs):
self.u = u
self.V = u.ufl_function_space()
self.comm = self.V.mesh.comm
self.u_t = Function(self.V)
self.sigma_t = Constant(self.V.mesh, 0.0)
self.f = ts_problem.F(self.u, self.u_t)
self.g = ts_problem.G(self.u)
self.f_j = self.sigma_t * ts_problem.dFdut(self.u, self.u_t) + ts_problem.dFdu(self.u, self.u_t)
self.g_j = ts_problem.dGdu(self.u)
self.bcs = bcs
self.ts = PETSc.TS().create(self.comm)
def evalIFunction(self, ts, t, x, xdot, F):
r.interpolate(r_fun(t))
x.copy(self.u.x.petsc_vec)
xdot.copy(self.u_t.x.petsc_vec)
with F.localForm() as f_local:
f_local.set(0.0)
petsc.assemble_vector(F, form(self.f))
bc1_fun.interpolate(u_exact_fun(t))
bc2_fun.interpolate(u_exact_fun(t))
apply_lifting(F, a=[form(self.f_j)], bcs=[self.bcs], x0=[x], alpha=-1.0)
F.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
set_bc(F, self.bcs, self.u.x.petsc_vec, -1.0)
F.assemble()
return True
def evalRHSFunction(self, ts, t, x, G):
with G.localForm() as g_local:
g_local.set(0.0)
petsc.assemble_vector(G, form(self.g))
apply_lifting(G, a=[form(self.g_j)], bcs=[self.bcs], x0=[x], alpha=-1.0)
G.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
set_bc(G, self.bcs, self.u.x.petsc_vec, -1.0)
#G.set(0.0)
G.assemble()
return True
def evalIJacobian(self, ts, t, x, xdot, sigma_t, J, P):
self.sigma_t.value = sigma_t
J.zeroEntries()
petsc.assemble_matrix(J, form(self.f_j), self.bcs)
J.assemble()
return True
def set_from_options(self):
ksp = self.ts.getSNES().getKSP()
ksp.setType(PETSc.KSP.Type.PREONLY)
pc = ksp.getPC()
pc.setType(PETSc.PC.Type.LU)
ksp.setFromOptions()
pc.setFromOptions()
def solve(self, t0, dt_init, max_t, max_steps):
w = Function(self.V)
u_exact.x.petsc_vec.copy(w.x.petsc_vec)
#self.ts.setEquationType(1000)
self.ts.setRHSFunction(self.evalRHSFunction)
self.ts.setIFunction(self.evalIFunction)#, self.F.vec())
self.ts.setIJacobian(self.evalIJacobian)#, J=self.FJ.mat(), P=self.FJ.mat())
self.ts.setSolution(w.x.petsc_vec)
self.ts.setType(PETSc.TS.Type.ARKIMEX) # ARKIMEX
self.ts.setMaxTime(max_t)
self.ts.solve(w.x.petsc_vec)
w.x.petsc_vec.copy(self.u.x.petsc_vec)
# 1d geometry parameters
interval_length = 1
cells_number = 4
t = 0
msh = mesh.create_unit_interval(MPI.COMM_WORLD, cells_number)
CG1_elem = element("Lagrange", msh.basix_cell(), 1)
V = functionspace(msh, CG1_elem)
u_test = TestFunction(V)
tdim = msh.topology.dim
fdim = tdim - 1
boundary_conditions = [
(lambda x: np.isclose(x[0], 0), 'dof_bdry_1'),
(lambda x: np.isclose(x[0], 1), 'dof_bdry_2')
dof_boundaries = {}
for marker, dof_name in boundary_conditions:
facets_bdry = mesh.locate_entities_boundary(msh, dim=fdim, marker=marker)
dof_boundaries[dof_name] = locate_dofs_topological(V=V, entity_dim=fdim, entities=facets_bdry)
class u_exact_fun():
def __init__(self, t):
self.t = t
def __call__(self, x):
values = np.zeros((1, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = np.exp(-self.t) * x[0]**2
return values
class r_fun():
self.t = t
values[0] = -np.exp(-self.t) * (x[0]**2 + 2)
return values
class DiffusionProblem():
def F(self, u, u_t):
return u_t * u_test * dx #+ inner(grad(u), grad(u_test)) * dx - r * u_test * dx
def dFdu(self, u, u_t):
return derivative(self.F(u, u_t), u)
def dFdut(self, u, u_t):
return derivative(self.F(u, u_t), u_t)
def G(self, u):
return -inner(grad(u), grad(u_test)) * dx + r * u_test * dx
def dGdu(self, u):
return derivative(self.G(u), u)
u_exact = Function(V)
u_exact0 = Function(V)
u_exact.interpolate(u_exact_fun(t))
r = Function(V)
bc1_fun = Function(V)
bc1 = dirichletbc(bc1_fun, dof_boundaries['dof_bdry_1'])
bc2_fun = Function(V)
bc2 = dirichletbc(bc2_fun, dof_boundaries['dof_bdry_2'])
Dirichlet_bcs = [bc1, bc2]
fig, ax = plt.subplots()
PETScTSSolver_instance = PETScTSSolver(DiffusionProblem(), u, Dirichlet_bcs)
PETScTSSolver_instance.set_from_options()
PETScTSSolver_instance.solve(t0=0.0, dt_init=1e-3, max_t=10, max_steps=1000)
