Time-dependent mesh and nonlinear problem (PETSC Error after migrating from FEniCSX 0.7.2 to 0.8.0)
I am solving a time-dependent Cahn-Hilliard equation, where the mesh is re-defined in each time step.
A new mesh is created at each time step, and so is the problem definition.
I have a Minimal Working Example as follows, which works well using FEniCSX 0.7.2.
import os
from math import tanh
from ufl import dx, grad, inner, dot
from dolfinx import log, plot, fem
from dolfinx.fem import Function, functionspace
from dolfinx.io import VTKFile
from dolfinx.mesh import CellType, create_unit_square
log.set_output_file("log.out")
# Define parameters
lmbda = 1.0e-4  # non-local energy parameter
alpha = 1.0e+0 # local energy parameter
xi = (lmbda/(2.0*alpha))**0.5  # diffuse-interface thickness
mcoef = 1.0e-2 # mobility
dt = 5.0e-03  # time step
T = 20 * dt # terminal time
t = 0.0 # current time
# Create mesh
msh = create_unit_square(MPI.COMM_WORLD, 10, 10, CellType.triangle)
# define finite element
P2 = element("Lagrange", msh.basix_cell(), 2)
# define mixed finite element and function space for c and mu
ME = mixed_element([P2, P2])
W = functionspace(msh, ME)
# define Test functions
(q, v) = ufl.TestFunctions(W)
# define Solutions
u = Function(W)  # current solution
u0 = Function(W)  # solution from previous converged step
# Split mixed functions
c, mu = ufl.split(u)
c0, _ = ufl.split(u0)
# Interpolate initial condition for c
def ellips(x):
    radi = 0.3
    x0 = 0.5
    y0 = 0.5
    r = ( - ( (x[0]-x0)**2 + 4.0*(x[1]-y0)**2 )**0.5 + radi ) / (2.0 * xi)
    c = 0.5*( np.tanh(r) + 1.0 )
    return c
u0.sub(0).interpolate(ellips)
u0.x.scatter_forward()
# define nonlinear problem
dfdc = 2.0 * alpha * c * ( 1.0 - c ) * ( 1.0 - 2.0 * c )
F0 = dt * mcoef * inner(grad(mu), grad(q)) * dx
F0 += inner(c, q) * dx - inner(c0, q) * dx
F1 = inner(mu, v) * dx - inner(dfdc, v) * dx - lmbda * inner(grad(c), grad(v)) * dx
F = F0 + F1
problem = NonlinearProblem(F, u)
# define Newton solver
solver.rtol = 1e-6
# Customize the linear solver used inside the NewtonSolver by
# modifying the PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
# write vtk files
ch = u0.sub(0).collapse()
ch.name="c"
muh = u0.sub(1).collapse()
muh.name="mu"
vtk = VTKFile(MPI.COMM_WORLD, "output1/cmu.pvd", "w")
vtk.write_function([ch,muh], 0)
# time stepping
step = 0
while (t < T):
    step += 1
    # solve
    r = solver.solve(u)
    print(f"Step {step}: num iterations: {r[0]}")
    # new mesh msh2
    msh2 = create_unit_square(MPI.COMM_WORLD, 10+step, 10+step, CellType.triangle)
    # define Functions in msh2
    P2_2 = element("Lagrange", msh2.basix_cell(), 2)
    ME_2 = mixed_element([P2_2, P2_2])
    W_2 = functionspace(msh2, ME_2)
    X_2 = functionspace(msh2, P2_2)
    c_2 = Function(X_2)
    c0_2 = Function(X_2)
    mu_2 = Function(X_2)
    mu0_2 = Function(X_2)
    # project solution u defined in msh to Functions in msh2
    c_interpolation_data = fem.create_nonmatching_meshes_interpolation_data(
        c_2.function_space.mesh._cpp_object,
        c_2.function_space.element,
        u.sub(0).function_space.mesh._cpp_object,
        padding=1.e-10)
    mu_interpolation_data = fem.create_nonmatching_meshes_interpolation_data(
        mu_2.function_space.mesh._cpp_object,
        mu_2.function_space.element,
        u.sub(1).function_space.mesh._cpp_object,
        padding=1.e-10)
    c0_2.interpolate(u.sub(0), nmm_interpolation_data=c_interpolation_data)
    mu0_2.interpolate(u.sub(1), nmm_interpolation_data=mu_interpolation_data)
    # create mesh and function
    msh = msh2
    P2 = P2_2
    ME = ME_2
    W = W_2
    u = Function(W_2)
    u0 = Function(W_2)
    # interpolate previous solution u0
    u0.sub(0).interpolate(c0_2)
    u0.sub(1).interpolate(mu0_2)
    # Test functions
    # q for c and v for mu
    # split u into c and mu
    F = F0 + F1
    # define newton solver
    solver = NewtonSolver(MPI.COMM_WORLD, problem) ## PETSC ERROR
    solver.rtol = 1e-6
    # define c and mu from u to write output files
    ch.name="c"
    muh.name="mu"
    # write files
    vtk.write_function([ch, muh], t)
# close files
vtk.close()
As I migrate to FEniCSX 0.8.0, I have made only small updates in the code as follows.
However, it returns an PETSC Error in the middle of the time step, in a random way.
import os
# Define parameters
# Create mesh
# define Solutions
def ellips(x):
    radi = 0.3
    x0 = 0.5
    y0 = 0.5
    return c
F = F0 + F1
solver.rtol = 1e-6
# write vtk files
ch.name="c"
muh.name="mu"
# time stepping
step = 0
while (t < T):
    step += 1
    # solve
    r = solver.solve(u)
    # new mesh msh2
    c_2 = Function(X_2)
        c_2.function_space.mesh,
        u.sub(0).function_space.mesh,
        padding=1.e-10)
        mu_2.function_space.mesh,
        u.sub(1).function_space.mesh,
        padding=1.e-10)
    msh = msh2
    P2 = P2_2
    ME = ME_2
    W = W_2
    u = Function(W_2)
    u0 = Function(W_2)
    # Test functions
    F = F0 + F1
    solver.rtol = 1e-6
    ch.name="c"
    muh.name="mu"
    # write files
# close files
vtk.close()
Can anyone help with this issue?
The original one works well with FEniCSX 0.7.2, but the updated one for FEniCSX 0.8.0 produces an PETSC Error in the middle of time step in a random way.
Could you try v0.9.0?
Thanks Dokken!, it is working fine on v0.9.0.
The updated code for v0.9.0 is as follows, for anyone who might find it interesting.
import os
# Define parameters
# Create mesh
# define Solutions
def ellips(x):
    radi = 0.3
    x0 = 0.5
    y0 = 0.5
    return c
F = F0 + F1
solver.rtol = 1e-6
# write vtk files
ch.name="c"
muh.name="mu"
# time stepping
step = 0
while (t < T):
    step += 1
    # solve
    r = solver.solve(u)
    # new mesh msh2
    cmap = msh2.topology.index_map(msh2.topology.dim)
    num_cells = cmap.size_local + cmap.num_ghosts
    all_cells = np.arange(num_cells, dtype=np.int32)
    c_2 = Function(X_2)
    c_interpolation_data = fem.create_interpolation_data(
        c_2.function_space,
        u.sub(0).function_space,
        all_cells,
        padding=1.e-10)
    mu_interpolation_data = fem.create_interpolation_data(
        mu_2.function_space,
        u.sub(1).function_space,
        all_cells,
        padding=1.e-10)
    c0_2.interpolate_nonmatching(u.sub(0), all_cells, interpolation_data=c_interpolation_data)
    mu0_2.interpolate_nonmatching(u.sub(1), all_cells, interpolation_data=mu_interpolation_data)
    msh = msh2
    P2 = P2_2
    ME = ME_2
    W = W_2
    u = Function(W_2)
    u0 = Function(W_2)
    # Test functions
    F = F0 + F1
    solver.rtol = 1e-6
    ch.name="c"
    muh.name="mu"
    # write files
# close files
vtk.close()
