Currently I am porting an old application code from Fenics (2019.1.0) to new Fenicsx.
The versions of the libraries I used are as follows:
dolfinx : 0.7.2
ufl: 2023.2.0
ffcx: 0.7.0
I compiled and built these programs from source which I obtained from Fenics git repository.
In my code I would like to use a symmetric trace-free tensor to represent stress tensor. UFL library does allow symmetric tensor flag. When I execute the following MWE code
import dolfinx as dfx
import ufl as ufl
mesh_dfx = dfx.mesh.create_unit_cube(MPI.COMM_WORLD, 8, 8, 8,
dfx.mesh.CellType.tetrahedron
# create 2 finite elements
# Velocity u (vector),
u_elem = ufl.VectorElement("Lagrange", mesh_dfx.ufl_cell(), 1)
# Stress sigma (Tensor)
# Variable sigma should be symmetric and trace-free.
# UFL library allows me to create symmetric tensor with a flag `symmetric`.
#NOTE: With symmetry - CODE RETURNS AN ERROR
sigma_elem = ufl.TensorElement("Lagrange", mesh_dfx.ufl_cell(),1, symmetry=True)
# Without symmetry - SEEMS TO RUN WITHOUT ERROR
#sigma_elem = ufl.TensorElement("Lagrange", mesh_dfx.ufl_cell(),1)
# create mixed finite element vector space
mxd_fspace = dfx.fem.FunctionSpace(mesh_dfx,
ufl.MixedElement([u_elem, sigma_elem ])
# setup trial and test functions
(u, sigma) = ufl.TrialFunctions(mxd_fspace)
(v, psi ) = ufl.TestFunctions(mxd_fspace)
# Convert symmetric tensor to symmetric-and-trace-free tensor
# using the following custom function
def gen3DTFdim3(sigma):
return ufl.as_tensor([
[sigma[0, 0], sigma[0, 1], sigma[0, 2]],
[sigma[1, 0], sigma[1, 1], sigma[1, 2]],
[sigma[2, 0], sigma[2, 1], -sigma[0, 0] - sigma[1, 1]]]
sigma = gen3DTFdim3(sigma)
psi = gen3DTFdim3(psi)
# For the purpose of demonstration I include only one term
# from the actual weak formulation of my problem.
a = ufl.dot(ufl.div(sigma), v) * ufl.dx
print(dfx.fem.assemble_scalar(dfx.fem.form(a)))
results in the following error
File "/home/sysadmin/py/fenicsxR13/demo_symTensor_unitCube.py", line 43, in <module>
File "/home/sysadmin/.local/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 188, in form
return _create_form(form)
File "/home/sysadmin/.local/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 183, in _create_form
return _form(form)
File "/home/sysadmin/.local/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 141, in _form
File "/home/sysadmin/.local/lib/python3.10/site-packages/dolfinx/jit.py", line 56, in mpi_jit
File "/home/sysadmin/.local/lib/python3.10/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 199, in compile_forms
raise e
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 190, in compile_forms
impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 260, in _compile_objects
_, code_body = ffcx.compiler.compile_ufl_objects(ufl_objects, prefix=module_name, options=options)
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/compiler.py", line 102, in compile_ufl_objects
ir = compute_ir(analysis, object_names, prefix, options, visualise)
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/representation.py", line 197, in compute_ir
irs = [_compute_integral_ir(fd, i, analysis.element_numbers, integral_names, finite_element_names,
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/representation.py", line 197, in <listcomp>
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/representation.py", line 492, in _compute_integral_ir
integral_ir = compute_integral_ir(itg_data.domain.ufl_cell(), itg_data.integral_type,
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/integral.py", line 72, in compute_integral_ir
S = build_scalar_graph(expression)
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/analysis/graph.py", line 80, in build_scalar_graph
scalar_expressions = rebuild_with_scalar_subexpressions(G)
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/analysis/graph.py", line 125, in rebuild_with_scalar_subexpressions
V_symbols = value_numberer.compute_symbols()
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/analysis/valuenumbering.py", line 68, in compute_symbols
symbol = f(expr)
File "/home/sysadmin/.local/lib/python3.10/site-packages/ffcx/ir/analysis/valuenumbering.py", line 184, in _modified_terminal
raise RuntimeError("Internal error in value numbering.")
RuntimeError: Internal error in value numbering.
I have read few posts in this forum regarding the erroneous behaviour of ufl when symmetric flag used. However, the error message mentioned in each post seems to be different from one another. Therefore, I’ve posted mine here.
I would like to know how can I fix this problem? Can I use any other version of dolfinx/ufl/ffcx combination to circumvent this error?
Thanks for reading my post!
