Using dolfinx_mpc in generalised plain strain formulation
Hello, I wish to implement create_slip_constraint from dolfinx_mpc on the generalized plane strain case. The left and bottom edges are allowed to slide tangentially but not normally.
I am stuck in the part dolfinx.fem.petsc.assemble_matrix_block implementation with mpc. A guidance will be quite helpful. Here is my code below.
from dolfinx import fem, io, plot
import dolfinx.fem.petsc
from dolfinx.cpp.la.petsc import get_local_vectors
from scifem import create_real_functionspace
from dolfinx_mpc.utils import (create_point_to_point_constraint, determine_closest_block, rigid_motions_nullspace, facet_normal_approximation)
from dolfinx_mpc import LinearProblem, MultiPointConstraint
hsize = 0.2
Re = 11.0
Ri = 9.0
gmsh.option.setNumber("General.Terminal", 0)  # to disable meshing info
gdim = 2
model_rank = 0
gmsh.model.add("Model")
geom = gmsh.model.geo
center = geom.add_point(0, 0, 0)
p1 = geom.add_point(Ri, 0, 0)
p2 = geom.add_point(Re, 0, 0)
p3 = geom.add_point(0, Re, 0)
p4 = geom.add_point(0, Ri, 0)
x_radius = geom.add_line(p1, p2)
outer_circ = geom.add_circle_arc(p2, center, p3)
y_radius = geom.add_line(p3, p4)
inner_circ = geom.add_circle_arc(p4, center, p1)
boundary = geom.add_curve_loop([x_radius, outer_circ, y_radius, inner_circ])
surf = geom.add_plane_surface([boundary])
geom.synchronize()
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", hsize)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", hsize)
gmsh.model.addPhysicalGroup(gdim, [surf], 1)
gmsh.model.addPhysicalGroup(gdim - 1, [x_radius], 1, name="bottom")
gmsh.model.addPhysicalGroup(gdim - 1, [y_radius], 2, name="left")
gmsh.model.addPhysicalGroup(gdim - 1, [outer_circ], 3, name="outer")
domain, _, facets = io.gmshio.model_to_mesh(
    gmsh.model, MPI.COMM_WORLD, model_rank, gdim=gdim
gmsh.finalize()
def eps(v, ezz):
    return ufl.sym(
        ufl.as_tensor(
                [v[0].dx(0), v[0].dx(1), 0],
                [v[1].dx(0), v[1].dx(1), 0],
                [0, 0, ezz],
E = fem.Constant(domain, 1e5)
nu = fem.Constant(domain, 0.3)
mu = E / 2 / (1 + nu)
lmbda = E * nu / (1 + nu) / (1 - 2 * nu)
def sigma(v, ezz):
    return lmbda * ufl.tr(eps(v, ezz)) * ufl.Identity(3) + 2.0 * mu * eps(v, ezz)
def eps(v, ezz):
    return ufl.sym(
        ufl.as_tensor(
                [0, 0, ezz],
def sigma(v, ezz):
# Define Function Space
degree = 2
V = fem.functionspace(domain, ("P",degree, (gdim,)))
R = create_real_functionspace(domain)
W = MixedFunctionSpace(V, R)
# Define Variational Problem
du, dezz = TrialFunctions(W)
u_, ezz_ = TestFunctions(W)
#u = fem.Function(V, name = "Displacement")
a_form = inner(sigma(du, dezz), eps(u_, ezz_)) * dx
T = fem.Constant(domain, 1000000.0)
#Self-weight on the surface
n = FacetNormal(domain)
ds = Measure("ds", domain=domain, subdomain_data=facet_markers)
dx = Measure("dx", domain=domain, subdomain_data=cell_markers)
dS = Measure("dS", domain=domain, subdomain_data=facet_markers)
L_form = dot(T*n,u_) * ds(3)
a_blocked_compiled = fem.form(extract_blocks(a_form))
L_blocked_compiled = fem.form(extract_blocks(L_form))
# Get the facet markers for boundary edges (ps1 and ps2)
mpc = MultiPointConstraint(V)
for tag in [1, 2]:  # ps1 and ps2
    normal_vec = create_normal_approximation(V, facet_markers, tag)
    mpc.create_slip_constraint(V, (facet_markers, tag), normal_vec)
mpc.finalize()
a_blocked_compiled = fem.form(ufl.extract_blocks(a_form))
L_blocked_compiled = fem.form(ufl.extract_blocks(L_form))
after this part I am stuck and need your guidance.
A = dolfinx.fem.petsc.assemble_matrix_block(a_blocked_compiled, bcs=bcs)
b = dolfinx.fem.petsc.assemble_vector_block(
    L_blocked_compiled, a_blocked_compiled, bcs=bcs
ksp = PETSc.KSP().create(domain.comm)
ksp.setOperators(A)
ksp.setType("preonly")
pc = ksp.getPC()
pc.setType("lu")
# solve system
xh = dolfinx.fem.petsc.create_vector_block(L_blocked_compiled)
ksp.solve(b, xh)
xh.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
maps = [(Wi.dofmap.index_map, Wi.dofmap.index_map_bs) for Wi in W.ufl_sub_spaces()]
u = fem.Function(V, name="Displacement")
x_local = get_local_vectors(xh, maps)
u.x.array[: len(x_local[0])] = x_local[0]
u.x.scatter_forward()
ezz = x_local[1][0]
Block-assembly is not implemented in DOLFINx_MPC, only nest assembly:
which can use direct solvers, as illustrated in:
On the main branch of DOLFINx_MPC the nest interface has gotten a serious face-lift:
which makes it way easier to use than it was previously.
I tried implement your suggestions for this geometry but I am getting some errors. I think there is some syntax mistake. Your intervention will be helpful here. Here is the geometry and my code.
// Gmsh project created on Tue May  6 11:35:50 2025
Point(1) = {0, 0.509795579104159, 0, 1.0};
Point(2) = {0.195090322016128, 0.470989701299072, 0, 1.0};
Point(3) = {0, 1.01959115820832, 0, 1.0};
Point(4) = {0.390180644032256, 0.941979402598143, 0, 1.0};
Line(1) = {1, 2};
Line(2) = {2, 4};
Line(3) = {4, 3};
Line(4) = {3, 1};
Curve Loop(1) = {4, 1, 2, 3};
Surface(1) = {1};
Physical Curve("ps1", 5) = {2};
Physical Curve("ps2", 6) = {4};
Physical Curve("bottom", 7) = {1};
Physical Curve("top", 8) = {3};
Physical Surface("my_surf", 9) = {1};
Show "*";
my code
import os
import math
import sys
from dolfinx.cpp.mesh import to_type, cell_entity_type
from dolfinx import (mesh, fem, io, common, default_scalar_type, geometry, plot)
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector, set_bc
from dolfinx.io import VTXWriter, distribute_entity_data, gmshio
from dolfinx.mesh import create_mesh, meshtags_from_entities
from dolfinx.io import XDMFFile, VTKFile
from ufl import (FacetNormal, as_matrix, as_tensor, extract_blocks, Identity, Measure, TestFunctions, tr, TrialFunctions, as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym, MixedFunctionSpace)
from dolfinx_mpc.utils import (create_point_to_point_constraint, determine_closest_block, rigid_motions_nullspace, facet_normal_approximation, create_normal_approximation, gather_transformation_matrix, gather_PETScMatrix, gather_PETScVector)
from packaging.version import Version
from dolfinx.cpp.la.petsc import scatter_local_vectors, get_local_vectors
from scifem import create_real_functionspace, assemble_scalar
from scifem.petsc import apply_lifting_and_set_bc, zero_petsc_vector
# Material properties
E = fem.Constant(domain, 200e9)       # Young's modulus
nu = fem.Constant(domain, 0.3)        # Poisson's ratio
lmbda = E * nu / ((1 + nu)*(1 - 2*nu))
mu = E / (2*(1 + nu))
# Strain with plane strain + extra ezz
def eps(u, ezz):
    return sym(as_tensor([
        [u[0].dx(0), u[0].dx(1), 0],
        [u[1].dx(0), u[1].dx(1), 0],
        [0, 0, ezz]
def sigma(u, ezz):
    return lmbda * tr(eps(u, ezz)) * Identity(3) + 2 * mu * eps(u, ezz)
# Function spaces: V for displacement, R for scalar ezz
degree = 2
V = fem.functionspace(domain, ("P", degree, (2,)))
# Trial and test functions
(du, dezz) = TrialFunctions(W)
(v, vezz) = TestFunctions(W)
zero_vec = fem.Constant(domain, PETSc.ScalarType((0.0, 0.0)))
# Variational forms
a00 = inner(sigma(du, 0), eps(v, 0)) * dx
a01 = inner(sigma(zero_vec, dezz), eps(v, 0)) * dx
a10 = inner(sigma(du, 0), eps(zero_vec, vezz)) * dx
a11 = inner(sigma(zero_vec, dezz), eps(zero_vec, vezz)) * dx
T = fem.Constant(domain, PETSc.ScalarType((0.0, 1e6)))
L0 = inner(T, v) * ds
L1 = fem.Constant(domain, PETSc.ScalarType(0.0)) * vezz * dx
# Assemble nested matrix and vector
a = [[a00, a01], [a10, a11]]
L = [L0, L1]
a_compiled = fem.form(a)
L_compiled = fem.form(L)
# Slip constraints on selected facets (example facets 5 and 6)
for tag in [5, 6]:  # ps1 and ps2
mpc.finalize()
# Assemble matrix WITHOUT mpc argument
A = assemble_matrix(a_compiled, bcs=[])
# Assemble RHS vector
b = assemble_vector(L_compiled)
apply_lifting(b, [a_compiled], bcs=[])
set_bc(b, [])
# Create and setup solver
ksp = PETSc.KSP().create(A.getComm())
ksp.setOperators(A)
ksp.getPC().setType("lu")
ksp.getPC().setFactorSolverType("mumps")
# Solve system
X = A.createVecRight()
ksp.solve(b, X)
# Split solution vector
x_u, x_ezz = X.getNestSubVecs()
# Distribute solution to function space
u_sol = fem.Function(mpc.function_space)
mpc.distribute_solution(x_u, u_sol.vector)
ezz_sol = x_ezz.array
Depending on your DOLFINx version, you need to:
Stable/0.9.0
  1. Load your geometry as usual (you have omitted this part of the code)
  2. Create the two function spaces V, R
  3. Create MPC on V
  4. Use the assembly procedure from dolfinx_mpc/python/demos/demo_stokes_nest.py at v0.9.2 · jorgensd/dolfinx_mpc · GitHub
  5. Create your ksp object as in: dolfinx_mpc/python/demos/demo_stokes_nest.py at v0.9.2 · jorgensd/dolfinx_mpc · GitHub
Main branch
Step 1-3 are the same.
4-5. Use dolfinx_mpc.LinearProblem or dolfinx_mpc.NonLinearProblem as described in: dolfinx_mpc/python/demos/demo_stokes_nonlinear_nest.py at main · jorgensd/dolfinx_mpc · GitHub
Hello @dokken, I have some doubts regarding this topic. I want to combine the “lagrange multipliers” from the real spaces (scifem package) with the periodic boundary conditions (dolfinx_mpc package). I have seen that in some recent posts (Non-linear blocked newton solver with real spaces #93) you managed to make it work for a non-linear problem but using block-assembly. Can this be done with nest assembly since
Thank you in advance.
Yes, it can be done. One has to make a custom implementation of the assemble_residual required by the Newton-solver, but it is possible.
Ok, thank you very much for the information. So, to make it clear, I should combine the assemble_residual_mpc from dolfinx_mpc/problem.py with the _assemble_residual of scifem/solvers.py, right?
Hello @dokken , as per your suggestions, I tried the implementation with some modifications, I am able to get better results but my plot quality are not coming so well. I feel my interpolation seems to be a problem. I am using vtk and xdmf formats for plotting.
Here is my code for your reference:
from dolfinx_mpc.utils import (create_point_to_point_constraint, determine_closest_block, rigid_motions_nullspace, gather_PETScMatrix, gather_PETScVector, gather_transformation_matrix, facet_normal_approximation)
import os
from scipy.sparse.linalg import spsolve
from scipy.sparse import bmat
from ufl import (FacetNormal, Identity, Measure, TestFunctions, TrialFunctions, as_tensor,
                 dot, dx, ds, inner, sym, tr)
from dolfinx import fem, io, mesh
from dolfinx.io import VTKFile
from dolfinx.fem import form, Function, Constant
from dolfinx.fem.petsc import (assemble_matrix, assemble_vector, apply_lifting, set_bc)
# Geometry parameters
hsize = 0.2
Re, Ri = 11.0, 9.0
# Gmsh geometry
model_rank = 0
geom.synchronize()
# Mesh settings
gmsh.model.addPhysicalGroup(2, [surf], 1)
gmsh.model.addPhysicalGroup(1, [x_radius], 1, name="bottom")
gmsh.model.addPhysicalGroup(1, [y_radius], 2, name="left")
gmsh.model.addPhysicalGroup(1, [outer_circ], 3, name="outer")
# Generate and load mesh
gmsh.model.mesh.generate(2)
domain, cell_tags, facet_tags = io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank, gdim=2)
gmsh.finalize()
degree = 2
gdim = domain.topology.dim
V = fem.functionspace(domain, ("P", degree, (gdim,)))
from basix.ufl import mixed_element
W = fem.functionspace(domain, mixed_element([V.ufl_element(), R.ufl_element()]))
# Material parameters
E = Constant(domain, 1e5)
nu = Constant(domain, 0.3)
lmbda = E * nu / ((1 + nu) * (1 - 2 * nu))
mu = E / (2 * (1 + nu))
# Kinematics
def eps(v, ezz):
    return sym(as_tensor([[v[0].dx(0), v[0].dx(1), 0],
                          [0, 0, ezz]]))
def sigma(v, ezz):
    return lmbda * tr(eps(v, ezz)) * Identity(3) + 2 * mu * eps(v, ezz)
# Mixed trial and test functions
(u_, ezz_) = TestFunctions(W)
# Slip MPC setup
for tag in [1, 2]:
    n_vec = create_normal_approximation(V, facet_tags, tag)
    mpc.create_slip_constraint(V, (facet_tags, tag), n_vec, bcs=[])
mpc.finalize()
# Bilinear and linear forms
T = Constant(domain, 1e1)
ds = Measure("ds", domain=domain, subdomain_data=facet_tags)
L_form = dot(T * FacetNormal(domain), u_) * ds(3)
# Assemble system
A_org = assemble_matrix(form(a_form))
A_org.assemble()
L_org = assemble_vector(form(L_form))
apply_lifting(L_org, [form(a_form)], [[]])
L_org.ghostUpdate(PETSc.InsertMode.ADD_VALUES, PETSc.ScatterMode.REVERSE)
set_bc(L_org, [])
# Gather to root
root = 0
A_csr = gather_PETScMatrix(A_org, root=root)
L_np = gather_PETScVector(L_org, root=root)
K = gather_transformation_matrix(mpc, root=root)
# Solve reduced system
if MPI.COMM_WORLD.rank == root:
    # Split matrix and vector
    Ve = W.sub(0).collapse()[0]
    Re = W.sub(1).collapse()[0]
    offset = Ve.dofmap.index_map.size_local * Ve.dofmap.index_map_bs
    A00 = A_csr[:offset, :offset]
    A01 = A_csr[:offset, offset:]
    A10 = A_csr[offset:, :offset]
    A11 = A_csr[offset:, offset:]
    L0 = L_np[:offset]
    L1 = L_np[offset:]
    # Build reduced block system
    K0 = K
    KTAK = bmat([[K0.T @ A00 @ K0, K0.T @ A01],
                 [A10 @ K0,        A11]])
    rhs_reduced = np.concatenate([K0.T @ L0, L1])
    # Solve
    d = spsolve(KTAK, rhs_reduced)
    uh_full = np.concatenate([K0 @ d[:K0.shape[1]], d[K0.shape[1]:]])
    uh_full = None
uh_full = MPI.COMM_WORLD.bcast(uh_full, root=root)
uh = Function(Ve, name="Displacement")
ezzh = Function(Re, name="Ezz")
uh.x.array[:] = uh_full[:offset]
ezzh.x.array[:] = uh_full[offset:offset + ezzh.x.array.size]
uh.x.scatter_forward()
ezzh.x.scatter_forward()
# Output strain/stress
TensorSpace = fem.functionspace(domain, ("DG", 0, (3, 3)))
strain_func = fem.Function(TensorSpace, name="strain")
stress_func = fem.Function(TensorSpace, name="stress")
# Define expressions
strain_expr = eps(uh, ezzh)
stress_expr = sigma(uh, ezzh)
# Interpolate
strain_func.interpolate(fem.Expression(strain_expr, TensorSpace.element.interpolation_points()))
stress_func.interpolate(fem.Expression(stress_expr, TensorSpace.element.interpolation_points()))
# Write results
if MPI.COMM_WORLD.rank == 0 and not os.path.exists("results"):
    os.makedirs("results")
MPI.COMM_WORLD.barrier()
with VTKFile(domain.comm, "results/gen_plane_strain.pvd", "w") as vtk:
    vtk.write_function(uh)
    vtk.write_function(ezzh)
    vtk.write_function(strain_func)
    vtk.write_function(stress_func)
Here you can see the displacement plot.
Thank You @dokken for guidance, I could finally solve it. :blush:
Hello @dokken, sorry for repeating myself. I have seen that i did not properly tagged you in the reply. Is this correct?
Blockquote Ok, thank you very much for the information. So, to make it clear, I should combine the assemble_residual_mpc from dolfinx_mpc/problem.py with the _assemble_residual of scifem/solvers.py, right?
Thank you very much in advance.
Yes, that would be what needs to be done
