Hi, I am trying to divide my boundaries but when I do that I am having a warning. I shared my code below. Thank you!
from dolfin_adjoint import *
ffc_options = {"optimize": True,
"eliminate_zeros": True,
"precompute_basis_const": True,
"precompute_ip_const": True}
a = 1
t = 1
lc = 1
h = 1
x_dir, y_dir = 1, 1
scale = 1
normal = Constant((0, 1, 0))
def createGeometryAndMesh(a, t, lc):
# Clear all models and create a new one
gmsh.clear()
gmsh.model.add("t3")
def geopoints(dx, dy, surf_point):
P1 = gmsh.model.occ.addPoint(0 + dx, dy, 0, lc)
P2 = gmsh.model.occ.addPoint(t + dx, dy, 0, lc)
P3 = gmsh.model.occ.addPoint(dx, h + dy, 0, lc)
P4 = gmsh.model.occ.addPoint(t + dx, h + dy, 0, lc)
L1 = gmsh.model.occ.addLine(P1, P2)
L2 = gmsh.model.occ.addLine(P2, P4)
L3 = gmsh.model.occ.addLine(P4, P3)
L4 = gmsh.model.occ.addLine(P3, P1)
Curve1 = gmsh.model.occ.addCurveLoop([L1, L2, L3, L4])
Surface1 = gmsh.model.occ.addPlaneSurface([Curve1], 11 + surf_point)
return Surface1
def rectangularbt(dx, dy, surf_point):
P50 = gmsh.model.occ.addPoint(-0, scale * 0 + h, 0, lc)
P60 = gmsh.model.occ.addPoint(scale * -0, scale * 0 + h + a, 0, lc)
P70 = gmsh.model.occ.addPoint(scale * (0 + dx + t), scale * 0 + h + a, 0, lc)
P80 = gmsh.model.occ.addPoint(scale * (0 + dx + t), scale * 0 + h, 0, lc)
L50 = gmsh.model.occ.addLine(P50, P80)
L60 = gmsh.model.occ.addLine(P80, P70)
L70 = gmsh.model.occ.addLine(P70, P60)
L80 = gmsh.model.occ.addLine(P60, P50)
Curve6 = gmsh.model.occ.addCurveLoop([L50, L60, L70, L80])
Surface6 = gmsh.model.occ.addPlaneSurface([Curve6], 50 + surf_point)
return Surface6
# Entity creation operations
SurfaceA = geopoints(0, 0, 2000)
SurfaceRb = rectangularbt(x_dir, y_dir, 6000)
gmsh.model.occ.synchronize()
frag, frag_map = gmsh.model.occ.fragment(
[(2, SurfaceRb)],
[(2, SurfaceA)],
print("frag :", frag)
print("frag_map:", frag_map)
# One group for each of the unit squares
for i in range(1, len(frag_map)):
print(" [frag_map[i][0][1]]", [frag_map[i][0][1]])
pg1 = gmsh.model.addPhysicalGroup(2, [frag_map[i][0][1]])
gmsh.model.setPhysicalName(2, pg1, f"main_geometry{i - 1}")
# One group for the top and middle rectangles (frag_map[0] and frag_map[1])
pg2 = gmsh.model.addPhysicalGroup(2, [frag_map[0][0][1]])
gmsh.model.setPhysicalName(2, pg2, "filled_geometry")
# Set mesh size at all points
gmsh.model.mesh.setSize(gmsh.model.getEntities(0), lc)
gmsh.option.setNumber("Mesh.MshFileVersion", 2.2)
gmsh.model.mesh.generate()
gmsh.write("./Result--" + "geoforstl" + ".geo_unrolled")
gmsh.write("./Result--" + "geo.msh")
# colors:
gmsh.option.setNumber("Geometry.PointNumbers", 1)
gmsh.option.setColor("Geometry.Points", 255, 165, 0)
gmsh.option.setColor("General.Text", 255, 255, 255)
gmsh.option.setColor("Mesh.Points", 255, 0, 0)
rr, gg, bb, aaa = gmsh.option.getColor("Geometry.Points")
gmsh.option.setColor("Geometry.Surfaces", rr, gg, bb, aaa)
gmsh.onelab.set("""[
{"type":"number",
"name":"Parameters/Twisting angle",
"values":[90],
"min":0,
"max":120,
"step":1}]""")
def checkForEvent():
action = gmsh.onelab.getString("ONELAB/Action")
if len(action) and action[0] == "check":
gmsh.onelab.setString("ONELAB/Action", [""])
createGeometryAndMesh()
gmsh.graphics.draw()
return True
# Refine the mesh
gmsh.model.mesh.refine()
gmsh.write("t3.opt");
gmsh.finalize()
# Importing mesh from gmsh and defining surface and boundary markers
msh = meshio.read("./Result--" + "geo.msh")
if key == "triangle":
for cell in msh.cells:
if cell.type == "tetra":
tetra_cells = cell.data
elif cell.type == "triangle":
triangle_cells = cell.data
triangle_mesh = meshio.Mesh(points=msh.points,
cell_data={"name_to_read": [triangle_data]})
meshio.write("./Result--" + "mesh.xdmf",
triangle_mesh)
mesh = Mesh()
infile.read(mesh)
print(mesh.topology().dim() - 1)
File("./Result--" + "MSH.pvd") << mesh
File("./Result--" + "/MSH.pvd") << mesh
File("./Result--" + "MSH2.pvd") << mf
File("./Result--" "/MSH2" ".pvd") << mf
boundary_markers = MeshFunction('size_t', mesh, mesh.topology().dim() - 1, 0)
class Boundary(SubDomain):
return on_boundary and near(x[1], 0.0)
b_c = Boundary()
b_c.mark(boundary_markers, 3)
File("./Result--" + "MSH3.pvd") << boundary_markers
# Compiling subdomains
dx_A = Measure("dx", domain=mesh, subdomain_data=mf, subdomain_id=2)
dx_C = Measure("dx", domain=mesh, subdomain_data=mf, subdomain_id=1)
dx_main = Measure("dx", domain=mesh, subdomain_data=mf, subdomain_id=3)
V = VectorFunctionSpace(mesh, "CG", 2) # Lagrange
W_tensor = TensorFunctionSpace(mesh, "CG", 2)
V_tensor = TensorFunctionSpace(mesh, "CG", 2)
W = FunctionSpace(mesh, "R", 0)
# Define functions
du = TrialFunction(V) # Incremental displacement
v = TestFunction(V) # Test function
u = Function(V) # Displacement from previous iteration
u0 = Function(V) # Initial displacement
def boundary_bot(x, on_boundary):
tol = 1E-7
return on_boundary and near(x[1], 0, tol)
bc_bot = DirichletBC(V, [0, 0, 0], boundary_bot)
def boundary_top1(x, on_boundary):
tol = 1E-7
return on_boundary and (near(x[1], (a+h), tol) and x[0] > 1.25)
def boundary_top2(x, on_boundary):
tol = 1E-7
return on_boundary and (near(x[1], (a+h), tol) and x[0] < 0.25)
disp1 = Constant([0.0, -0.1, 0.0])
bc_top1 = DirichletBC(V, disp1, boundary_top1)
disp2 = Constant([0.0, -0.2 , 0.0])
bc_top2 = DirichletBC(V, disp2, boundary_top2)
bcs = [bc_bot, bc_top1, bc_top2]
boundary_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(2)
AutoSubDomain(boundary_top1).mark(boundary_subdomains, 1)
AutoSubDomain(boundary_top2).mark(boundary_subdomains, 2)
dss = ds(subdomain_data=boundary_subdomains)
def kinematics(u):
# Kinematics
d = u.geometric_dimension() # Space dimension
I = Identity(d) # Identity tensor
F = variable(I + grad(u)) # Deformation gradient
C = F.T * F # Right Cauchy-Green tensor
Ic = tr(C)
J = det(F)
return Ic, J, F, C, I
# Elasticity parameters
E, nu = 30.5, 0.0 # main
mu, lmbda = Constant(E / (2 * (1 + nu))), Constant(
E * nu / ((1 + nu) * (1 - 2 * nu)))
disp1.assign(Constant([0.0, -0.1, 0.0]))
disp2.assign(Constant([0.0, -0.1-0.05, 0.0]))
Ic, J, F, C, I= kinematics(u)
psiA = (mu / 2) * (Ic - 3) - mu * ln(J) + (lmbda / 2) * (ln(J)) ** 2
psi_main = (mu / 2) * (Ic - 3) - mu * ln(J) + (lmbda / 2) * (ln(J)) ** 2
psi = psi_main + psiA
# Total potential energy
Pi_main = psi_main * dx_main
PiA = psiA * dx_A
Pi = Pi_main + PiA
dPi = derivative(Pi, u, v)
solve(dPi == 0, u, bcs,
form_compiler_parameters=ffc_options)
stressA = diff(psiA, F)
stress_main = diff(psi_main, F)
stress = stress_main + stressA
force = dot(stress, normal)
stored_force= assemble((force[1]) * dss(1))
