I am enforcing continuity across non-conformal interface using MPC and need to enforce further constraints with real elements. Following the advice here related to the main branch, I constructed a model but it seems to be running into problems with form compilation. I will appreciate if someone familiar could point out my mistake. The MWE below (dolfinx 0.10, conda build) reproduces the error:
import dolfinx, gmsh, ufl, mpi4py, petsc4py, pyvista, scifem
import pyvista, dolfinx_mpc
gmsh.finalize()
gmsh.option.setNumber("General.Terminal", 0)
gmsh.clear()
# gmsh.model.add("generator_2d")
occ = gmsh.model.occ
gdim = 2
b1 = occ.addRectangle(0, 0, 0, 0.5, 1)
b2 = occ.addRectangle(0.5, 0, 0, 0.5, 1)
occ.synchronize()
all_doms = gmsh.model.getEntities(gdim)
for j, dom in enumerate(all_doms):
gmsh.model.addPhysicalGroup(dom[0], [dom[1]], j + 1) # create the main group/node
# number all boundaries
all_edges = gmsh.model.getEntities(gdim - 1)
for j, edge in enumerate(all_edges):
gmsh.model.addPhysicalGroup(edge[0], [edge[1]], edge[1]) # create the main group/node
# for _ in range(refine):
# gmsh.model.mesh.refine()
# gmsh.model.mesh.setOrder(fem_order)
gmsh.model.mesh.optimize()
mpi_rank = 0
dolfinx_model = dolfinx.io.gmsh.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, mpi_rank, gdim)
mesh, ct, ft = dolfinx_model.mesh, dolfinx_model.cell_tags, dolfinx_model.facet_tags
interface_bnd_idx = [2, 8] # by visual inspection of the mesh
Omega_A = dolfinx.fem.functionspace(mesh, ("CG", 2))
Omega_r = scifem.create_real_functionspace(mesh)
# mpc
mpc = dolfinx_mpc.MultiPointConstraint(Omega_A)
tol = float(1e-8)
mpc.create_contact_inelastic_condition(
ft, interface_bnd_idx[0], interface_bnd_idx[1], eps2=tol)
mpc.finalize()
W = ufl.MixedFunctionSpace(mpc.function_space, Omega_r)
A, Vc = ufl.TrialFunctions(W)
At, Vct = ufl.TestFunctions(W)
dx = ufl.Measure("dx", domain=mesh, subdomain_data=ct)
zero = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(0))
F = ufl.inner(A, At)*dx + ufl.inner(Vc, Vct)*dx + ufl.inner(A, Vct)*dx + ufl.inner(Vc, At)*dx
F += ufl.inner(zero, Vct)*dx + ufl.inner(zero, At)*dx
left_dofs = dolfinx.fem.locate_dofs_geometrical(Omega_A, lambda x: np.isclose(x[0], 0))
dbc = dolfinx.fem.dirichletbc(1.0, left_dofs, Omega_A)
a_block, L_block = ufl.extract_blocks(F)
a_form = dolfinx.fem.form(a_block)
L_form = dolfinx.fem.form(L_block)
# solve the linear model
petsc_options = {"pc_type": "lu", "pc_factor_mat_solver_type": "mumps"}
problem = dolfinx_mpc.problem.LinearProblem(a_form, L_form, [mpc, None], bcs=[dbc], petsc_options=petsc_options)
A_sol = problem.solve()
The form compiler leads to a long error where I suspect the following is relevant:
ArityMismatch Traceback (most recent call last)
Cell In[17], line 64
61 dbc = dolfinx.fem.dirichletbc(1.0, left_dofs, Omega_A)
63 a_block, L_block = ufl.extract_blocks(F)
---> 64 a_form = dolfinx.fem.form(a_block)
65 L_form = dolfinx.fem.form(L_block)
67 # solve the linear model
File ~/install/miniforge3/envs/fenics-0.10/lib/python3.11/site-packages/dolfinx/fem/forms.py:449, in form(form, dtype, form_compiler_options, jit_options, entity_maps)
446 else:
447 return form
--> 449 return _create_form(form)
File ~/install/miniforge3/envs/fenics-0.10/lib/python3.11/site-packages/dolfinx/fem/forms.py:445, in form.<locals>._create_form(form)
443 return _zero_form(form)
444 elif isinstance(form, collections.abc.Iterable):
--> 445 return list(map(lambda sub_form: _create_form(sub_form), form))
446 else:
447 return form
File ~/install/miniforge3/envs/fenics-0.10/lib/python3.11/site-packages/dolfinx/fem/forms.py:445, in form.<locals>._create_form.<locals>.<lambda>(sub_form)
60 f"{tuple(map(_afmt, a))} vs {tuple(map(_afmt, b))}."
61 )
62 return a
ArityMismatch: Adding expressions with non-matching form arguments ('v_0^0',) vs ('v_0^0', 'v_1^0').
