Hi everyone,
I currently have a function Evap(T) that is a function of my solution T, I wish to include this in my equation that is solved in a time dependently, and have the value of this function update for every time step. Currently I have this as the function I wish to use:
def vp_function(x): # x is the values of the solution at each node
a = 5.73623
b = 13204.109
c = -24.306
return 10**(a - (b/(x + c)))
tempspace = np.linspace(200,10000,10000)
vp_f = vp_function(tempspace)
mesh = UnitSquareMesh(10,10)
Space = FunctionSpace(mesh, 'P', 1)
T = Function(Space)
vp_new_array = vp_f(T.vector().get_local())
vp_space = FunctionSpace(mesh, 'CG',1)
vp = Function(vp_space)
vp.vector()[:] = vp_new_array
def Evap(T):
return vp*(1/T)
Where Evap(T) is the function I wish to use in my final form. However when I run what I have so farm I get this:
File "test.py", line 54, in <module>
TypeError: 'numpy.ndarray' object is not callable
Is there a way that I can set vp up such that it is usable in Fenics and its value will update for every time step, such that the value of Evap(T) will change due to its 1/T dependence and its implicit T dependence from vp ? My current code is below:
import scipy as scipy
from ufl import as_tensor
from ufl import Index
import math
from scipy.optimize import curve_fit
from scipy.interpolate import interp1d
from scipy import interp
from scipy.interpolate import UnivariateSpline
parameters["allow_extrapolation"] = True
set_log_level(50)
hfont = {'fontname':'Liberation Sans'}
t_start = 0.0
t_end = 100
nstep = 200
dtime = (t_end - t_start)/ nstep #time step
#---------IMPORT EVAPORATION DATA--------------
def vp_function(x):
a = 5.73623
b = 13204.109
c = -24.306
T = Function(Space)
T0 = Function(Space)
T_init = Expression('Tambient', degree=1, Tambient=1000.)
T = project(T_init, Space)
assign(T0,T)
def Evap(T):
return vp*(1/T)
V = TestFunction(Space) # Test Function used for FEA
dT = TrialFunction(Space) # Temperature Derivative
i = Index()
G = as_tensor(T.dx(i), (i)) #gradient of T
G0 = as_tensor(T0.dx(i), (i)) # gradient of T at previous time step
q = -G
F = (1/dtime*(T-T0)*V - q[i]*V.dx(i)) * dx + Evap(T)*V*ds #final form to solve
Gain = derivative(F, T, dT) # Gain will be used as the Jacobian required to determine the evolution of a dynamic system
problem = NonlinearVariationalProblem(F, T, [], Gain)
solver.parameters["newton_solver"]["relative_tolerance"] = 1E-4
solver.parameters["newton_solver"]["absolute_tolerance"] = 1E-3
solver.parameters["newton_solver"]["convergence_criterion"] = "residual"
solver.parameters["newton_solver"]["error_on_nonconvergence"] = True
solver.parameters["newton_solver"]["linear_solver"] = "cg"
solver.parameters["newton_solver"]["maximum_iterations"] = 10000
solver.parameters["newton_solver"]["preconditioner"] = "hypre_euclid"
solver.parameters["newton_solver"]["report"] = True
solver.parameters["newton_solver"]["krylov_solver"]["nonzero_initial_guess"] = False
solver.parameters["newton_solver"]["krylov_solver"]["relative_tolerance"] = 1E-4
solver.parameters["newton_solver"]["krylov_solver"]["absolute_tolerance"] = 1E-3
solver.parameters["newton_solver"]["krylov_solver"]["monitor_convergence"] = False
solver.parameters["newton_solver"]["krylov_solver"]["maximum_iterations"] = 100000
t = 0
for t in np.arange(t_start + dtime,t_end + dtime,dtime):
print( "Time", t)
solver.solve()
assign(T0, T)
print(assemble(Evap(T)*da))
print(vp(max(T.vector())))
