Hello everyone
Here I want to compute value of solution u using data u at t =0.2 so, first I append all the solution in a list U and try to compute u at t=0.6 using u at t=0.2 in second for loop but it shows error.
Here u_n is the solution u at t=0 and f is given function.
Please suggest something in order to correct it.
T = 1.0 # final time
num_steps = 5 # number of time steps
alpha = 3 # parameter alpha
beta = 1.2 # parameter beta
s = 0.4 # delay
k = s / dt
nx = ny = 8
mesh = UnitSquareMesh(nx, ny)
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + alpha*x[1]*x[1] + beta*t', degree=2, alpha=alpha, beta=beta, t=t)
def boundary(x, on_boundary):
return on_boundary
# Define initial value
u_n = interpolate(u_D, V)
#u_n = project(u_D, V)
# Define variational proble
f = Expression('beta - 3 -2*alpha - x[0]*x[0] - alpha*x[1]*x[1] - beta*(t-s)', degree=2, alpha=alpha, beta=beta, s=s, t=0)
phi = Expression('1 + x[0]*x[0] + alpha*x[1]*x[1] + beta*t', degree=2, alpha=alpha, beta=beta, t=-s)
t=0
U =[u_n]
for i in range(num_steps):
F1 = u*v*dx + dt*dot(grad(u), grad(v))*dx - (u_n + dt*f)*v*dx - dt*phi*v*dx
a1, L1 = lhs(F1), rhs(F1)
if i <= k:
#Update current time
t = (i+1)*dt
u_D.t = t
f.t = t
phi.t = t
#Compute solution
solve(a1 == L1, u, bc)
U.append(u)
#print(u_nodes.append(u))
u_n.assign(u)
break
print(U)
F2 = u*v*dx + dt*dot(grad(u), grad(v))*dx - (u_n + dt*f)*v*dx - dt*U[i-k]*v*dx
a2, L2 = lhs(F2), rhs(F2)
if i > k:
t = (i+1)*dt
u_D.t = t
f.t = t
phi.t = t
#Compute solution
solve(a2 == L2, u, bc)
