I’m trying to set up a simulation using Test problem 1: Channel flow (Poiseuille flow) and gmsh to generate 2d nozzle meshes. Below is the code I am using:
import os
import pyvista
from lib import dimdict
import tqdm.autonotebook
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction,
TrialFunction, VectorElement, as_vector, div, dot, ds, dx, inner,
lhs, grad, nabla_grad, rhs, sym, sqrt)
from dolfinx.fem import (Constant, Function, FunctionSpace,
assemble_scalar, dirichletbc, form, locate_dofs_topological,
set_bc, locate_dofs_geometrical)
create_vector, create_matrix, set_bc)
from dolfinx.graph import adjacencylist
from dolfinx.geometry import bb_tree, compute_collisions_points, compute_colliding_cells
from dolfinx.io import (XDMFFile, VTXWriter, distribute_entity_data, gmshio)
from dolfinx.mesh import create_mesh, meshtags_from_entities
from ufl import (FacetNormal, FiniteElement, MixedElement, Identity, Measure, TestFunction,
TestFunctions, TrialFunction, VectorElement, as_vector, div, dot, ds,
dx, inner, lhs, grad, nabla_grad, rhs, sym, split)
## Creating mesh for a syringe
comm = MPI.COMM_WORLD
model_rank = 0
syringe_param_entry = 0
dimdictent=dimdict.ents['Entries'][syringe_param_entry]
# Creating gmsh mesh
gdim = 2
vals = dimdictent["Params"]
# gmsh.option.setNumber("Mesh.Algorithm", 5)
# Syringe dimensions
syringe_radius = vals["syringe_radius"]["Value"]
syringe_length = vals["syringe_length"]["Value"]
# Nozzle dimensions
nozzle_base_radius = vals["nozzle_base_radius"]["Value"]
nozzle_length = vals["nozzle_length"]["Value"]
nozzle_tip_radius = vals["nozzle_tip_radius"]["Value"]
# Nozzle stage dimensions
nozzle_stage_length = vals["nozzle_stage_length"]["Value"]
nozzle_stage_radius = vals["nozzle_stage_radius"]["Value"]
# Outline points
stagelenx = syringe_length + nozzle_stage_length
nozzlelenx = stagelenx + nozzle_length
# Define mesh sizes
ms1 = syringe_radius/2
ms2 = nozzle_base_radius/2
ms3 = nozzle_tip_radius
gmsh.option.setNumber("Mesh.MeshSizeMax", 30)
# Order points
if nozzle_stage_length > 0:
ptlst = [
(0,syringe_radius),
(syringe_length,syringe_radius),
(syringe_length,nozzle_stage_radius),
(stagelenx,nozzle_stage_radius),
(stagelenx,nozzle_base_radius),
(nozzlelenx,nozzle_tip_radius),
(nozzlelenx,-nozzle_tip_radius),
(stagelenx,-nozzle_base_radius),
(stagelenx,-nozzle_stage_radius),
(syringe_length,-nozzle_stage_radius),
(syringe_length,-syringe_radius),
(0,-syringe_radius)
nozzle_stage = True
ptlst = [
(0,syringe_radius),
(syringe_length,nozzle_base_radius),
(syringe_length,-nozzle_base_radius),
(0,-syringe_radius)
nozzle_stage = False
# Defining starting point
gmsh.model.occ.addPoint(0,syringe_radius,0,ms1,1)
# Defining gmsh points from precompiled list and assigning resolution based on radius
count = 1
lnlst = []
for pt in range(len(ptlst)-1):
if abs(ptlst[pt+1][1]) == syringe_radius:
res = ms1
elif abs(ptlst[pt+1][1]) == nozzle_stage_radius:
res = ms2
elif abs(ptlst[pt+1][1]) == nozzle_base_radius:
res = ms2
elif abs(ptlst[pt+1][1]) == nozzle_tip_radius:
res = ms3
if ptlst[pt] != ptlst[pt+1]:
gmsh.model.occ.addPoint(ptlst[pt+1][0],ptlst[pt+1][1],0,res,count+1)
gmsh.model.occ.addLine(count,count+1,count)
lnlst.append(count)
count += 1
# Defining ending point and last connecting line
gmsh.model.occ.addPoint(0,-syringe_radius,0,ms1,count+1)
gmsh.model.occ.addLine(count,1,count)
lnlst.append(count)
# Creating surface
gmsh.model.occ.addCurveLoop(lnlst,lnlst[-1]+1) # base surface
gmsh.model.occ.addPlaneSurface([lnlst[-1]+1],lnlst[-1]+2)
# Synchronizing mesh parts
gmsh.model.occ.synchronize()
# Defining nodes where fluid will flow
surfaces = gmsh.model.getEntities(dim=gdim)
assert (len(surfaces) == 1)
fm = surfaces[0][1]
gmsh.model.addPhysicalGroup(surfaces[0][0], [fm], fm)
gmsh.model.setPhysicalName(surfaces[0][0], fm, "Fluid")
# Finding boundary, inflow, and outflow nodes
inlet_marker, outlet_marker, wall_marker, idk_marker = fm+1,fm+2,fm+3,fm+4
inflow, outflow, walls, leftovers = [], [], [], []
boundaries = gmsh.model.getBoundary(surfaces,oriented=False)
for boundary in boundaries:
if np.allclose(center_of_mass, [0, 0, 0]):
inflow.append(boundary[1])
elif np.allclose(center_of_mass, [nozzlelenx, 0, 0]):
outflow.append(boundary[1])
walls.append(boundary[1])
gmsh.model.setPhysicalName(1, inlet_marker, "Inlet")
gmsh.model.addPhysicalGroup(1, outflow, outlet_marker)
gmsh.model.setPhysicalName(1, outlet_marker, "Outlet")
gmsh.model.addPhysicalGroup(1, leftovers, idk_marker)
gmsh.model.setPhysicalName(1, idk_marker, "IDK")
# Generating the mesh
gmsh_instance = gmsh.model.mesh.generate(gdim)
# Creating mesh model with gmsh mesh
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model,comm=comm,rank=comm.rank,gdim=gdim)
ft.name = "Facet Markers"
ct.name = "Cell Markers"
with XDMFFile(mesh.comm, "results/mesh.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
# Finalize gmsh
gmsh.finalize()
# The following resources were used to build this script:
# https://jsdokken.com/dolfinx-tutorial/chapter2/ns_code2.html
# https://fenicsproject.org/qa/11271/nonlinear-non-newtonian-navier-stokes/
# https://fenicsproject.discourse.group/t/ipcs-solver-with-time-dependent-pressure-bc/10616/5
# https://jsdokken.com/dolfinx-tutorial/chapter2/ns_code1.html
## Defining problem specific parameters
t = 0 # Start time
T = 10 # Final time
dt = 1 / 100 # Time step size
num_steps = int(T / dt)
# Physical properties of water (for testing)
# Units are kg, mm, s, mPa, (mm/s),
RHO = 1 # kg/(mm**3)
MU = 1 # kg/(mm*s)
f = Constant(mesh, PETSc.ScalarType((0, 0)))
rho = Constant(mesh, PETSc.ScalarType(RHO)) # Density
mu = Constant(mesh, PETSc.ScalarType(MU)) # Viscosity
# Keeping viscosity constant for initial testing, but would like to make it vary with shear rate according to Power Law
# Defining visocity for a shear-thinning fluid using the Power Law
K = Constant(mesh, PETSc.ScalarType(1.0)) # Rheological constant
m = Constant(mesh, PETSc.ScalarType(0.5)) # Power-law index
# Defining inlet / delta pressure (outlet pressure is 0 gauge)
dp = 8 # mPa
# Defining Taylor-Hood function space
v_cg2 = VectorElement("Lagrange", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
p = TrialFunction(Q)
q = TestFunction(Q)
u_n = Function(V)
u_n.name = "u_n"
U = 0.5 * (u_n + u)
fdim = mesh.topology.dim-1
# Define boundary conditions
# Walls
wall_dofs = locate_dofs_topological(V, fdim, ft.find(wall_marker))
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bcu_walls = dirichletbc(u_nonslip, wall_dofs, V)
bcu = [bcu_walls]
# Inlet
p_inlet = PETSc.ScalarType(dp)
inflow_dofs = locate_dofs_topological(Q, fdim, ft.find(inlet_marker))
bcp_inflow = dirichletbc(p_inlet, inflow_dofs, Q)
# Outlet
p_outlet = PETSc.ScalarType(0)
outflow_dofs = locate_dofs_topological(Q, fdim, ft.find(outlet_marker))
bcp_outlet = dirichletbc(p_outlet, outflow_dofs, Q)
bcp = [bcp_inflow, bcp_outlet]
# Define strain-rate tensor
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2 * mu * epsilon(u) - p * Identity(len(u))
# Define the variational problem for the first step
p_n = Function(Q)
p_n.name = "p_n"
F1 = rho * dot((u - u_n) / k, v) * dx
F1 += rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx
F1 += inner(sigma(U, p_n), epsilon(v)) * dx
F1 += dot(p_n * n, v) * ds - dot(mu * nabla_grad(U) * n, v) * ds
F1 -= dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
# Define variational problem for the second step
u_ = Function(V)
a2 = form(dot(nabla_grad(p), nabla_grad(q)) * dx)
L2 = form(dot(nabla_grad(p_n), nabla_grad(q)) * dx - (rho / k) * div(u_) * q * dx)
A2.assemble()
b2 = create_vector(L2)
# Define variational problem for the third step
p_ = Function(Q)
a3 = form(rho * dot(u, v) * dx)
L3 = form(rho * dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
from pathlib import Path
folder = Path("results")
folder.mkdir(exist_ok=True, parents=True)
vtx_u = VTXWriter(mesh.comm, "dfg2D-3-u.bp", [u_], engine="BP4")
vtx_p = VTXWriter(mesh.comm, "dfg2D-3-p.bp", [p_], engine="BP4")
vtx_u.write(t)
vtx_p.write(t)
## Solving
def u_exact(x):
values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = 4 * x[1] * (1.0 - x[1])
return values
u_ex = Function(V)
u_ex.interpolate(u_exact)
L2_error = form(dot(u_ - u_ex, u_ - u_ex) * dx)
for i in range(num_steps):
# Update current time step
# Step 1: Tentative veolcity step
with b1.localForm() as loc_1:
loc_1.set(0)
assemble_vector(b1, L1)
set_bc(b1, bcu)
solver1.solve(b1, u_.vector)
u_.x.scatter_forward()
# Step 2: Pressure corrrection step
with b2.localForm() as loc_2:
loc_2.set(0)
assemble_vector(b2, L2)
set_bc(b2, bcp)
solver2.solve(b2, p_.vector)
p_.x.scatter_forward()
with b3.localForm() as loc_3:
loc_3.set(0)
assemble_vector(b3, L3)
solver3.solve(b3, u_.vector)
u_n.x.array[:] = u_.x.array[:]
p_n.x.array[:] = p_.x.array[:]
# Write solutions to file
vtx_u.write(t)
vtx_p.write(t)
# Compute error at current time-step
error_L2 = np.sqrt(mesh.comm.allreduce(assemble_scalar(L2_error), op=MPI.SUM))
error_max = mesh.comm.allreduce(np.max(u_.vector.array - u_ex.vector.array), op=MPI.MAX)
# Print error only every 20th step and at the last step
if (i % 20 == 0) or (i == num_steps - 1):
print(f"Time {t:.2f}, L2-error {error_L2:.2e}, Max error {error_max:.2e}")
# Close xmdf file
vtx_u.close()
vtx_p.close()
b1.destroy()
b2.destroy()
b3.destroy()
solver1.destroy()
solver2.destroy()
solver3.destroy()
def plotfield():
pyvista.start_xvfb()
topology, cell_types, geometry = vtk_mesh(V)
values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
values[:, :len(u_n)] = u_n.x.array.real.reshape((geometry.shape[0], len(u_n)))
# Create a point cloud of glyphs
function_grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
function_grid["u"] = values
glyphs = function_grid.glyph(orient="u", factor=0.2)
# Create a pyvista-grid for the mesh
grid = pyvista.UnstructuredGrid(*vtk_mesh(mesh, mesh.topology.dim))
# Create plotter
plotter = pyvista.Plotter(off_screen=True)
plotter.add_mesh(grid, style="wireframe", color="k")
plotter.add_mesh(glyphs)
plotter.view_xy()
fig_as_array = plotter.screenshot("glyphs.png")
return
plotfield()
The dictionary dimdict with geometry information looks like this:
ents=\
{"Entries":
{ "Entry ID": 0, "Name": "Test1", "Params":
"syringe_radius": {"Value": 60, "Units": "mm"},
"syringe_length": {"Value": 550, "Units": "mm"},
"nozzle_base_radius": {"Value": 20, "Units": "mm"},
"nozzle_length": {"Value": 320, "Units": "mm"},
"nozzle_tip_radius": {"Value": 0.1, "Units": "mm"},
"nozzle_stage_length": {"Value": 50, "Units": "mm"},
"nozzle_stage_radius": {"Value": 30, "Units": "mm"},
{ "Entry ID": 1, "Name": "Test2", "Params":
"syringe_radius": {"Value": 30, "Units": "mm"},
"syringe_length": {"Value": 50, "Units": "mm"},
"nozzle_length": {"Value": 20, "Units": "mm"},
"nozzle_stage_length": {"Value": 10, "Units": "mm"},
"nozzle_stage_radius": {"Value": 20, "Units": "mm"},
{ "Entry ID": 2, "Name": "Test3", "Params":
"syringe_length": {"Value": 200, "Units": "mm"},
"nozzle_base_radius": {"Value": 30, "Units": "mm"},
"nozzle_length": {"Value": 50, "Units": "mm"},
"nozzle_tip_radius": {"Value": 30, "Units": "mm"},
"nozzle_stage_length": {"Value": 0, "Units": "mm"},
"nozzle_stage_radius": {"Value": 0, "Units": "mm"},
{ "Entry ID": 3, "Name": "Test4", "Params":
"syringe_radius": {"Value": 0.5, "Units": "mm"},
"syringe_length": {"Value": 0.5, "Units": "mm"},
"nozzle_base_radius": {"Value": 0.5, "Units": "mm"},
"nozzle_length": {"Value": 0.5, "Units": "mm"},
"nozzle_tip_radius": {"Value": 0.5, "Units": "mm"},
When I recreate a unit square mesh (Entry ID 3) and use the same parameters as in the example (mu=1,rho=1,deltapressure=8), the generated plot is comparable to output from the example, though the calculated error is much greater:
Info : Meshing 1D...
Info : [ 0%] Meshing curve 1 (Line)
Info : [ 20%] Meshing curve 2 (Line)
Info : [ 40%] Meshing curve 3 (Line)
Info : [ 50%] Meshing curve 4 (Line)
Info : [ 70%] Meshing curve 5 (Line)
Info : [ 90%] Meshing curve 6 (Line)
Info : Done meshing 1D (Wall 0.000524887s, CPU 0.000246s)
Info : Meshing 2D...
Info : Meshing surface 8 (Plane, Frontal-Delaunay)
Info : Done meshing 2D (Wall 0.00107404s, CPU 0.001073s)
Info : 32 nodes 67 elements
Time 0.01, L2-error 1.26e+00, Max error 3.08e+00
Time 0.21, L2-error 1.48e+00, Max error 3.00e+00
Time 0.41, L2-error 1.52e+00, Max error 3.00e+00
Time 0.61, L2-error 1.53e+00, Max error 3.00e+00
Time 0.81, L2-error 1.53e+00, Max error 3.00e+00
Time 1.01, L2-error 1.53e+00, Max error 3.00e+00
Time 1.21, L2-error 1.53e+00, Max error 3.00e+00
Time 1.41, L2-error 1.53e+00, Max error 3.00e+00
Time 1.61, L2-error 1.53e+00, Max error 3.00e+00
Time 1.81, L2-error 1.53e+00, Max error 3.00e+00
Time 2.01, L2-error 1.53e+00, Max error 3.00e+00
Time 2.21, L2-error 1.53e+00, Max error 3.00e+00
Time 2.41, L2-error 1.53e+00, Max error 3.00e+00
Time 2.61, L2-error 1.53e+00, Max error 3.00e+00
Time 2.81, L2-error 1.53e+00, Max error 3.00e+00
Time 3.01, L2-error 1.53e+00, Max error 3.00e+00
Time 3.21, L2-error 1.53e+00, Max error 3.00e+00
Time 3.41, L2-error 1.53e+00, Max error 3.00e+00
Time 3.61, L2-error 1.53e+00, Max error 3.00e+00
Time 3.81, L2-error 1.53e+00, Max error 3.00e+00
Time 4.01, L2-error 1.53e+00, Max error 3.00e+00
Time 4.21, L2-error 1.53e+00, Max error 3.00e+00
Time 4.41, L2-error 1.53e+00, Max error 3.00e+00
Time 4.61, L2-error 1.53e+00, Max error 3.00e+00
Time 4.81, L2-error 1.53e+00, Max error 3.00e+00
Time 5.01, L2-error 1.53e+00, Max error 3.00e+00
Time 5.21, L2-error 1.53e+00, Max error 3.00e+00
Time 5.41, L2-error 1.53e+00, Max error 3.00e+00
Time 5.61, L2-error 1.53e+00, Max error 3.00e+00
Time 5.81, L2-error 1.53e+00, Max error 3.00e+00
Time 6.01, L2-error 1.53e+00, Max error 3.00e+00
Time 6.21, L2-error 1.53e+00, Max error 3.00e+00
Time 6.41, L2-error 1.53e+00, Max error 3.00e+00
Time 6.61, L2-error 1.53e+00, Max error 3.00e+00
Time 6.81, L2-error 1.53e+00, Max error 3.00e+00
Time 7.01, L2-error 1.53e+00, Max error 3.00e+00
Time 7.21, L2-error 1.53e+00, Max error 3.00e+00
Time 7.41, L2-error 1.53e+00, Max error 3.00e+00
Time 7.61, L2-error 1.53e+00, Max error 3.00e+00
Time 7.81, L2-error 1.53e+00, Max error 3.00e+00
Time 8.01, L2-error 1.53e+00, Max error 3.00e+00
Time 8.21, L2-error 1.53e+00, Max error 3.00e+00
Time 8.41, L2-error 1.53e+00, Max error 3.00e+00
Time 8.61, L2-error 1.53e+00, Max error 3.00e+00
Time 8.81, L2-error 1.53e+00, Max error 3.00e+00
Time 9.01, L2-error 1.53e+00, Max error 3.00e+00
Time 9.21, L2-error 1.53e+00, Max error 3.00e+00
Time 9.41, L2-error 1.53e+00, Max error 3.00e+00
Time 9.61, L2-error 1.53e+00, Max error 3.00e+00
Time 9.81, L2-error 1.53e+00, Max error 3.00e+00
Time 10.00, L2-error 1.53e+00, Max error 3.00e+00
So, my first question is what exactly does the error mean and why does it change from 10**-6 to 10**0 with a slightly different mesh geometry?
My second question is, what units need to be used here? In order to achieve dimensionlessness in the Reynolds Number and considering that the mesh is measured out in mm, expressing density as kg/(mm3), viscosity as kg/(mms), and pressure as kg/(mms2) (equivalent to mPa) should work. When using water at 20C as an example, rho would be 1/1000, mu would be 1/1000000, and a reasonable pressure would be 1000 mPa, but these values shoot the error up to 10**93 for the unit square mesh by the second time step:
Info : Done meshing 1D (Wall 0.000373357s, CPU 0.000192s)
Info : Done meshing 2D (Wall 0.0012464s, CPU 0.001246s)
Time 0.01, L2-error 1.00e+04, Max error 1.00e+04
Time 0.21, L2-error 1.98e+93, Max error 4.94e+93
Similarly, I am also running into stability issues with the simulation when I change the parameters. Specifically, if I increase the linear dimensions of the mesh or use a more complex mesh (not a square), error increases quite a bit. Using a square with linear dimensions increased 10-fold results in the following:
Info : Done meshing 1D (Wall 0.000636288s, CPU 0.00064s)
Info : Done meshing 2D (Wall 0.00112193s, CPU 0.00112s)
Time 0.01, L2-error 4.47e+05, Max error 1.02e+04
Time 0.21, L2-error 4.47e+05, Max error 1.02e+04
Time 0.41, L2-error 4.47e+05, Max error 1.02e+04
Time 0.61, L2-error 4.47e+05, Max error 1.02e+04
Time 0.81, L2-error 4.47e+05, Max error 1.02e+04
Time 1.01, L2-error 4.47e+05, Max error 1.02e+04
Time 1.21, L2-error 4.47e+05, Max error 1.02e+04
Time 1.41, L2-error 4.47e+05, Max error 1.02e+04
Time 1.61, L2-error 4.47e+05, Max error 1.02e+04
Time 1.81, L2-error 4.47e+05, Max error 1.02e+04
Time 2.01, L2-error 4.47e+05, Max error 1.02e+04
Time 2.21, L2-error 4.47e+05, Max error 1.02e+04
Time 2.41, L2-error 4.47e+05, Max error 1.02e+04
Time 2.61, L2-error 4.47e+05, Max error 1.02e+04
Time 2.81, L2-error 4.47e+05, Max error 1.02e+04
Time 3.01, L2-error 4.47e+05, Max error 1.02e+04
Time 3.21, L2-error 4.47e+05, Max error 1.02e+04
Time 3.41, L2-error 4.47e+05, Max error 1.02e+04
Time 3.61, L2-error 4.47e+05, Max error 1.02e+04
Time 3.81, L2-error 4.47e+05, Max error 1.02e+04
Time 4.01, L2-error 4.47e+05, Max error 1.02e+04
Time 4.21, L2-error 4.47e+05, Max error 1.02e+04
Time 4.41, L2-error 4.47e+05, Max error 1.02e+04
Time 4.61, L2-error 4.47e+05, Max error 1.02e+04
Time 4.81, L2-error 4.47e+05, Max error 1.02e+04
Time 5.01, L2-error 4.47e+05, Max error 1.02e+04
Time 5.21, L2-error 4.47e+05, Max error 1.02e+04
Time 5.41, L2-error 4.47e+05, Max error 1.02e+04
Time 5.61, L2-error 4.47e+05, Max error 1.02e+04
Time 5.81, L2-error 4.47e+05, Max error 1.02e+04
Time 6.01, L2-error 4.47e+05, Max error 1.02e+04
Time 6.21, L2-error 4.47e+05, Max error 1.02e+04
Time 6.41, L2-error 4.47e+05, Max error 1.02e+04
Time 6.61, L2-error 4.47e+05, Max error 1.02e+04
Time 6.81, L2-error 4.47e+05, Max error 1.02e+04
Time 7.01, L2-error 4.47e+05, Max error 1.02e+04
Time 7.21, L2-error 4.47e+05, Max error 1.02e+04
Time 7.41, L2-error 4.47e+05, Max error 1.02e+04
Time 7.61, L2-error 4.47e+05, Max error 1.02e+04
Time 7.81, L2-error 4.47e+05, Max error 1.02e+04
Time 8.01, L2-error 4.47e+05, Max error 1.02e+04
Time 8.21, L2-error 4.47e+05, Max error 1.02e+04
Time 8.41, L2-error 4.47e+05, Max error 1.02e+04
Time 8.61, L2-error 4.47e+05, Max error 1.02e+04
Time 8.81, L2-error 4.47e+05, Max error 1.02e+04
Time 9.01, L2-error 4.47e+05, Max error 1.02e+04
Time 9.21, L2-error 4.47e+05, Max error 1.02e+04
Time 9.41, L2-error 4.47e+05, Max error 1.02e+04
Time 9.61, L2-error 4.47e+05, Max error 1.02e+04
Time 9.81, L2-error 4.47e+05, Max error 1.02e+04
Time 10.00, L2-error 4.47e+05, Max error 1.02e+04
I apologize for any dumb questions; I am not well versed in finite element analysis or how to set the solvers up. Any and all input, specifically suggestions on how to better set up this simulation (modeling shear stress / velocity of pressure-driven flow in complex 2d geometries built with gmsh and using dolfinx to set up the problem and solve) is greatly appreciated.
I am also interested making the viscosity parameter mu update based on the velocity (shear thinning behavior using the Power Law relationship between shear stress and shear rate).
