Using Python functions in FEniCS variational formulation
Hello FEniCS community,
I have been implementing a finite element solver in FEniCS with great results thus far, but I have been facing a technical obstacle when using more complicated functions in the variational formulation.
For example, I have defined the following smooth function in Python via cubic interpolation:
def diffu(r): # We define a function which outputs the diffusivity for a given radius
    R1 = np.linspace(0,0.47,48) # Radii 0, 0.1, 0.2, ... , 0.47
    R2 = np.linspace(0.471,0.5,30) # Smaller steps for radii: 0.471, 0.472, ... , 0.5
    R = np.concatenate((R1, R2)) # All 78 arguments for calculations placed into one array.
    D = np.array([1.0000, 0.9997, 0.9988, 0.9972, 0.9950, 0.9922, 0.9888, 0.9849, 0.9803, 0.9752,
                0.9696, 0.9634, 0.9567, 0.9496, 0.9420, 0.9340, 0.9256, 0.9168, 0.9076, 0.8982,
                0.8884, 0.8783, 0.8680, 0.8574, 0.8467, 0.8357, 0.8246, 0.8133, 0.8019, 0.7904,
                0.7787, 0.7668, 0.7548, 0.7427, 0.7303, 0.7177, 0.7048, 0.6915, 0.6776, 0.6631,
                0.6476, 0.6310, 0.6127, 0.5921, 0.5684, 0.5401, 0.5051, 0.4596, 0.4543, 0.4487,
                0.4430, 0.4370, 0.4309, 0.4244, 0.4178, 0.4109, 0.4036, 0.3961, 0.3883, 0.3800,
                0.3714, 0.3624, 0.3528, 0.3428, 0.3322, 0.3209, 0.3089, 0.2962, 0.2824, 0.2677,
                0.2516, 0.2340, 0.2145, 0.1925, 0.1671, 0.1365, 0.0962, 0.0000])
    # We use cubic interpolation in order to smooth out the resulting curve
    f_cubic = interp1d(R, D, 'cubic')
    return float(f_cubic(r))
However, when I solve a resulting scalar PDE for a function u, and try to call this function with u as an argument (as needed by the mathematical problem) in the variational formulation, I get the following error:
ValueError: object arrays are not supported
Now, it is clear to me that such a general Python function is incompatible with the Unified Form Language used by the variational formulation. The question is - how to go about this and reconcile the two syntaxes? Any help will be greatly appreciated, thank you very much!!
You can simply use an Expression or UserExpression, which will interpolate into a specified function space at assembly. See: https://bitbucket.org/fenics-project/dolfin/raw/946dbd3e268dc20c64778eb5b734941ca5c343e5/python/test/unit/function/test_expression.py for usecases and syntax.
You can also use SpatialCoordinate, see: https://bitbucket.org/fenics-project/dolfin/raw/946dbd3e268dc20c64778eb5b734941ca5c343e5/python/demo/undocumented/special-functions/demo_special-functions.py
Hello Jorgen, thank you for providing me with a first step in the right direction. If I am understanding correctly, I do not need to write a new function altogether, but I can call the existing one via an Expression (in much the same way sin, cos, exp etc. are imported from math and subsequently used with x[0] and x[1] coordinates)?
UPDATE: when I try to implement:
Expression(‘diffu®’, degree = 1),
I get the following error: Unable to compile C++ code with dijitso
My point was, as you are trying to do an interpolation of something spatially dependent, you could just use the expressions to describe the relatio n you are after:
Expression("1-pow(pow(x[0]-x0, 2)+pow(x[1]-x1,2),0.5)/0.5", x0=x0, x1=X11,degree=3)
Which will produce a qubic function that is 1 when the distance from (x0,x1) is 0, 0 when it is 0.5
Thanks for clarifying. I am still not seeing how this will solve the required problem in practice, as it seems that this would require me to hardcode expressions for all 78 points I am using? I do not have an explicit formula for the function I am after.
So does your points align with the grid you are using? If not, how are you supposed to interpolate the function to an appropriate function space?
Here is a step-by-step of what I am trying to do - apologies if I was not clear enough before.
I am solving a PDE for a vector u = (c, R). The space that I am working in is:
P1 = FiniteElement('P', triangle, 1)
element = MixedElement([P1, P1])
Later on in the code, right before I state the variational formulation, I split u into its components:
c, R = split(u)
With suitable definition of initial and boundary conditions, as well as test functions v_1 and v_2 on the space V, my variational formulation (which has worked as expected so far) is:
F = (c-c_n)/dt*v_1*vol(R,r)*dx + dot(grad(c_), grad(v_1))*vol(R,r)*dx \
+ v_1*leng(R,r)*beta*c_*(1+gamma*c_)*dx + v_2*(R-R_n)/dt*dx \
+ v_2*beta*gamma*c_*dx
where:
def vol(R,r): # Area of cleanser occupied region.
    return 1 - np.pi *(r+R)**2
def leng(R,r): # Local length of agent-cleanser interface.
    return 2*np.pi*(r+R)
c_= 0.5*(c+c_n)     # The "c tilde" for the implicit midpoint method.
What I am wanting to do is to change my variational formulation to:
F = (c-c_n)/dt*v_1*vol(R,r)*dx + dot(grad(c_), grad(v_1))*vol(R,r)*diffu(r+R)*dx \
That is, everything is the same other than the diffu function in the second term, which I defined at the beginning of this post. However, while the diffu function can handle float inputs in the domain from 0 to 0.5, it cannot properly process the solution component R. In particular, I want to evaluate (pointwise) the function diffu(r+R), where r is a small fixed constant, say 0.1. Clearly r and R are of different data types, but I have no idea whatsoever of how to go about making this work within the variational formulation as I am an absolute beginner with FEniCS.
I can see multiple ways of doing this. Using Expression or UserExpression as @dokken suggested above since that would indeed interpolate it to whatever degree you want.
If you want to use scipy.interpolate.interp1d then you can pass your array of dofs and evaluate the resulting diffu(R), something like
diffvals = Function(FunctionSpace(mesh, "CG", 1))
diffvals.vector()[:] = diffu(0.1+R.vector()[:])
It would be helpful if you could demonstrate what you are trying to achieve with a minimal MWE. That makes others help you as precisely as possible.
Hi Bhavesh,
Thank you for your answer. Here is the exact code of the entire solver. Everything is carefully commented, but the relevant part is the variational formulation, which is where I want to be calling diffu(r+R) instead of diffu(r) (which I am doing now since Python won’t let me insert R as an argument of the function).
Could you perhaps indicate where and how I should make the change in the code?
Running the code should give you two solution plots, one for c and one for R. For example, try calling the agentonpores(T, num_steps, r, a, b, R_0, c_0, beta, gamma, bc_bottom) function with T = 3, num_steps = 100, a = b = 1, r = 0.1, beta = gamma = 1, R_0 = 0.1, c_0 = 1.
from fenics import * # imports the key classes UnitSquareMesh, FunctionSpace, Function etc.
import numpy as np # we'll need this, always - most matrix-y operations use numpy
import sympy as sym
from matplotlib import pyplot as plt # go-to plotter, MATLAB style
from scipy.interpolate import interp1d
def agentonpores(T, num_steps, r, a, b, R_0, c_0, beta, gamma, bc_bottom):
    dt = T / num_steps # time step size (predetermined by the number of timesteps)
    degree = 1 # the degree that determines the kind of elements we are using for the function space
        # Effective diffusivities for the particular radii of pores.
    nx = ny = 100 # Specifying the resolution of our triangular mesh
    mesh = RectangleMesh(Point(0.0, 0.0), Point(a, b), nx, ny, "crossed")
    # Uniform, finite element mesh over the unit square.
    # The mesh consists of cells, which in 2D are triangles with straight lines.
    # Defining a MixedElement as the product space of two simple finite elements.
    # Afterwards, using the mixed element to define the function space.
    # V = VectorFunctionSpace(mesh, 'P', 2, degree)
    P1 = FiniteElement('P', triangle, degree)
    # 'P' means that we are using the standard Lagrange family of elements.
    # The third argument specifies the degree of the finite element.
    # Patrick says that this is a sensible choice and should do the job, so I will stick with it.
    # Define boundary condition - there is no cleanser initially at t = 0!
    # The first condition corresponds to no cleanser, the second to the initial radius.
    u_0 = Expression((str(c_0), str(R_0)), degree=1)
    tol = 1e-14 # a tiny tolerance that helps us locate the suitable parts of the boundary.
    class BoundaryX0(SubDomain): # defining the boundary at x = 0
            return on_boundary and near(x[0], 0, tol)
    class BoundaryXa(SubDomain): # defining the boundary at x = a
            return on_boundary and near(x[0], a, tol)
    class BoundaryY0(SubDomain): # defining the boundary at y = 0
            return on_boundary and near(x[1], 0, tol)
    class BoundaryYb(SubDomain): # defining the boundary at y = b
            return on_boundary and near(x[1], b, tol)
    # We are working with facets, so from the FEniCS documentation we need -1 of the dimension of the mesh topology.
    # If instead we wanted to work with vertices, the dimension would be -2.
    boundary_markers = MeshFunction('size_t', mesh, mesh.topology().dim()-1, 0)
    # This was previously done with a FacetFunction, which has now deprecated within FEniCS.
    boundary_markers.set_all(9999)
    bx0 = BoundaryX0()
    bxa = BoundaryXa()
    by0 = BoundaryY0()
    byb = BoundaryYb()
    bx0.mark(boundary_markers, 0) # Assigning a "0" marker to x = 0
    bxa.mark(boundary_markers, 1) # Assigning a "1" marker to x = 1
    by0.mark(boundary_markers, 2) # Assigning a "2" marker to y = 0
    byb.mark(boundary_markers, 3) # Assigning a "3" marker to y = 1
    # In this dictionary, we specify the kinds of boundary conditions we are dealing with.
    # There are three possibilities: Dirichlet, Neumann and Robin.
    # These conditions refer to the cleanser concentration, not to the radius of agent.
    # For each kind of condition, to the right we specify the function that this condition is assigned.
    boundary_conditions_cleanser = {0: {'Neumann': Expression('0', degree=1)}, # insulated left end
                            1: {'Neumann': Expression('0', degree=1)}, # insulated right end
                            2: {'Dirichlet': Expression('1', degree=1)}, # applied cleanser concentration on surface
                            3: {bc_bottom : Expression('0', degree=1)}} # insulated maximum depth / no cleanser
    bcs = [] # We first start with an empty array of boundary conditions, which we then fill.
    # Next, we fill this array only with Dirichlet conditions, since these are the only ones which are taken
    # into account explicitly, as opposed to Neumann conditions within the variational formulation itself.
    # We apply the boundary conditions to V.sub(0) - the cleanser (indexing in Python starts from zero)
    # This next for loop skips over anything that is not Dirichlet
    for i in boundary_conditions_cleanser:
        if 'Dirichlet' in boundary_conditions_cleanser[i]:
            bc = DirichletBC(V.sub(0), boundary_conditions_cleanser[i]['Dirichlet'],
                            boundary_markers, i)
            bcs.append(bc)
    # Define initial value for the solution vector, using the initial condition we set above.
    u_n = interpolate(u_0, V)
    #c_n = project(u_D, V), depending on whether we want to interpolate or project the boundary data.
    u =  interpolate(u_0, V) # A good initial guess = initial value! Newton is local, so we start close.
    v_1, v_2 = TestFunctions(V) # Test functions for cleanser PDE and radius PDE, respectively.
    c, R = split(u) # The components of the solution vector (cleanser first, then radius).
    c_n, R_n = split(u_n) # The components of the discretised iterations, as above.
    # Variational formulation
    F = (c-c_n)/dt*v_1*vol(R,r)*dx + dot(grad(c_), grad(v_1))*vol(R,r)*diffu(r)*dx \
    # language used to express this syntax is UFL (Unified Form Language) and is integral to FEniCS.
    # Time-stepping
    t = 0
    for n in range(num_steps):
        # Update current time
        t += dt # add the timestep to the current time to move forward
        u_0.t = t # update the time
        # Compute solution
        solve(F == 0, u, bcs) # Apply Newton-Kantorovich to nonlinear problem, with the specified boundary conditions
    # Plot solution at the end of the simulation
    plt.figure(0)
    simulationplot1 = plot(c, title = "Cleanser concentration at end of simulation", mode = 'color')
    plt.colorbar(simulationplot1)
    plt.xlabel("Horizontal distance $(y)$")
    plt.ylabel("Depth within porous medium $(x)$")
    plt.figure(1)
    simulationplot2 = plot(R, title = "Radius of agent coating at end of simulation", mode = 'color')
    plt.colorbar(simulationplot2)
So as far as I can tell, r only has a single value per simulation, and the return value can thus be wrapped as a constant.
C= Constant(diffu(r))
The above snippet I posted should work by defining diffu as a dolfin.Function. What is bc_bottom ?
Hi Bhavesh,
Sorry for not clarifying: bc_bottom is the type of boundary condition at y = b (I am solving the problem on a rectangle [0,a] \times [0,b]. You should input either ‘Neumann’ or ‘Dirichlet’ as a string and the code will recognise it.
I tried copy-pasting your definition of diffu right above the variational formulation, and then calling diffu( R) in the variational formulation yielded the following error:
Hi Jorgen, while r is constant for any given simulation, R varies with time and space - I am trying to evaluate the function diffu with argument r + R. Therefore, I do not think that I can solve the problem by wrapping into a constant.
For context, r represents a material property which is intrinsic to a porous medium, whereas R stands for a coating of fluid.
This comes from using R.vector() I think. Try using this in the code
import sympy as sym
diffvals = interp1d(R, D, 'cubic')
and inside your agentpores function
VR = V.sub(1).collapse()  # or FunctionSpace(mesh, "CG", 1)
diffu=Function(VR)
diffu.vector()[:] = R_0
F = (c-c_n)/dt*v_1*vol(R,r)*dx + dot(grad(c_), grad(v_1))*vol(R,r)*diffu*dx \
# Time-stepping
t = 0
    # Compute solution
    c_n, R_n = u.split(True)
    diffu.vector().set_local(diffvals(r+R_n.vector()[:]))
assuming the variational formulation is correct.
Thanks so much for this! Just to clarify, you are no longer using def diffu® as a Python function, but the first code block is located just before the function? Is the code then working for you?
For some reason, I am getting this error. Perhaps it is not the best idea to use R both as the concatenation and the component of the solution in the function. I have changed the former to R_tot but still obtain this:
Right. interp1d resturns a function so I just moved it out. But you can keep it local, as you were doing before, too.
I think you are overwriting it with the definition of diffu later on.
Here’s a complete version that should run fine (I only changed the definition of diffu and moved everything out of the function, but you can readjust as you wish)…
import sympy as sym
T = 3.
num_steps = 100
a = b = 1
r = 0.1
beta = gamma = 1
R_0 = 0.1
c_0 = 1.
bc_bottom = "Dirichlet"
diffu=Function(VR)
bx0 = BoundaryX0()
bxa = BoundaryXa()
by0 = BoundaryY0()
byb = BoundaryYb()
        bcs.append(bc)
diffu.vector()[:] = R_0 #start
# Time-stepping
t = 0
    print(f"Step {n+1}")
    # Compute solution
This seems to be working just the way it should be - I am eternally grateful! I will play around with the code slightly just to make sure I am comfortable with how everything does its job before closing this with your post as the solution.
Hi Bhavesh,
Before I close this, just wanted to check a few things I am not 100% sure about. From several simulations, it seems that although the code is working, it is giving me results which are identical to those with diff( r ) as a constant (the physical expectation is that r+R clogs the medium more, so there should be much smaller concentrations when plugging diff(r+R)) in the variational formulation. This is what plotting the interpolation should also tell you.
^ First, I am not entirely sure why you are defining this to be R_0: does this mean this vector is just the argument for the function you are using later on? Or is this just a starting guess because the diffusivity is between 0 and 1?
^ I am assuming this is the evaluation of diff(r+R) that I am looking for, using the diffvals interpolation?
This just assigns all the values of diffu.vector()[:] which is a numpy.array of the degrees of freedom to be equal to R_0 (each). You can assign it to be equal to float(diffvals(R_0)) too. Again, this is a starting guess.
That’s right. This is assigning the degrees of freedom (nodal values) of diffu to be equal to those given by the interpolant.
