Hi, I was wondering whether I can abuse similar solutions (e.g. previous time steps), to speedup the solution of my system.
Below is a minimal example of a pulsating acoustic sphere, where I am probing the response of the domain to different frequencies. Can the solver access the previous solution? How would I have to modify this implementation to get more efficient simulations? Does the solver do that automatically?
Thank you
# mesh
gmsh.model.add("Pulsating-Sphere")
box = gmsh.model.occ.add_rectangle(0.0, 0.0, 0.0, 1., 1.)
circ = gmsh.model.occ.add_disk(0.0, 0.0, 0.0, 0.2, 0.2, )
gmsh.model.occ.cut([(2, box)], [(2, circ)])
gmsh.model.occ.synchronize()
surfs = gmsh.model.occ.get_entities(2)
gmsh.model.add_physical_group(2, [s[1] for s in surfs])
lines = gmsh.model.occ.get_entities(1)
for line in lines:
com = np.array(gmsh.model.occ.get_center_of_mass(*line))
if not np.greater(com[:2], np.zeros(2, )).all():
continue
if not np.less(com[:2], np.ones(2, )).all():
continue
gmsh.model.add_physical_group(1, [line[1]], tag=42)
gmsh.model.add_physical_group(1, [l[1] for l in lines])
gmsh.option.setNumber("Mesh.MeshSizeMax", 343. / 500. / 15.)
gmsh.model.mesh.generate(2)
msh, ct, ft = dolfinx.io.gmshio.model_to_mesh(
gmsh.model, MPI.COMM_SELF, 0
ds = ufl.Measure("ds", msh, subdomain_data=ft)
# variational problem
v = dolfinx.fem.FunctionSpace(
msh, ufl.FiniteElement("Lagrange", msh.ufl_cell(), 2)
p = ufl.TrialFunction(v)
xi = ufl.TestFunction(v)
p_sol = dolfinx.fem.Function(v)
p_sol.name = "p"
# physics constants
v0 = 1e-3
s = 1j * 1.2 * 343.
# solve different systems
for f in np.linspace(450., 500., 50):
k = f * 2. * np.pi / 343.
ks = k ** 2
lhs = (
ufl.inner(ufl.grad(p), ufl.grad(xi)) * ufl.dx
- (ks * ufl.inner(p, xi) * ufl.dx)
- (s * k * 0.5 * (1 + 1j) * ufl.inner(p, xi) * ufl.ds)
rhs = s * k * ufl.inner(v0, xi) * ds(42)
problem = LinearProblem(
lhs,
rhs,
u=p_sol,
petsc_options={
"ksp_type": "preonly",
"pc_type": "cholesky",
problem.solve()
