When solve this problem, I have trouble, here is the problem . Numerical Results for the Vector Heat Equation with EBC. Before presenting the results for the PPE
reformulation, we show the convergence results for the vector heat equation (VHE) with EBC as a benchmark.
This provides both: a baseline for the PPE reformulation convergence study, and a verification of the code.
Let the problem domain be Ω = [0,1) × [0, 1] with periodic b.c. applied in the x-direction and EBC in the
y-direction. Hence, the problem reads as
ut = ∆u + f in (0,1) ×(0,1)
n × u = 0;div u = 0 on [0,1) ×{0,1}
u(0; y) = u(1; y) for 0<y<1
which the problem is defined in the paper HIGH-ORDER METHODS FOR A PRESSURE POISSON EQUATIONREFORMULATION OF THE NAVIER-STOKES EQUATIONS WITH ELECTRIC BOUNDARY CONDITIONS section3.4.1
I write the code as the follow
#vectorheat
from future import print_function
from math import *
import os, sys
import sympy as sp
from sympy import exp, sin, pi, cos
T = 1 # final time
num_steps = 10000 # number of time steps
define symbol expressions of u,p,f using sympyw23
x,y,t = sp.symbols(“x[0],x[1],t”)
phsi=cos(t)sin(4pi*(x+y))((4y*(1-y))**4)
u1=sp.diff(phsi,y,1)
u2=-sp.diff(phsi,x,1)
f1=sp.diff(u1,t,1)-sp.diff(u1,x,2)-sp.diff(u1,y,2)
f2=sp.diff(u2,t,1)-sp.diff(u2,x,2)-sp.diff(u2,y,2)
transform the expressions to ccode style
u1 = sp.printing.ccode(u1)
u2 = sp.printing.ccode(u2)
f1 = sp.printing.ccode(f1)
f2 = sp.printing.ccode(f2)
phsip = sp.printing.ccode(phsi)
# Left boundary is "target domain" G
return bool(x[0] < DOLFIN_EPS and x[0] > -DOLFIN_EPS and on_boundary)
# Map right boundary (H) to left boundary (G)
def map(self, x, y):
y[0] = x[0] - 1
y[1] = x[1]
Create mesh and define function spaces
mesh = UnitSquareMesh(32, 32)
P1 = FiniteElement(“Lagrange”, mesh.ufl_cell(), 1)
Q = FunctionSpace(mesh, P1)
Mh= FunctionSpace(mesh, “RT”, 1,constrained_domain=PeriodicBoundary())
Define trial and test functions
u = TrialFunction(Mh)
v = TestFunction(Mh)
sigm =TrialFunction(Q)
sigmT =TestFunction(Q)
sigm_=Function(Q)
u_= Function(Mh)
f = Expression((f1,f2), degree=5, t=0)
u_e = Expression((u1,u2), degree=5,t=0)
u_n = interpolate(u_e, Mh)
k = Constant(dt)
Define variational problem for step 0
a0=inner(sigm,sigmT)*dx
L0=inner(u_n,curl(sigmT))*dx
Define variational problem for step 1
F1=inner((u-u_n)/k,v)*dx+inner(curl(sigm_),v)*dx+inner(div(u),div(v))*dx-inner(f,v)*dx
a1=lhs(F1)
L1=rhs(F1)
Time-stepping
t = 0
for n in range(1):
solve(a0 == L0, sigm_)
f.t=t
solve(a1 == L1, u_)
u_e.t = t
error=errornorm(u_e, u_, "L2")
print('t = %.2f: error = %.3g' % (t, error))
u_n.assign(u_)
but I got a complete wrong answer. I need help for it.
