Hi everyone, I’m actually working on an ADR EDP solver using FeniCs, I’m pretty new at this library. In the FeniCs documentation I found an ADR EDP implementation example but it used a previous file with a velocity field solved from a Navier-Stokes problem.
In my code when I define the velocity field (that must depend on time) it seems to have no incidence in the solution, the behavior is like the advection term does not affect the problem, I’ll let my code in here,
(I changed the velocity field to a more exagerated one so i can be sure the field does not affect, the original one was: project(Expression((‘x[0]’+c,'x[1]’+c), degree=1),W))
from future import print_function
T = 10.0 # final time
num_steps = 500 # number of time steps
eps = 0.001 # diffusion coefficient
bet = 10 # reaction rate
tht = 1
sig = 0.5
Create mesh
domain = Rectangle(Point(-1.0, -1.0), Point(1.0, 1.0))
mesh = generate_mesh(domain, 20)
Define function space for velocity
W = VectorFunctionSpace(mesh, ‘P’, 2)
Define function space for system of concentrations
P1 = FiniteElement(‘P’, triangle, 1)
element = MixedElement([P1, P1, P1])
Define test functions
v_1, v_2, v_3 = TestFunctions(V)
Define functions for velocity and concentrations
w = Function(W)
u_0 = Expression((‘pow(x[0],2)+pow(x[1],2) > 0.01 ? 0.1 : 0’, ‘pow(x[0],2)+pow(x[1],2) < 0.01 ? 0.1 : 0’, ‘0’), degree=1)
u_n = project(u_0,V)
Split system functions to access components
u_1, u_2, u_3 = split(u)
u_n1, u_n2, u_n3 = split(u_n)
Define source terms
f_1 = Constant(0)
f_2 = Constant(0)
f_3 = Constant(0)
Define expressions used in variational forms
k = Constant(dt)
eps = Constant(eps)
bet = Constant(bet)
tht = Constant(tht)
sig = Constant(sig)
Define variational problem
F = ((u_1 - u_n1) / k)v_1dx + dot(w, grad(u_1))v_1dx \
epsdot(grad(u_1), grad(v_1))dx + betu_1u_2v_1dx \
((u_2 - u_n2) / k)v_2dx + dot(w, grad(u_2))v_2dx \
epsdot(grad(u_2), grad(v_2))dx - betu_1u_2v_2dx + thtu_2v_2*dx \
((u_3 - u_n3) / k)v_3dx + dot(w, grad(u_3))v_3dx \
epsdot(grad(u_3), grad(v_3))dx - sigu_2v_3*dx \
- f_1v_1dx - f_2v_2dx - f_3v_3dx
Create VTK files for visualization output
vtkfile_u_1 = File(‘reaction_system/u_1.pvd’)
vtkfile_u_2 = File(‘reaction_system/u_2.pvd’)
vtkfile_u_3 = File(‘reaction_system/u_3.pvd’)
Time-stepping
t = 0
for n in range(num_steps):
Update current time
Set velocity
##c = str(int(np.sin(np.pi*t)))
w = project(Expression((’-1’,’-1’), degree=1),W) #HERE IS THE PROBLEM
Solve variational problem for time step
solve(F == 0, u)
Save solution to file (VTK)
_u_1, _u_2, _u_3 = u.split()
vtkfile_u_1 << (_u_1, t)
vtkfile_u_2 << (_u_2, t)
vtkfile_u_3 << (_u_3, t)
Update previous solution
u_n.assign(u)
Hold plot
p = plot(_u_2)
plot(mesh)
plt.colorbar§
The solution looks like:
I’m thinking that maybe I didn’t define well the velocity field since it was imported from a previous file in the example, as I’m not expert I don’t know and can’t find any problem like this in the web, hope you guys can help me, it is a really simple issue for sure!!
