Hello everyone,
I am planning to perform vibro-acoustics with harmonic time dependency. This means that I need to couple the acoustic Helmholtz solver with a linear elastodynamics solver.
I have explored some of the available multiphysics and coupling software, but I am seeking advice on the optimal approach for my case.
In my general scenario, there is always an interface between fluid and solid with non-matching meshes, as shown below:
I am considering the use of preCICE, which already implements mapping between non-matching meshes. However, it is primarily designed for time-dependent problems (although it can also be used for “steady-state” problems).
Is there a better-suited option for my purpose?
Thank you very much.
