Visual bug when using Paraview after solving in parallel
I have prepared an MRE:
nn = 5
domain = dolfinx.mesh.create_box(MPI.COMM_WORLD, [np.array([-1, -1,-1]), np.array([1, 1,1])],
                               [nn,nn,nn], dolfinx.mesh.CellType.tetrahedron, ghost_mode=dolfinx.mesh.GhostMode.shared_facet)
V = dolfinx.fem.functionspace(domain, ("Lagrange", 2))
u_test = ufl.TestFunction(V)
u_n = dolfinx.fem.Function(V)
u_n.x.array[:]=0
u_h = dolfinx.fem.Function(V)
u_h.x.array[:]=0
t = dolfinx.fem.Constant(domain, 0.0)
dt = dolfinx.fem.Constant(domain, 1.0)
diff_term = ufl.dot(ufl.grad(u_test), ufl.grad(u_h)) * ufl.dx
N_bc = u_test*ufl.ds
f_h = -diff_term + N_bc
F_E = u_h*u_test*ufl.dx - u_n*u_test*ufl.dx - dt*f_h
problem = NonlinearProblem(F_E, u_h)
vtxfile = dolfinx.io.VTXWriter(MPI.COMM_WORLD,"u_vtx.bp",u_h)
for i in range(10):
    t.value = t.value + dt.value
    idx, converged = solver.solve(u_h)
    u_h.x.scatter_forward()
    u_n.x.array[:] = u_h.x.array
    vtxfile.write(t)
vtxfile.close()
When running with mpiexec -n 1 python script.py vs mpiexec -n 32 python script.py, after importing results to Paraview everything seems fine. After applying basic clip filter, when n=2 or more, following artifacts appear:
Did anyone encounter a similar issue or is something wrong with my code? Any help appreciated.
Paraview version 5.3.12
Dolfinx run in docker initialized with dolfinx/dolfinx:stable
If you turn on the option “Crinkle clip” this will disappear. The issue is due to how VTX stores the data locally per process, rather than as a big array
Thank you for the answer. This does solve the issue with missing elements, although “crinkle clip” is a different kind of clipping, especially for unstructured grids. But now I understand the problem lies outside of Dolfinx.
