Visual representation (interpolation) of a 2nd order tensor in a 3D space (recipe)
I have seen that others have tried to do this. So I thought that I could share it
# Copyright 2023 edgar (fenicsproject.discourse.group)
# License: GNU General Public License version 3
# https://www.gnu.org/licenses/gpl-3.0.en.html
# Partially based and adapted from https://jsdokken.com/dolfinx-tutorial/
# which holds a Creative Commons Attribution 4.0 International License
# http://creativecommons.org/licenses/by/4.0/
import pyvista
from dolfinx import mesh
from dolfinx import fem
from dolfinx.fem import FunctionSpace
from dolfinx import plot
from dolfinx import io
import dolfinx.fem.petsc as petsc
def clamped_boundary(x):
    return np.isclose(x[0], 0)
    # ufl.sym: Equivalent to
    #  0.5 * (∇(u) + (∇(u))^T)
    #  0.5 * (ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
    return ufl.sym(ufl.grad(u))
def sigma(u, lambda_, mu):
    return (lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u))
            + 2 * mu * epsilon(u))
# Scaled variables
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
gamma = 0.4 * delta**2
beta = 1.25
lambda_ = beta
g = gamma
box_vertex1 = np.array([0, 0, 0])
box_vertex2 = np.array([L, W, W])
ncells = [20, 6, 6]
domain = mesh.create_box(
    MPI.COMM_WORLD, [box_vertex1, box_vertex2],
    ncells, cell_type=mesh.CellType.hexahedron)
fe_type = "Lagrange"
fe_degree = 1
gdim = domain.geometry.dim
V = FunctionSpace(domain, (fe_type, fe_degree, (gdim,)))
boundary_facets = mesh.locate_entities_boundary(
    domain, fdim, clamped_boundary)
u_D = np.array([0, 0, 0], dtype=ScalarType)
boundary_dof = fem.locate_dofs_topological(
    V, fdim, boundary_facets)
bc = fem.dirichletbc(u_D, boundary_dof, V)
T = fem.Constant(domain, ScalarType((0, 0, 0)))
u = ufl.TrialFunction(V)
f = fem.Constant(domain, ScalarType((0, 0, -rho * g)))
a = ufl.inner(sigma(u, lambda_, mu), epsilon(v)) * ufl.dx
problem = petsc.LinearProblem(
    a, L, bcs=[bc],
    petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
topology, cell_types, geometry = plot.vtk_mesh(V)
vtu = pyvista.UnstructuredGrid(
  topology, cell_types, geometry)
vtu["u"] = uh.x.array.reshape((geometry.shape[0], 3))
warped = vtu.warp_by_vector("u", factor=1.5)
pvpl = pyvista.Plotter()
undef_actor = pvpl.add_mesh(vtu, style="wireframe", color="k")
warped_actor = pvpl.add_mesh(warped, show_edges=True, scalars="u")
# https://tutorial.pyvista.org/tutorial/04_filters/solutions/e_glyphs.html
arrows = vtu.glyph(
    scale=True, orient=True, tolerance=0.05, factor=0.25)
pvpl.add_mesh(arrows, show_scalar_bar=False)
pvpl.show_axes()
pvpl.save_graphic("Media/dolfinx_tuto_linear_elasticity.svg")
pvpl.show()
sigma_dev = sigma(uh, lambda_, mu) - (
    1 / 3 * ufl.tr(sigma(uh, lambda_, mu))
    * ufl.Identity(len(uh)))
sigma_vm = ufl.sqrt(3 / 2 * ufl.inner(sigma_dev, sigma_dev))
V_vm = fem.FunctionSpace(
    domain, ("Discontinuous Lagrange", 0))
sigma_vm_expr = fem.Expression(
    sigma_vm, V_vm.element.interpolation_points())
sigma_vm_fun = fem.Function(V_vm)
sigma_vm_fun.interpolate(sigma_vm_expr)
warped.cell_data["sigma_vm"] = sigma_vm_fun.vector.array
warped.set_active_scalars("sigma_vm")
pvpl.add_actor(undef_actor)
pvpl.add_mesh(warped, scalars="sigma_vm")
pvpl.show_axes()
pvpl.save_graphic("Media/dolfinx_tuto_linear_elasticity_sigma_fun_vm.svg")
pvpl.show()
tens2_dim = (domain.geometry.dim,) * 2
interp_ord = 1
CG_lin_2ord = fem.FunctionSpace(domain, (fe_type, interp_ord, tens2_dim))
sigma_expr = fem.Expression(
    sigma(uh, lambda_, mu), CG_lin_2ord.element.interpolation_points())
sigma_fun = fem.Function(CG_lin_2ord)
sigma_fun.interpolate(sigma_expr)
vtu["sigma"] = sigma_fun.x.array.reshape((geometry.shape[0], 3, 3))
vtu.set_active_tensors("sigma")
# warped["sigma"] = vtu.warp_by_vector("u", factor=1.5)
warped["sigma"] = vtu["sigma"]
# https://docs.pyvista.org/version/stable/examples/02-plot/multi-window.html
pyvista.global_theme.multi_rendering_splitting_position = 0.60
pvpl = pyvista.Plotter(shape="1|2")
pvpl.subplot(0)
pvpl.add_mesh(warped, scalars="sigma",
              scalar_bar_args={"title": "stress norm"})
pvpl.show_axes()
pvpl.subplot(1)
pvpl.add_mesh(warped, scalars="sigma", component=0,
              scalar_bar_args={"title": "stress xx"})
pvpl.subplot(2)
pvpl.add_mesh(warped, scalars="sigma", component=8,
              scalar_bar_args={"title": "stress zz"})
pvpl.save_graphic("Media/dolfinx_tuto_linear_elasticity_sigma_fun.svg")
pvpl.show()
Thanks for FEniCS! Thanks to @dokken, @nate, @jackhale, @dparsons parsons for paying attention, sharing your time and helping everyone here.
  • FEniCSx software
    dolfinx: 0.7.0.dev0_r27554.cfeffe0-1
    basix: 0.7.0.dev0_r945.1117a8d-1
    ufl: 2023.2.0.dev0_r3562.77ae57c-1
    ffcx: 0.7.0.dev0_r7077.1d27238-1
  • Dependencies
    python: 3.11.5-2
    python-numpy: 1.26.0-1
    petsc: 3.19.5.1171.g37df9106526-1
    hdf5-openmpi: 1.14.2-1
    boost: 1.83.0-2
    adios2: 2.8.3-5
    scotch: 7.0.4-1
    pybind11: 2.11.1-1
    python-build: 1.0.1-1
    python-cffi: 1.15.1-4
    python-cppimport: 22.08.02.r6.g0849d17-1
    python-installer: 0.7.0-3
    python-mpi4py: 3.1.4-3
    python-pytest: 7.4.2-1
    python-scikit-build: 0.17.6-1
    python-setuptools: 1:68.0.0-1
    python-wheel: 0.40.0-3
    xtensor: 0.24.0-2
    xtensor-blas: 0.20.0-1
  • Operating system
    Arch Linux: 6.5.4-arch2-1
