Volume after deformation
I am currently stuck at the following problem. I modified a demo file where rectangular mesh is deformed under its own weight:
mesh = BoxMesh(Point(0.0, 0.0, 0.0), Point(L, W, H), 20, 8, 4)
V = VectorFunctionSpace(mesh, ‘P’, 1)
with fixed boundaries:
left = CompiledSubDomain(“near(x[0], side) && on_boundary”, side = 0.0)
right = CompiledSubDomain(“near(x[0], side) && on_boundary”, side = 10.0)
c = Constant((0, 0, 0))
bcl = DirichletBC(V, c, left)
bcr = DirichletBC(V, c, right)
bcs = [bcl, bcr]
The solution is saved:
solve(a == L, u, bcs)
File(‘elasticity/displacement.pvd’) << u
Now i would like to know the local volume change, lets say from the four mesh-volumes in the center of the rectangle. So i would need to calculate the inital volume (which is ok, one can do that just using the dimension and resolution) and the volume after displacement.
See the picture below, i guess then it gets more clear.
Thank you
Hi, consider the following
# Undeformed configuration
mesh0 = UnitSquareMesh(32, 32)
File('before.pvd') << mesh0
# Displacement
V = VectorFunctionSpace(mesh0, 'CG', 2)
u = interpolate(Expression(('x[0]*x[1]', '0'), degree=2), V)
# Deformation takes the form x = F(X) = X + u(X) so then
# volume element, dv, in deformed configuration is dv = det(F)*dV,
# with dV the volume element of reference configuration. One way of
# getting the deformed volume is therefore to integrate det(F)*dV over
# undeformed domain.
volume_after0 = assemble(det(Identity(2) + grad(u))*dx)
# Alternatively actually deform the mesh by displacement
mesh1 = Mesh(mesh0)
X = mesh1.coordinates()
X += np.vstack(map(u, X))
File('after.pvd') << mesh1
# and compute the volume of the deformed mesh
volume_after = assemble(Constant(1)*dx(domain=mesh1))
# Should be the same
print(volume_after0, volume_after)
# For doing this over just part of the domains ...
cell_f0 = MeshFunction('size_t', mesh0, mesh0.topology().dim(), 0)
# Left half
CompiledSubDomain('x[0] < 0.5 + DOLFIN_EPS').mark(cell_f0, 1)
dV = Measure('dx', domain=mesh0, subdomain_data=cell_f0)
volume_after0 = assemble(det(Identity(2) + grad(u))*dV(1))
# Assume here that no cells disappeared/got entangled
cell_f1 = MeshFunction('size_t', mesh1, mesh1.topology().dim(), 0)
cell_f1.array()[:] = cell_f0.array()
dV = Measure('dx', domain=mesh1, subdomain_data=cell_f1)
volume_after = assemble(Constant(1)*dV(1))
thank you very much. I am starting to understand more :slight_smile:
And it works just fine, I just had to change to Identity(3) (for a box) and adjust the parameters.
Thank you very much :slight_smile:
Sorry, me again. The results seem to be wrong.
Using:
CompiledSubDomain(‘x[0] < 11.0 + DOLFIN_EPS’).mark(cell_f0, 1)
dV = Measure(‘dx’, domain=mesh0, subdomain_data=cell_f0)
volume_before1 = assemble(det(Identity(3) + grad(u))*dV(1))
print(“Volume before of left half”, volume_before1)
I find a volume of 92.8. But that should be the volume before deformation, right? So 80.
mesh0 = BoxMesh(Point(0.0, 0.0, 0.0), Point(10.0, 4.0, 2.0), 20, 8, 4)
V = VectorFunctionSpace(mesh, “Lagrange”, 1)
Thanks for your help again :slight_smile:
Edit:
Replacing
with:
volume_before1 = assemble(Constant(1)*dV(1))
seems to work.
Best
Can you post full (and formated) code? Anyways, both volumes are volumes of the deformed object. The difference is that one is computed without actually deforming it, while in the other case you deform the mesh and integrate.
Aa ok, then i misunderstood.
Here the Code:
from ufl import nabla_div
Scaled variables
Len = 10.0; W = 4.0; H=2.0;
mu = 1
rho = 1
delta = W/Len
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
mesh = BoxMesh(Point(0.0, 0.0, 0.0), Point(Len, W, H), 21, 8, 4)
Define boundary condition
tol = 1E-14
Mark boundary subdomians
bcs = [bcl, bcr]
Define strain and stress
#return sym(nabla_grad(u))
def sigma(u):
return lambda_nabla_div(u)Identity(d) + 2muepsilon(u)
Define variational problem
d = u.geometric_dimension() # space dimension
f = Constant((0, 0, -rho*g))
T = Constant((0, 0, 0))
L = dot(f, v)*dx + dot(T, v)*ds
Compute solution
Save solution to file in VTK format
#volume of a cell
#c1=Cell(mesh, 7)
#print(c1.volume())
######Volume before and after deformation###############
volume_before0 = assemble(Constant(1)*dx(domain=mesh))
Deformation takes the form x = F(x) = X + u(X) so then
undeformed domain.
volume_after0 = assemble(det(Identity(3) + grad(u))*dx)
print("Volume before ", volume_before0)
print("Volume after ", volume_after0)
##another way is to make new mesh, and then actually deform it:
mesh1 = Mesh(mesh)
print(“Volume after 2nd way”, volume_after)
For doing this over just part of the domains …
cell_f0 = MeshFunction(‘size_t’, mesh, mesh.topology().dim(), 0)
Right half
CompiledSubDomain(‘x[0] < 4.0 + DOLFIN_EPS’).mark(cell_f0, 1)
dV = Measure(‘dx’, domain=mesh, subdomain_data=cell_f0)
#volume_before1 = assemble(det(Identity(3) + grad(u))*dV(1))
print(“Volume before small half”, volume_before1)
cell_f1 = MeshFunction(‘size_t’, mesh1, mesh1.topology().dim(), 0)
dV = Measure(‘dx’, domain=mesh1, subdomain_data=cell_f1)
volume_after1 = assemble(Constant(1)*dV(1))
print(“Volume after of small half:”, volume_after1)
Right half
CompiledSubDomain(‘x[0] < 6.0 + DOLFIN_EPS’).mark(cell_f0, 1)
volume_before2 = assemble(Constant(1)*dV(1))
print(“Volume before large half”, volume_before2)
volume_after2 = assemble(Constant(1)*dV(1))
print(“Volume after of large half:”, volume_after2)
print("--------------")
print(“Volume before center:”, volume_before2-volume_before1)
print(“Volume after center:”, volume_after2-volume_after1)
# Scaled variables
mu = 1
rho = 1
delta = W/Len
beta = 1.25
lambda_ = beta
g = gamma
V = VectorFunctionSpace(mesh, 'Lagrange', 1)
# Define boundary condition
tol = 1E-14
# Mark boundary subdomians
left = CompiledSubDomain('near(x[0], side) && on_boundary', side = 0.0)
right = CompiledSubDomain('near(x[0], side) && on_boundary', side = 10.0)
bcs = [bcl, bcr]
# Define strain and stress
def sigma(u):
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u)
# Compute solution
mesh1 = Mesh(mesh)
print('Volume after 2nd way', volume_after)
cell_f0 = MeshFunction('size_t', mesh, mesh.topology().dim(), 0)
CompiledSubDomain('x[0] < 4.0 + DOLFIN_EPS').mark(cell_f0, 1)
dV = Measure('dx', domain=mesh, subdomain_data=cell_f0)
volume_before = assemble(Constant(1)*dV(1))
print('Volume before small half', volume_before)
volume_after0 = assemble(det(Identity(3) + grad(u))*dV(1))
print('Volume after (0) small half', volume_after0)
dv = Measure('dx', domain=mesh1, subdomain_data=cell_f1)
volume_after1 = assemble(Constant(1)*dv(1))
print('Volume after (1) small half', volume_after1)
Nice, thanks alot :slight_smile:
may i ask another question.
How can I save the mesh of the deformed subdomain only?
I have tried the following:
mesh1 = Mesh(mesh)
cell_f5 = MeshFunction(‘size_t’, mesh1, mesh.topology().dim(), 0)
CompiledSubDomain(‘x[0] < 4.0 + DOLFIN_EPS’).mark(cell_f5, 1)
File(‘liner_def/subdomain1.pvd’) << cell_f5
But that saves the whole mesh of the deformation, with value 1 for the subdomain and value 0 for the rest. I would need only the deformed submesh.
Also consider that i would need to save more infomation that just the coordinates, e.g. the stress, like in the demo:
s = sigma(u) - (1./3)*tr(sigma(u))Identity(d) # deviatoric stress
von_Mises = sqrt(3./2
inner(s, s))
V = FunctionSpace(mesh, ‘P’, 1)
von_Mises = project(von_Mises, V)
plot(von_Mises, title=‘Stress intensity’)
If only 0 or 1 is written therem, it would not be os much use ^^.
Thank you very much for your help again :slight_smile:
There is another Problem: With
CompiledSubDomain(‘x[2] > 1.0 + DOLFIN_EPS’).mark(cell_f0, 1)
one gets the layer of which the conditions applies after deformation. Actually the condition was meant for the inital setup. For example look at this picture:
The fist upper layer of the mesh is marked, but only unti x[2]>1.0. But what I would need is that this condition is applied to the undeformed mesh, i.e. that the complete upper layer is part of the subdomain.
Thanks again ^^
Edit: Would be possible to define such subdomains from the very beginning? Because in the end i want to have exactly this, different layers/domains with different material properties…
Me again.
So I can use the subdomains defined on the inital Mesh to calculate the Volume:
dV = Measure(‘dx’, domain=mesh, subdomain_data=subdomains)
volume_before0 = assemble(Constant(1)*dV(0))
print(“Volume of upper Layer before deformation”, volume_before0)
volume_after1 = assemble(det(Identity(3) + grad(u))*dV(0))
print(“Volume of upper Layer after deformation”, volume_after1)
volume_before0 = assemble(Constant(1)*dV(1))
print(“Volume of bottom Layer before deformation”, volume_before0)
volume_after1 = assemble(det(Identity(3) + grad(u))*dV(1))
print(“Volume of bottom Layer after deformation”, volume_after1)
and save the displacement in a file:
File(‘liner_def/domains_after.pvd’) << u
Or show the marked Subdomains of the inital mesh:
File(‘liner_def/domains_before.pvd’) << subdomains
Now i would like to save the marked subdomains of the deformed mesh, i.e. the solution u with the subdomains defined before.
Is there a way?
Thanks again :slight_smile:
ping
