What would be the optimal convergence rate for the Stokes problem?
Hello everyone,
Currently, I’m addressing the Stokes problem and observing a convergence rate of around 3 in the (L2 norm) for velocity. Considering I’m employing P2 for velocity and P1 for pressure, what would be the optimal convergence rate for the Stokes problem? Shouldn’t I expect a convergence rate closer to 2, given the use of P2 for velocity?
Thank you in advance.
Given a Stokes problem posed with sufficiently smooth analytical solution and material cofficients discrectised on a mesh of granularity measured to be h, the standard Taylor-Hood element of degree \ell in the velocity approximation and \ell-1 in the pressure approximation would yield expected approximation error convergence rates of:
  • \Vert \vec{u} - \vec{u}_h \Vert_{L_2} \backsim \mathcal{O(h^{\ell+1})}
  • \Vert \vec{u} - \vec{u}_h \Vert_{H^1} \backsim \mathcal{O(h^{\ell})}
  • \Vert p - p_h \Vert_{L_2} \backsim \mathcal{O(h^{\ell})}
  • \Vert p - p_h \Vert_{H^1} \backsim \mathcal{O(h^{\ell-1})}
Thank you for your response. Do you have any articles or resources that can provide detailed explanations regarding why the convergence rates should be close to 2 or 3, as you mentioned?
Maybe start with chapter 5 of: https://www.ljll.fr/pironneau/publi/publications/OPfemInFluids.pdf
Referring to chapter 3 of:
https://webs.um.es/eliseo/um/uploads/Main/Girault_Raviart_Finite_Element_Approximation_of_the_Navier_Stokes_Equations_LNM_1979.pdf
Allthough it should be in more modern textbooks as well
As @dokken has already mentioned, this result derives from standard a priori error analysis. You should be able to find it in any standard introductory FEM text, or lecture notes.
Thank you, sir, for the answer.
OK, think you so much for you answer.
