Where can i find the dolfin module files?
Hello everyone,
I installed fenics Legacy with Docker (windows 11) following this tutorial :
https://fenics.readthedocs.io/projects/containers/en/latest/jupyter.html
i runned this command so i can use fenics with jupyter:
docker run --name notebook -w /home/fenics -v ${pwd}:/home/fenics/shared -d -p 127.0.0.1:8888:8888 quay.io/fenicsproject/stable 'jupyter-notebook --ip=0.0.0.0'
I would like to open the files from the dolfin module, especially the dolfin/io/XDMFFile.cpp file… I looked pretty much everywhere in the Docker container’s files but can’t find the directory containing these files.
I am an absolute begginer in using Docker and fenics, any advice on where can i find these files would be truly appreciated !
The legacy images remove the source code after installation, Ref: https://bitbucket.org/fenics-project/docker/raw/b1d5e0963afc9a23d11a18b1e82347cee21ae520/dockerfiles/stable/Dockerfile
This is Also done in the more modern images:
Package fenics-gmsh · GitHub
However, it is quite easy to take one of the modern docker files, and remove a single line at the end of the file: packages/Dockerfile at main · scientificcomputing/packages · GitHub and build the image yourself.
You could simply clone dolfin from
Bitbucket and inspect the files locally. What exactly are you looking for?
First of all, thanks you for your reply.
I will precise what i am trying to achieve.
I have the exact same issue covered in this topic to which you responded :
https://fenicsproject.discourse.group/t/cannot-open-xdmf-files-in-legacy-version-of-fenics-latest-paraview/10344
My understanding of your last answer is that i have to modify the 5 files as it is presented in this link https://bitbucket.org/fenics-project/dolfin/commits/6fbc9fb8e1272c4cdd73d7e2e432dc29ebfe03ac
That’s why i’m searching those files in order to edit them.
I’m totally new on these topics so please correct me if my understanding is wrong.
This has been fixed in fenics versions · scientificcomputing · GitHub
or if you want jupyter-lab support:
fenics-gmsh versions · scientificcomputing · GitHub
were you run
docker run -ti -v $(pwd):/root/shared -w /root/shared --name=notebook -p 8888:8888 ghcr.io/scientificcomputing/fenics-gmsh:jupterlab-2023-04-21
jupyter lab --ip 0.0.0.0 --no-browser --allow-root
Thanks again for your reply. I tried but i still have the same issue, here is what i did:
I runned the windows terminal as admin and runned the two commands :
Everything worked well. Then i opened a new jupyter file and pasted this code :
import fenics as fe
CANTILEVER_LENGTH = 1.0
CANTILEVER_WIDTH = 0.2
N_POINTS_LENGTH = 10
N_POINTS_WIDTH = 3
LAME_MU = 1.0
LAME_LAMBDA = 1.25
DENSITY = 1.0
ACCELERATION_DUE_TO_GRAVITY = 0.016
def main():
    # Mesh and Vector Function Space
    mesh = fe.BoxMesh(
        fe.Point(0.0, 0.0, 0.0),
        fe.Point(CANTILEVER_LENGTH, CANTILEVER_WIDTH, CANTILEVER_WIDTH),
        N_POINTS_LENGTH,
        N_POINTS_WIDTH,
        N_POINTS_WIDTH,
    lagrange_vector_space_first_order = fe.VectorFunctionSpace(
        mesh,
        "Lagrange",
        1,
    # Boundary Conditions
    def clamped_boundary(x, on_boundary):
        return on_boundary and x[0] < fe.DOLFIN_EPS
    dirichlet_clamped_boundary = fe.DirichletBC(
        lagrange_vector_space_first_order,
        fe.Constant((0.0, 0.0, 0.0)),
        clamped_boundary,
    # Define strain and stress
        engineering_strain = 0.5 * (fe.nabla_grad(u) + fe.nabla_grad(u).T)
        return engineering_strain
    def sigma(u):
        cauchy_stress = (
            LAME_LAMBDA * fe.tr(epsilon(u)) * fe.Identity(3)
            2 * LAME_MU * epsilon(u)
        return cauchy_stress
    # Define weak form
    u_trial = fe.TrialFunction(lagrange_vector_space_first_order)
    v_test = fe.TestFunction(lagrange_vector_space_first_order)
    forcing = fe.Constant((0.0, 0.0, - DENSITY * ACCELERATION_DUE_TO_GRAVITY))
    traction = fe.Constant((0.0, 0.0, 0.0))
    weak_form_lhs = fe.inner(sigma(u_trial), epsilon(v_test)) * fe.dx  # Crucial to use inner and not dot
    weak_form_rhs = (
        fe.dot(forcing, v_test) * fe.dx
        fe.dot(traction, v_test) * fe.ds
    # Compute solution
    u_solution = fe.Function(lagrange_vector_space_first_order)
    fe.solve(
        weak_form_lhs == weak_form_rhs,
        u_solution,
        dirichlet_clamped_boundary,
    # Compute the von Mises stress
    deviatoric_stress_tensor = (
        sigma(u_solution)
        1/3 * fe.tr(sigma(u_solution)) * fe.Identity(3)
    von_Mises_stress = fe.sqrt(3/2 * fe.inner(deviatoric_stress_tensor, deviatoric_stress_tensor))
    lagrange_scalar_space_first_order = fe.FunctionSpace(
        mesh,
        "Lagrange",
        1,
    von_Mises_stress = fe.project(von_Mises_stress, lagrange_scalar_space_first_order)
    # Write out fields for visualization with Paraview
    u_solution.rename("Displacement Vector", "")
    von_Mises_stress.rename("von Mises stress", "")
    beam_deflection_file = fe.XDMFFile("beam_deflection.xdmf")
    beam_deflection_file.parameters["flush_output"] = True
    beam_deflection_file.parameters["functions_share_mesh"] = True
    beam_deflection_file.write(u_solution, 0.0)
    beam_deflection_file.write(von_Mises_stress, 0.0)
if __name__ == "__main__":
    main()
The code compiled without errors.
I tried to opened the .xdmf file that the code created in paraview :
<?xml version="1.0"?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []>
<Xdmf Version="3.0" xmlns:xi="http://www.w3.org/2001/XInclude">
  <Domain>
    <Grid Name="TimeSeries" GridType="Collection" CollectionType="Temporal">
      <Grid Name="mesh" GridType="Uniform">
        <Topology NumberOfElements="540" TopologyType="Tetrahedron" NodesPerElement="4">
          <DataItem Dimensions="540 4" NumberType="UInt" Format="HDF">beam_deflection.h5:/Mesh/0/mesh/topology</DataItem>
        </Topology>
        <Geometry GeometryType="XYZ">
          <DataItem Dimensions="176 3" Format="HDF">beam_deflection.h5:/Mesh/0/mesh/geometry</DataItem>
        </Geometry>
        <Time Value="0.000000000000000e+00" />
        <Attribute Name="Displacement Vector" AttributeType="Vector" Center="Node">
          <DataItem Dimensions="176 3" Format="HDF">beam_deflection.h5:/VisualisationVector/0</DataItem>
        </Attribute>
        <Attribute Name="von Mises stress" AttributeType="Scalar" Center="Node">
          <DataItem Dimensions="176 1" Format="HDF">beam_deflection.h5:/VisualisationVector/1</DataItem>
        </Attribute>
      </Grid>
    </Grid>
  </Domain>
</Xdmf>
And paraview crashed when i clicked on apply with both xdmf3ReaderS xdmf3ReaderT. With XDMF Reader, it didn’t crash but i had this error :
ERROR: In vtkXdmfReader.cxx, line 487
vtkXdmfReader (000001E8DABCCA00): Failed to read data.
ERROR: In vtkExecutive.cxx, line 741
vtkPVCompositeDataPipeline (000001E8DAB4C770): Algorithm vtkFileSeriesReader (000001E8DAA2C2B0) returned failure for request: vtkInformation (000001E8E9E9D9D0)
Debug: Off
Modified Time: 411165
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
FROM_OUTPUT_PORT: 0
The error is at least not with the xdmf file, as the paths are complete
Im not at a laptop, so i cant test the code right now
Something weird is that if i add these lines to the code as you suggested in the other topic, the issue disepears :
    encoding = fe.XDMFFile.Encoding.ASCII
    file.write(u_solution,encoding=encoding)
